micknudsen
I have just received my Teensy 3.1 in the mail, and I am eager to get started. This is my first time with something like this, so I am following "Getting Started" on the homepage very carefully. However, when I try to compile Blinky, it fails:
Any ideas what could possibly be wrong? I am running Mac OS X Mavericks 10.9.1. Any help is greatly appreciated. Thanks!
/Michael Knudsen, Denmark
Michael-Knudsens-Mac-Developer:blinky micknudsen$ make
-------- begin --------
avr-gcc (GCC) 4.8.1
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling C: blinky.c
avr-gcc -c -mmcu=atmega32u4 -I. -gdwarf-2 -DF_CPU=16000000UL -Os -funsigned-char -funsigned-bitfields -ffunction-sections -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=./blinky.lst -std=gnu99 -MMD -MP -MF .dep/blinky.o.d blinky.c -o blinky.o
Compiling C: usb_debug_only.c
avr-gcc -c -mmcu=atmega32u4 -I. -gdwarf-2 -DF_CPU=16000000UL -Os -funsigned-char -funsigned-bitfields -ffunction-sections -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=./usb_debug_only.lst -std=gnu99 -MMD -MP -MF .dep/usb_debug_only.o.d usb_debug_only.c -o usb_debug_only.o
usb_debug_only.c:96:24: error: variable 'device_descriptor' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
static uint8_t PROGMEM device_descriptor[] = {
usb_debug_only.c:113:24: error: variable 'hid_report_descriptor' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
static uint8_t PROGMEM hid_report_descriptor[] = {
usb_debug_only.c:128:24: error: variable 'config1_descriptor' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
static uint8_t PROGMEM config1_descriptor[CONFIG1_DESC_SIZE] = {
usb_debug_only.c:175:52: error: variable 'string0' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
static struct usb_string_descriptor_struct PROGMEM string0 = {
usb_debug_only.c:180:52: error: variable 'string1' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
static struct usb_string_descriptor_struct PROGMEM string1 = {
usb_debug_only.c:185:52: error: variable 'string2' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
static struct usb_string_descriptor_struct PROGMEM string2 = {
usb_debug_only.c:198:11: error: variable 'descriptor_list' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
} PROGMEM descriptor_list[] = {
make: *** [usb_debug_only.o] Error 1
