Results 1 to 21 of 21
Thread: Teensy 3.1 Pin Assignments pdf
    it is possible to get tho original file for this pdf "https://www.pjrc.com/teensy/card5a_rev5.pdf"? I want to insert additional Information about the PWM FTM0 channel pin assignment.
    19,258
    Well, yes, but on 1 condition: I can't help you use Scribus, so please do not ask me to do so. The card was created with Scribus. This data does not exist in any other format, other than this original and the PDF file exported from Scribus.
    If you make any edits others might find helpful, I hope you'll share them here?
    Attached Files Attached Files
    19,258
    This zip file does not contain the PCB image. You'll need to grab that off the Teensy 3.1 product page and then import it to the image object within Scribus.
    Opps, I think I might have just helped with Scribus a bit....
    Boston, MA, USA
    1,103
    Since this is up for edits - Paul, any thoughts on using the clearer and more widely understood Master In - Slave Out and Master Out - Slave In (MISO/MOSI) instead of DIN/DOUT?
    First Try!
    card5a_barney_rev1.pdf
    Dont use for development.
    I am confused, on
    http://www.pjrc.com/teensy/td_libs_SPI.html
    i think MOSI and MISO is in wrong order
    Please take a look on
    http://www.freescale.com/files/captu...lh7_lqfp64.pdf
    I think there are some Pins to delete like TX/RX Pin 3/4 or DOUT/DIN Pin 7/8
    I hope my additions are correct
    card5a_barney_rev2.pdf
    Scribus File
    card5a_barney_rev2.zip
    Jun 2013
    So. Calif
    2,828
    Re pins 11, 12 (SPI data)
    the PJRC crib sheet card lists
    11 DOUT
    12 DIN
    I've found that the "in" and "out" of these is with respect to the ARM CPU as SPI master, so
    11 DOUT == MOSI
    12 DIN == MISO
    (I griped about the use of other than the SPI de facto standard official names like MISO/MOSI - because these official names eliminate the ambiguity in data direction, whereas DIN/DOUT are implicit and thus subject to error. As are TX and RX on UARTs at the module pin level. And the misuse of UART RTS (does not mean ready to send as oft-said).
    Boston, MA, USA
    1,103
    Quote Originally Posted by Barney View Post
    No, those should not be deleted. They are correctly indicated (in pale grey) as the alternate pin functions.
    Hi Stevech, Hi Nantonos
    thanks for your suggestions and information. I have changed MOSI and MISO to the right position. In the wikipedia page i have found that CS are named SS. So i have changed CS to SS.
    Other correction or suggestions?
    Barney
    Boston, MA, USA
    1,103
    Quote Originally Posted by Nantonos View Post
    To clarify, they should not be deleted but they should be changed from DOUT to MOSI and from DIN to MISO.
    I'm seeing an odd glitch on the "2" of I2C (and on Serial2, less obviously).
    Jun 2013
    So. Calif
    2,828
    If you want to tackle the bottom board graphic document... As a noob I found it non-obvious in terms of the signal name labels referring to the inner solder pads, versus the board pins that are adacent to the labels.
    19,258
    Here's the Scribus file for the back side.
    19,258
    One small issue with calling the DOUT pin "MOSI" is it's still the output pin if you configure the SPI port in slave mode. The "SI" portion implies it would be an input.
    Then again, almost everyone uses the SPI port in master mode.
    Hi Nantonos,
    i see this glichtes under Windows not with Linux or Smartphone. Ich have tried different test:
    1. PDF creation with version 1.3, 1.4 , 1.5 -> glitches exisits
    2. Other fonts -> glitches exisits
    3. Make pdf with Linux (Ubuntu) -> glitches exisits
    4. Print out on Color Laser Printer -> no glitches!
    I have no idea to fix it.
    Here two version in one document:
    card5b_barney_rev1.pdf
    What do you mean, lines or grey out?
    Boston, MA, USA
    1,103
    I had forgotten that slave mode was an option.
    That would be useful info to add to the SPI page on the PJRC site.
    "In SPI Master mode, which is the most common configuration, DOUT is MOSI and DIN is MISO. In SPI Slave mode, DOUT is still the output and DIN is still the input."
    19,258
    Oh, I like that design with the lines and dots. Maybe PJRC should do that on the next batch of printed cards....
    Jun 2013
    So. Calif
    2,828
    I like the bottom-side lines/dots to the inner pads.
    Did you want to add those lines/dots to the other seven inner pads?
    Again, this is sympathetic to the noob seeing this for the first time.
    19,258
    I've added a link on the main pinout reference page to this and 2 other alternate pinout threads.
    http://www.pjrc.com/teensy/pinout.html
    Hopefully these links will help everyone find it.
