Patrick Harrop
New member
Hi
My apologies if this has already been answered. Although teensy 3.1 is 5 v tolerant, its output is at 3.3 volts. I am currently using LED buck pucks that require a voltage range of 0 to 5.0 volts from PWM. Any suggestions on how to amplify PWM signals from the teensy (which should have a max of 3.3 volts) to the range of 5 volts? I know this is a rather basic question, but I am a bit of a novice here. Any direction would be appreciated. Thanks
