Results 1 to 3 of 3
Thread: feasibility of using Teen 3.x with 3 quadrature encoders?
    9
    A person wants to use 3 quadrature encoders for volume controls and display the number of counts. As far as I Know you can only use one quadrature encoder at a time when the encoder is directly connected to a ARduino Uno board. Hence would it possible to use 3 directly coupled quadrature encoders with Teensy 3.0 or 3.1?
    If not would it be possible to use 3 quadrature encoders with Teensy 3.0 or 3.1 if a converter like a LS7184 is used? A LS7184 converts the output of a quadrature encoder to a clock pulse and a direction signal. See:
    >http://www.lsicsi.com/pdfs/Data_Sheets/LS7183_LS7184.pdf<
    Howard
    24,098
    Yes, 3 encoders works well. Just use the Encoder library.
    On Arduino Uno, only 2 pins have interrupt capability.
    On Teensy 3.1, all 34 digital pins can be used as interrupts!
    9
    Thanks Paul,
    Perfect Answer.
    Howard
Tags for this Thread
