Results 1 to 7 of 7
Thread: AltSoftSerial Project Help
    Mar 2014
    3
    I am using an arduino UNO with a Atlas Scientific ENV-32x data logger.
    I want the arduino to send strings to the data logger, using software serial so it will work without PC connection.
    So just a basic intro, if the button is pressed on pin 5, the arduino should send "D" to the data logger, this command will delete the logger memory.
    Unfortunately, it seems like the data isnt making its way to the data logger for reasons I dont understand. (the logger has an LED that blinks when it receives data.)
    PS(All my wiring has been checked working, and the hardware is not broken.)
    Check out my code below.
    #include <AltSoftSerial.h>
    AltSoftSerial altSerial;
    const int delBtn = 5;
    int buttonStateDel = 0;
      pinMode(delBtn, INPUT);
      Serial.begin(38400);
      Serial.println("AltSoftSerial Test Begin");
      altSerial.begin(38400);
      char c;
      byte cmd;
      buttonStateDel = digitalRead(delBtn);
      if (buttonStateDel == HIGH) {
            Serial.println("Del");
            altSerial.print("D");
      if (altSerial.available()) {
        c = altSerial.read();
        Serial.print(c);
    Olympia, WA
    52
    If you can modify the code using the regular softwareserial library to work (as detailed here: https://www.atlas-scientific.com/_fi...ode-EZ-COM.pdf ) I am not sure what else altsoftserial would add other than throughput, which you don't need to send a "D" character.
    Disclaimer: I often miss the forest for the trees. I also hardcode pin numbers, remove code, and other simplifications until something works. Good luck!
    20,321
    Quote Originally Posted by bdor5285 View Post
    I'm wondering how you can claim to have checked the wiring from pin 9 on your Uno to the serial input on the data logger?
    Mar 2014
    3
    Using the example in the altsoftserial library I was able to check the wiring by sending data to and from the device using serial. After speaking to a representative from the company I was told that the included SoftSerial is not sufficient for use with this device.
    Mar 2014
    12
    Here is the link from Atlas-Scientific to interface data-logger and arduino uno. This example specifically uses normal "SoftwareSerial" library. I hope you might find it useful.
    Mar 2014
    3
    The support person I spoke with explained that this software does not work with the newest logger. I tried it and can garunteed that it doesn't.
    Mar 2014
    12
    Could you paste your circuit diagram and photo of actual connections?
    And also when you are sending any data you also have to send a 'Carriage Returns' i.e. <CR>. Remember in order to format the previous data you need to send "D<CR>D<CR>".
Tags for this Thread
