Page 3 of 3 FirstFirst 1 2 3
Results 51 to 59 of 59
Thread: Teensy Quick Reference: Code Examples, Tips and Tricks
  1. #51
  2. #52
    May 2013
    San Jose, CA
    602
    Dealing with electrical noise in an automotive environment:
    https://forum.pjrc.com/threads/34687...l=1#post105577
  3. #53
  4. #54
    5,187
    Calling this "CPUspecs();" from setup will show you compile time details on your Teensy:
    void CPUspecs() {
    #if defined(__MKL26Z64__)
      Serial.println( "CPU is T_LC");
    #elif defined(__MK20DX256__)
      Serial.println( "CPU is T_3.1/3.2");
    #elif defined(__MK20DX128__)
      Serial.println( "CPU is T_3.0");
    #elif defined(__MK64FX512__)
      Serial.println( "CPU is T_3.5");
    #elif defined(__MK66FX1M0__)
      Serial.println( "CPU is T_3.6");
      Serial.print( "F_CPU =");   Serial.println( F_CPU );
      Serial.print( "ARDUINO =");   Serial.println( ARDUINO );
      Serial.print( "F_PLL =");   Serial.println( F_PLL );
      Serial.print( "F_BUS =");   Serial.println( F_BUS );
      Serial.print( "F_MEM =");   Serial.println( F_MEM );
      Serial.print( "NVIC_NUM_INTERRUPTS =");   Serial.println( NVIC_NUM_INTERRUPTS );
      Serial.print( "DMA_NUM_CHANNELS =");   Serial.println( DMA_NUM_CHANNELS );
      Serial.print( "CORE_NUM_TOTAL_PINS =");   Serial.println( CORE_NUM_TOTAL_PINS );
      Serial.print( "CORE_NUM_DIGITAL =");   Serial.println( CORE_NUM_DIGITAL );
      Serial.print( "CORE_NUM_INTERRUPT =");   Serial.println( CORE_NUM_INTERRUPT );
      Serial.print( "CORE_NUM_ANALOG =");   Serial.println( CORE_NUM_ANALOG );
      Serial.print( "CORE_NUM_PWM =");   Serial.println( CORE_NUM_PWM );
    Above should be correct - I never had a T_3.0 and apparently never ran it on the T_LC - I made this to watch the T_3.5 and T_3.6.
    This line is also useful to record compile TIME and DATE:
      Serial.print(__DATE__);   Serial.print(" -- ");  Serial.println(__TIME__);
  5. #55
    2,574
    Cool
    You can simplify this via string pasting at compilation time to:
      Serial.print (__DATE__ " --- " __TIME__);
    Basically, adjacent strings are combined together by the compiler to from one single string.
  6. #56
    16,298
    We also have a special linker symbol for the build time. Unlike these macros (which don't force a rebuild of the file they're in), it's always updated on every build because Arduino passes it as a parameter to the linker command line. But it's UNIX time, so you need mktime() or TimeLib.h to convert to human readable.
  7. #57
    5,187
    Thanks MichaelMeissner - I finally got around to using this as follows - in setup() after SerialStart( #milis ); is called a programmed wait for Serial to appear is done and a compile signature for the file is the first output.
    #define SerialStart(a) ({Serial.begin(19200); while (!Serial && (millis()< (a))); Serial.print("\n" __DATE__ " --- " __TIME__ " --- " __FILE__ "\n");} )
    used like :: SerialStart( 4000 );
    So setup() just gets one line { if you copy the macro ) that waits a #millis for Serial to come online, and starting a Teensy shows if it was programmed after the last change 3 minutes ago - and a random Teensy on the desk will show with what file and when it was last programmed.
  8. #58
    Salt Lake City, UT, USA
    246
    Thanks everyone, this is all helpful! I have so many versions of test code running at the moment it is nice to see the exact build time, file, and also the CPU details verify settings like clock were correct.
  9. #59
    16,298
Tags for this Thread
