Results 1 to 3 of 3
Thread: TeensyDuino 1.18RC
    Member geekguy's Avatar
    Feb 2014
    Beaverton, OR
    66
    TeensyDuino 1.18RC
    It doesn't offer 72 MHz as, a speed option for Teensy 3.1.
    8-Dale
    Boston, MA, USA
    1,111
    Correct. Lots of things which depend on the clock frequency being 96/48 would stop working if it was set to 72. Since the 48MHz part reliably clocks to 96, the 72MHz part does too (but I believe there are some improvements, memory access speed? I read it a while ago and can't find it now).
    21,808
    Nantonos is right, there are currently a lot of places in that have code like this:
    #if F_CPU == 96000000
      #define TX_TIMEOUT (TX_TIMEOUT_MSEC * 596)
    #elif F_CPU == 48000000
      #define TX_TIMEOUT (TX_TIMEOUT_MSEC * 428)
    #elif F_CPU == 24000000
      #define TX_TIMEOUT (TX_TIMEOUT_MSEC * 262)
    When 72 MHz is supported, a LOT of things won't work until they're also updated. It's a big job, and honestly it's been a much lower priority than getting the audio library published.
