Page 3 of 3 FirstFirst 1 2 3
Results 51 to 66 of 66
Thread: Teensy Quick Reference: Code Examples, Tips and Tricks
  1. #51
  2. #52
    May 2013
    San Jose, CA
    664
    Dealing with electrical noise in an automotive environment:
    https://forum.pjrc.com/threads/34687...l=1#post105577
  3. #53
  4. #54
    9,019
    Calling this "CPUspecs();" from setup will show you compile time details on your Teensy:
    void CPUspecs() {
    #if defined(__MKL26Z64__)
      Serial.println( "CPU is T_LC");
    #elif defined(__MK20DX256__)
      Serial.println( "CPU is T_3.1/3.2");
    #elif defined(__MK20DX128__)
      Serial.println( "CPU is T_3.0");
    #elif defined(__MK64FX512__)
      Serial.println( "CPU is T_3.5");
    #elif defined(__MK66FX1M0__)
      Serial.println( "CPU is T_3.6");
      Serial.print( "F_CPU =");   Serial.println( F_CPU );
      Serial.print( "ARDUINO =");   Serial.println( ARDUINO );
      Serial.print( "F_PLL =");   Serial.println( F_PLL );
      Serial.print( "F_BUS =");   Serial.println( F_BUS );
      Serial.print( "F_MEM =");   Serial.println( F_MEM );
      Serial.print( "NVIC_NUM_INTERRUPTS =");   Serial.println( NVIC_NUM_INTERRUPTS );
      Serial.print( "DMA_NUM_CHANNELS =");   Serial.println( DMA_NUM_CHANNELS );
      Serial.print( "CORE_NUM_TOTAL_PINS =");   Serial.println( CORE_NUM_TOTAL_PINS );
      Serial.print( "CORE_NUM_DIGITAL =");   Serial.println( CORE_NUM_DIGITAL );
      Serial.print( "CORE_NUM_INTERRUPT =");   Serial.println( CORE_NUM_INTERRUPT );
      Serial.print( "CORE_NUM_ANALOG =");   Serial.println( CORE_NUM_ANALOG );
      Serial.print( "CORE_NUM_PWM =");   Serial.println( CORE_NUM_PWM );
    Above should be correct - I never had a T_3.0 and apparently never ran it on the T_LC - I made this to watch the T_3.5 and T_3.6.
    This line is also useful to record compile TIME and DATE:
      Serial.print(__DATE__);   Serial.print(" -- ");  Serial.println(__TIME__);
  5. #55
    3,063
    Cool
    You can simplify this via string pasting at compilation time to:
      Serial.print (__DATE__ " --- " __TIME__);
    Basically, adjacent strings are combined together by the compiler to from one single string.
  6. #56
    20,302
    We also have a special linker symbol for the build time. Unlike these macros (which don't force a rebuild of the file they're in), it's always updated on every build because Arduino passes it as a parameter to the linker command line. But it's UNIX time, so you need mktime() or TimeLib.h to convert to human readable.
  7. #57
    9,019
    Thanks MichaelMeissner - I finally got around to using this as follows - in setup() after SerialStart( #milis ); is called a programmed wait for Serial to appear is done and a compile signature for the file is the first output.
    #define SerialStart(a) ({Serial.begin(19200); while (!Serial && (millis()< (a))); Serial.print("\n" __DATE__ " --- " __TIME__ " --- " __FILE__ "\n");} )
    used like :: SerialStart( 4000 );
    So setup() just gets one line { if you copy the macro ) that waits a #millis for Serial to come online, and starting a Teensy shows if it was programmed after the last change 3 minutes ago - and a random Teensy on the desk will show with what file and when it was last programmed.
  8. #58
    Salt Lake City, UT, USA
    269
    Thanks everyone, this is all helpful! I have so many versions of test code running at the moment it is nice to see the exact build time, file, and also the CPU details verify settings like clock were correct.
  9. #59
    20,302
  10. #60
    May 2013
    San Jose, CA
    664
  11. #61
    Oct 2012
    Portland OR
    608
    I was going to add a note about the Program Pin to my "Teensy Quick Reference: Code Examples, Tips and Tricks", but I can no longer edit it (2014 post is too old?)
    https://forum.pjrc.com/threads/57204...hat-does-it-do
  12. #62
    Oct 2012
    Portland OR
    608
    Teensy 3.x, Teensy 4, F_CPU and F_CPU_ACTUAL:
    https://forum.pjrc.com/threads/57236...l=1#post212642
  13. #63
    Oct 2012
    Portland OR
    608
    Teensy 4 is listed at 100 mA, but is sometimes less. My sample running the stock "blink" application draws about 54 mA or 51 mA depending if the LED is on or off.
  14. #64
    Aug 2019
    southwest USA
    1
    Here are a couple of details that help keep TeensyLC hibernate current
    as low as possible. a) before hibernate delare pin 17 as output and
    write a high or low to it to prevent the input of the buffer chip from
    floating at an intermediate level due to leakages (this can cause up to
    240 ua of extra Iq during hibernate). b) if you are using the atod
    converter and any of the analog input(s) could be somewhere far from
    the rails (not close to 0 or 3.3) during hibernate this can cause an
    extra 70-100 ua of Iq. For a telemetry transmitter that hibernates most
    of the time and sends two analog values over the radio once each minute,
    low Iq was more important than conversion bandwidth. In my case a10 and
    a11 were connected to very high dc impedance resistive dividers (2.2 meg
    and 470k to minimize drain from the batteries being measured) fed from
    batteries to monitor two voltages in the 0-18 volt range. A relatively
    large capacitance (100n) was used at pins a10 and a11 to keep the
    dynamic impedance low during conversions. Because a10 and a11 could
    be below 3.3 or above 0 during hibernate the extra Iq mentioned above
    was occurring. Fix is to tie pin 2 to a10 and pin 3 to a11 and use
    those two pins as outputs to drag a10 and a11 very near ground during
    hibernation. Upon wakeup pins 2 and 3 are declared as inputs followed
    by a delay allowing the dividers and capacitors 5 time constants, the
    conversions are done, and the pins re-stated as outputs that are low
    again. Using these two pre cautions the Iq during hibernate (including
    the drain of an LM2936-5 regulator) is typically 11-12 ua.
    The hardware datasheet for the mcu used in the TeensyLC shows that the
    input current into analog inputs is typically only 0.025 ua but I think
    they forgot to look at Iq vs analog input voltage, and it is hard to
    imagine why they did not do that and/or put the results in the data-
    sheet when the extra current can be 10x sleeping current if the analog
    input(s) are near mid-supply sleeping current. This extra Iq tapers
    down to nil as you move away from mid-supply towards either supply rail.
    // note input divider r's are 2.2 meg and 470 k
      unsigned short int value1,value2,wrd1,wrd2;
      unsigned int ch1,ch2;
    //  atod function
    void atod() {
    // release a10 and a11
        pinMode(2,INPUT);
        pinMode(3,INPUT);
    //  wait for 5 time const
        delay(250);
    //  actual conversions
        value1 = adc->analogRead(A10,ADC_0);
        value2 = adc->analogRead(A11,ADC_0);
    //  limit results
        if (value1<0) value1=0;
        if (value2<0) value2=0;
        if (value1>4095) value1=4095;
        if (value2>4095) value2=4095;
    //  offset error comp both chan
        ch1=(value1-1);
        ch2=(value2-1);
        if(ch1<0)ch1=0;
        if(ch2<0)ch2=0;
    //  error scaling both chan
        ch1=ch1*34330;
        ch1=ch1>>15;
        ch2=ch2*34315;
        ch2=ch2>>15;
        value1=ch1;
        value2=ch2;
    //  re-clamp a10 and a11
        pinMode(2,OUTPUT);
        pinMode(3,OUTPUT);
        digitalWrite(2,LOW);
        digitalWrite(3,LOW);
        wrd1=value1;
        wrd2=value2;
    int main() {
    // declare pin 17 as output
       pinMode(17, OUTPUT);
    // put pin 17 buffer input at one rail
       digitalWrite(17, LOW);
        pinMode(A10, INPUT);
        pinMode(A11, INPUT);
        adc->setAveraging(32); // set number of averages
        adc->setResolution(12); // set bits of resolution
        adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_LOW_SPEED, ADC_0);
        adc->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_LOW_SPEED, ADC_0);
    Last edited by defragster; Yesterday at 05:55 AM. Reason: Added # code format - note the code loop() doesn't terminate ???
  15. #65
    Oct 2012
    Portland OR
    608
    Teensy 4:
    FreqMeasure input is pin 22 (various Teensy models use various pins). https://www.pjrc.com/teensy/td_libs_FreqMeasure.html
    tempmonGetTemp() returns the internal CPU temperature for T4 boards. https://forum.pjrc.com/threads/54711...l=1#post198493
  16. #66
    Oct 2012
    Portland OR
    608
    Teensy 4: DMAMEM keyword needed to access other half of RAM, if 512 KB isn't enough: https://forum.pjrc.com/threads/57269...l=1#post212873
Tags for this Thread
