Page 2 of 2 FirstFirst 1 2
Results 26 to 42 of 42
Thread: Serial Number of Teensy 3.1
  1. #26
    8,558
    Indeed @MM, I meant had not seen all those #defines in one place
  2. #27
    Jun 2013
    So. Calif
    2,828
    @Pauls of course with the unique ID in Freescale's chip, one can derive the lower bits of an Ethernet MAC address, an make the upper bits be a registered IEEE OUI such as PJRC et al have. Or, use IEEE's "self-administed" coding for the high bits, and be generic but still unique from any other NICs in the LAN. Self-administered MACs are for use only on a LAN, not into a WAN.
  3. #28
    20,070
    Do you have any idea why the reported USB serialnumber has an additional zero padded?
    The extra zero is a workaround for a Macintosh OS-X bug, where the last digit of the serial number is lost when creating the /dev/cu.usbmodem#### device name, which then has the interface number appended. If you use a Teensy in USB serial mode on a Mac, you'll see the device name always has the serial number, with the last zero replaced by a 1. Without the extra zero, OS-X loses one digit.
    I and others have reported this bug to Apple. Someone on their mail list figured out the exact place in the Darwin source code where the error happens, because a buffer is too short by 1 byte. This conversation happened years ago. Every indication is Apple will never fix this.
    As a workaround, I added the extra zero, so Mac users get proper non-conflicting device names when they have Teensys that differ in serial numbers only on their last digit.
  4. #29
    8,558
    Thanks Paul - wasn't sure why the pad was needed - but - it matched what I saw in Win USB and TyQt
    Question: is there an example of reading 'registers' like the on chip ID - I got to the pointed spot in the manual - but like @PaulS not sure on reading: Address: 4004_7000h base + 1054h offset = 4004_8054h (pg265...F1RM.pdf)
  5. #30
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    107
    @PaulS
    Thanks, found your comment in usb-desc.c as well.
    @Defragster
    Here is a piece of code that reads and displays the 128-bit Unique ID:
      char ID[32];
      sprintf(ID, "%08lX %08lX %08lX %08lX", SIM_UIDH, SIM_UIDMH, SIM_UIDML, SIM_UIDL);
      while (!Serial);
      pinMode(13, OUTPUT);
      digitalWrite(13, HIGH); // just to show that serial port is opened
      delay (1000);
      Serial.print("Reading 128-bit UniqueID from chip: ");
      Serial.println(ID);
    And this is the output on the serial monitor: "Reading 128-bit UniqueID from chip: A4210000 70E10003 00254018 31374E45"
    What's the ID of your Teensy?
    Regards,
    Paul
  6. #31
    1,973
    Unfortunately, I'm not that familiar with coding C++ to access these registers.
    The 4 32-bit UID registers are defined in the firmware in kinetis.h, so you should be able to reference/print them from your sketch
    #define SIM_UIDH        (*(const uint32_t *)0x40048054)    // Unique Identification Register High
    #define SIM_UIDMH       (*(const uint32_t *)0x40048058)    // Unique Identification Register Mid-High
    #define SIM_UIDML       (*(const uint32_t *)0x4004805C)    // Unique Identification Register Mid Low
    #define SIM_UIDL        (*(const uint32_t *)0x40048060)    // Unique Identification Register Low
    The LC has only 3 32-bit UID registers (no UIDH)
  7. #32
    Apr 2015
    Netherlands
    107
    Our posts must have been crossed
    Yes, I also found the definitions in kinetis.h and used them in my code.
    Paul
  8. #33
    1,973
    here are my IDs
    3.1 Reading 128-bit UniqueID from chip: FFFFFFFF FFFF000A 00364009 24754E45
    3.0 Reading 128-bit UniqueID from chip: FFFFFFFF FFFF0013 000C2003 14134D44
    LC Reading 96-bit UniqueID from chip: 00000051 00701007 28234E45
    beta LC 00000024 000E1007 28234E45
    my favorite macro for displaying symbol/value
    #define PRREG(x) Serial.print(#x" 0x"); Serial.println(x,HEX)
  9. #34
    Apr 2015
    Netherlands
    107
    That's interesting. The fineprint on the chip on my (2 months old) Teensy 3.1 reads "1436" on the lowest line, so I guess it's produced in week 36, 2014.
    Since you joined this forum more than 2 years before me, I take it that your Teensy's and chips are manufactured way earlier than mine.
    And that leads to thinking that the default ID on the chip-die is all FF's and then laser-fused before packaging. Someone has an idea about this?
    Regards,
    Paul
  10. #35
    1,973
    batch dates on my chips: 3.0 is 1226, 3.1 is 1234
    (i never could find a date on my LC chips, code 1N15J ?
  11. #36
    20,070
    I've been told those codes like "1N15J" identify which piece of Freescale silicon is actually inside.
    On Teensy 3.1, the oldest boards (from January 2014) have "1N36B". I believe the first digit is the revision of the silicon.
  12. #37
    Apr 2015
    Netherlands
    107
    On my Teensy 3.1, the chip states "3N36B".
    That would be rev 3 of the silicon, which is consistent with the value I read from the System Device Identification Register (SIM_SDID), bits 15-12 [REVID].
  13. #38
    Hi guys,
    I've just received my first Teensy v3.6.... is there a simple way to retrieve a single byte to be used as unique ID?
    Thanks!
  14. #39
    Germany NRW
    5,592
    A single byte is only 255 combinations.. this is why all unique IDs are using more than one byte...
  15. #40
    whoops, you're right!
    Thanks!
  16. #41
    20,070
    How about 16 bytes. NXP put a unique signature into every chip. You can read it with registers SIM_UIDH, SIM_UIDMH, SIM_UIDML and SIM_UIDL.
    Every 32 bit Teensy also has a serial number written by PJRC. Search for info about reading the ethernet mac address.
  17. #42
    Thanks I'll give it a look!
