Results 1 to 11 of 11
Thread: audio shield anomaly
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    156
    Hey there. I have been building a project around the teensy 3.1 and the audio shield. In the process of increasing the complexity of the system the audio shield stopped sending any audio to the line out jack but still sends generated tones out of the headphone jack. Additionally, line input seems to have stopped working. However...when the unit is not powered the signal from line in to line out is passed through. Powering the system cuts off the signal. It is noteworthy that this happens regardless of code or teensy used as I have a second uC handy and have tried various example programs on both processors in addition to my own code. I'm honestly unsure how this may have happened as I have checked my circuit for problems and found none. My first conclusion is that I have damaged the chip on the audio shield. Posting here due to puzzling pass-thru function. Something still works... thoughts? The behavior is the best description of the apparent problem I can offer. I am already planning to replace the unit, any information on this will help me decide what happens to the old one.
    1,607
    Does your sketch have
      audioShield.unmuteLineout();
    to enable the lineout?
    Pete
    Mar 2014
    New Ulm, Mn
    156
    Yes. I'm sorry I didn't include any code here because I tried the shield with all of the examples and many variations of code and the output behavior was consistent as described. I even tried "toggling" that function(method?) just to see if it had any effect...
    Mar 2014
    New Ulm, Mn
    156
    If I did this right I attached the last iteration of code I attempted. This was working...and didnt sound too godawful...
    Attached Files Attached Files
    1,607
    Works for me.
    Pete
    Mar 2014
    New Ulm, Mn
    156
    http://flaminghand.com/boardfront.jpg
    http://flaminghand.com/boardrear.jpg
    Just for reference this is the board I installed everything to. The audio shield has been removed. The only thing I can see that raises a tiny question is my combining the ground lines for the line in.
    Oct 2012
    Portland OR
    706
    I think the only problem would be shorting VGND and GND (it says on the silkscreen not to do that).
    Mar 2014
    New Ulm, Mn
    156
    Yeah. I didn't do that... I only attached wires to the line in/ line out areas. It was working quite nicely for a while. Too many possibilities including handling. For what it is worth I observed very good audio from the line out, and acceptable levels of heterodyning with all of the redundant signal mixing I was doing there just testing out potential. I'm a musician and have pretty good gear to interface this board with. I'm impressed.
    24,101
    Before we started shipping these, I tried shorting VGND and GND, and also the 2 output lines to GND and VGND, just to see what would happen. The chip does limit the current and things do recover, and the MK20 didn't seem to crash or sustain any damage (the supposed current limit is a little over the MK20's spec).
    Of course, DO NOT actually try shorting VGND and GND, since it stresses the chips quite a lot. But I can tell you I did try it here on the prototype and everything survived.
    As for the original question, I have no idea why the line in & out aren't working.
    Oct 2012
    Portland OR
    706
    Quote Originally Posted by ETMoody3 View Post
    I don't think the behavior of the chip is specified when it is powered off. I don't think the passthrough necessarily means much- there will be a signal path from input to output through the ESD protection diodes, for example, when the chip is powered off so that Vdd = GND.
    Mar 2014
    New Ulm, Mn
    156
    Well, just to be thorough I just tried it again and I get a high frequency sqeal from left and 60 cycle hum from right. Fubar. Ordering two replacements
    Which is to say that if I were hiring engineers like y'all it would be costing a bit more than 30 bux. I should be donating, but suffice it to say I have a new favorite microcontroller dev board. Thanks beyond words for this work on this audio library. When I get good enough handle on what I need you can expect some musician-relevant requests.
