Results 1 to 9 of 9
Thread: New Product: OctoWS2811 Adaptor Board, $10
    Administrator Paul's Avatar
    Oct 2012
    390
    Today PJRC is releasing an adaptor board for large LED projects using the OctoWS2811 library.
    http://www.pjrc.com/store/octo28_adaptor.html
    If you've followed this forum, you've probably seen many LED projects that had terrible flickering troubles. This board tries to address those problems with the 5V buffer and resistors matched to CAT6 cable. It also encourages a wiring style, where signal grounds run twisted with each signal, and they meet power grounds at the LEDs, which gives the best possible signal quality and avoids the common grounding troubles that cause difficult flickering.
    Junior Member Alecmd's Avatar
    Dec 2013
    8
    Great news! Very useful. Thanks Paul.
    Mar 2014
    2
    Great board, I purchased a few. But I was wondering what the extra connections are for. the 0,1,23,22,19,18.17 and of course the holes below them which all appear to be ground. Thanks
    23,969
    Quote Originally Posted by NormanK View Post
    Those are the I/O pins not used by OctoWS2811. If you're running VideoDisplay and sending all the data from a PC or Mac, you'll probably never need them. But if you're creating a stand-alone project that generates all the graphics on the Teensy3, easy access to the unused pins might be handy for sensor inputs or controlling other stuff.
    Dec 2013
    8
    @Paul: Which kind of TIA/EIA-568 standard do I use? T568A or T568B? I have to crimp my ethernet cables...
    Dec 2013
    Minnesota
    18
    Awesome news!!
    It looks like you've got a capacitor(probably the 0.1uf you've recommended in another thread) on the buffer chip's vcc and 8x 100 ohm impedance matching resistors.
    What is the ninth component?
    Ordered!
    23,969
    There's 1 extra 100 ohm resistor between pin 12 on Teensy3 and the "sync" pad along the bottom.
    Dec 2013
    8
    @Paul: T568A or T568B pin assignments?
    http://en.wikipedia.org/wiki/Category_6_cable
    Thanks.
    23,969
    T568B.
    Actually, you can use either T568B or T568A. I've updated the web page with both.
