Page 20 of 21 FirstFirst ... 10 18 19 20 21 LastLast
Results 476 to 500 of 525
Thread: ADC library, with support for Teensy 4, 3.x, and LC
  1. #476
    Jan 2020
    216
    Hello!
    I'm trying to do calculations while waiting for conversions to finish.
    Is it guaranteed that ADC0 will read sensor A0 and sensor A2? And
    ADC1 will always read A1 and A3 in this code? If not, is there a way
    I can change the code to do that?
    adc->startSynchronizedSingleRead(A0, A1);
    //Calculations on previous sensor pair
    from second time through the loop (A2, A3);
    while (adc->adc0->isConverting() || adc->adc1->isConverting());
    g_sensorValue[0] = 1023 - (adc->adc0->readSingle());
    g_sensorValue[1] = 1023 - (adc->adc1->readSingle());
    adc->startSynchronizedSingleRead(A2, A3);
    //Calculations on previous sensor pair (A0, A1);
    g_sensorValue[2] = 1023 - (adc->adc0->readSingle());
    g_sensorValue[3] = 1023 - (adc->adc1->readSingle());
  2. #477
    9,763
    Looking at the code, I think it is reasonably safe to assume that:
    bool ADC::startSynchronizedSingleRead(uint8_t pin0, uint8_t pin1)
        // check pins
        if (!adc0->checkPin(pin0))
            adc0->fail_flag |= ADC_ERROR::WRONG_PIN;
            return false;
        if (!adc1->checkPin(pin1))
            adc1->fail_flag |= ADC_ERROR::WRONG_PIN;
            return false;
        // check if we are interrupting a measurement, store setting if so.
        adc0->adcWasInUse = adc0->isConverting(); // is the ADC running now?
        if (adc0->adcWasInUse)
        { // this means we're interrupting a conversion
            // save the current conversion config, the adc isr will restore the adc
            __disable_irq();
            //digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN) );
            adc0->saveConfig(&adc0->adc_config);
            __enable_irq();
        adc1->adcWasInUse = adc1->isConverting(); // is the ADC running now?
        if (adc1->adcWasInUse)
            __disable_irq();
            adc1->saveConfig(&adc1->adc_config);
            __enable_irq();
        // no continuous mode
        adc0->singleMode();
        adc1->singleMode();
        // start both measurements
        adc0->startReadFast(pin0);
        adc1->startReadFast(pin1);
        return true;
    But what I have not looked at is if those pins are Valid for those ADCs on every Teensy... But you should be able to verify that for whichever teensy you are using by either looking at code, or Reference Manual or easier yet I believe he has a summary of which pins are valid for which ADC...
  3. #478
    May 2015
    USA
    1,085
    Yes, it makes sense to do calculations on A2,A3 values after starting a read on A0,A1. And vice versa.
    > ADC0 will read sensor A0 ...
    Yes, ADC0 is always assigned to the first pin in the parameter list.
  4. #479
    Jan 2020
    216
    Looking at the code, I think it is reasonably safe to assume that.
    Thanks, the pins are valid on the teensy 4 which Iím using and he did specify that.
    Iím getting some strange values ocassionally and itís because of my code but wanted to make sure it wasnít something else before I spend hours looking for a solution.
  5. #480
    Jan 2020
    216
    Thanks 🙏 Just needed to be sure
  6. #481
    Apr 2018
    Eastern Time, USA
    163
    Very nice work
    Can analogSyncRead() be called from an ISR? For example, can it be used in a function that was launched by the timer ?
    Thank you
  7. #482
    9,763
    My guess is it probably can. I have not used the syncRead before, but I have done analogReads on an IntervalTimer...
    For example with my never finish Well monitoring code, that reads in 4 analog values for 4 different current sensors trying to do a quick and dirty RMS to figure out if a pump is running or not.
    My later version I would actually do this with DMA/Timer reads into buffers for two of them, and when this completes I would start it up again on the other two while processing the first two.
    I would do this on an IntervalTimer where I would verify the previous analog Reads completed, and then start up the next set and then do a quick and dirty calculation of RMS. My DMA timed reads would maybe give me 50 sample per the 60 hz sine wave and maybe enough for a couple of complete cycles like 150 samples...
  8. #483
    Apr 2018
    Eastern Time, USA
    163
    Sorry, I meant to post that on the thread for the adc library
  9. #484
    Apr 2018
    Eastern Time, USA
    163
    Hi, nice work.
    1) What setup is needed before calling the fast read function?
    2) Can analogSyncRead() be called from an ISR?
    I notice it appears to disable and enable interrupts. Is there any provision to save and restore the previous interrupt enable state?.
  10. #485
    Senior Member Rolfdegen's Avatar
    Sep 2020
    Germany
    227
    Hallo Teensy friends
    I connected 4 potentiometers to the analog inputs of Teensy 4.1. Each potentiometer has a pin on 3.3V and GND. The ADC result is very noisy and unstable. I've already tried everything, for example RC filters at the input, but without improvement. I changed averaging and resolution without much improvement. What else can I try?
    My last idea is an external ADC chip e.g. MCP 3208 without analog inputs on the Teensy But I would like to use the analog inputs on the Teensy
    //init analog Inputs
    	pinMode(14, INPUT_DISABLE);
    	pinMode(16, INPUT_DISABLE);
    	pinMode(17, INPUT_DISABLE);
    	pinMode(22, INPUT_DISABLE);
    	analogReadResolution(12);
    	analogReadAveraging(16);
    // adc polling every 25ms
    void read_pots (void)
      pot_1 = (analogRead(A0) >> 5);
      pot_2 = (analogRead(A2) >> 5);
      pot_3 = (analogRead(A3) >> 5);
      pot_4 = (analogRead(A8) >> 5);
      if(pot_1 != pot_1_old){
      pot_1_old = pot_1;
      pot_1_change = true;
      if(pot_2 != pot_2_old){
      pot_2_old = pot_2;
      pot_2_change = true;
      if(pot_3 != pot_3_old){
      pot_3_old = pot_3;
      pot_3_change = true;
      if(pot_4 != pot_4_old){
      pot_4_old = pot_4;
      pot_4_change = true;
    My last idea is an external ADC chip e.g. MCP 3208 without analog inputs on the Teensy? But I would like to do without it.
  11. #486
    May 2015
    USA
    1,085
    Two things:
    1) take a few thousand samples and use an average or trimmed mean
    2) do a comparison more like "if ((new_ad + 32 < old_ad) || (new_ad > old_ad + 32)) ..."
    // take mean of samples on each side of the median - adjustable,  no dither
    double trimmed_mean(const uint16_t array[], const unsigned count, const unsigned n)
      qsort(array, count, sizeof(array[0]), compare_u16);
      unsigned sum = 0;
      unsigned n2 = 0;
    #if 0
      // classic method is to trim n of the most extreme samples from each end - try n = 20% of count
      for (unsigned i = n; i < (count - n); ++i) {
        sum += array[i];
        ++n2;
    #else
      // weight each side method - try n = 1 for a tight histogram
      const int median = array[count / 2];
      for (unsigned i = 0; i < count; ++i) {
        if (((int)array[i] >= median - (int)n) && ((int)array[i] <= median + (int)n)) {
          sum += array[i];
          ++n2;
      } // for
      //Serial.printf("med %d,n2 %d  %g\n", median, n2,(double)sum / n2);
      return (double)sum / n2;
  12. #487
    Sep 2020
    Germany
    227
    Thanks for your tip
    I think the right way would be to find the cause of the spikes. With 12-bit resolution, a little noise is normal. But at 7Bit it is not normal (see my test results).
    12Bit resolution
    10Bit resultion
    8Bit resultion
    All tests with Everanging 16
  13. #488
    May 2015
    USA
    1,085
    Say that analogRead() returns 127 and then 128. What do you expect your code to do?
  14. #489
    Sep 2020
    Germany
    227
    I want to set envelope parameter from 0-127 in my Synth. These must be stable.
  15. #490
    Sep 2020
    Germany
    227
    My Prototyp
  16. #491
    Sep 2020
    Germany
    227
    read pots
    // read Pots (ADC resolution 12Bit )
      pot_1_old = pot_1;
      pot_change = true;
      pot_2_old = pot_2;
      pot_change = true;
      pot_3_old = pot_3;
      pot_change = true;
      pot_4_old = pot_4;
      pot_change = true;
  17. #492
    May 2015
    USA
    1,085
    OK, now step through your code in the case where analogRead() returns 127 and then 128. What values do you get for pot_1 and what happens?
  18. #493
    Sep 2020
    Germany
    227
    Ok I understand this. But..the max return value cannot be greater than 127 !?
  19. #494
    Sep 2020
    Germany
    227
    Now I have improved the ADC query.
    // read Pots
      if (pot_1 >= 127){
    	  pot_1 = 127;
      if (pot_2 >= 127){
    	  pot_2 = 127;
      if (pot_3 >= 127){
    	  pot_3 = 127;
      if (pot_4 >= 127){
    	  pot_4 = 127;
      pot_1_old = pot_1;
      pot_change = true;
      pot_2_old = pot_2;
      pot_change = true;
      pot_3_old = pot_3;
      pot_change = true;
      pot_4_old = pot_4;
      pot_change = true;
  20. #495
    Sep 2020
    Germany
    227
    But.. the adc noise is not better (:. Now i have installed 100nF caps on the pots.
    It's not an improvement. Now I want to try to reduce the sample rate.
    Can I do that in Teensy 4.1 board ?
  21. #496
    Sep 2020
    Germany
    227
    ADC noise and potentiometer query
    Video: https://youtu.be/Cuzt2-V0pK0
  22. #497
    Germany
    1,651
    Did you try ResponsiveAnalogRead? (https://github.com/dxinteractive/ResponsiveAnalogRead) This library is fantastic in getting stable reads from pots and similar slow devices.
  23. #498
    Sep 2020
    Germany
    227
    I want to try it and I will report. Tanks ..
  24. #499
    Sep 2020
    Germany
    227
    Hi luni. Thank you for your great tip with ResponsiveAnalogRead. The ADC noise is very low and my potentiometer settings are very stable.
  25. #500
    Nov 2020
    2
    Issue with "synchronizedMeasurements" examlpe
    Hi guys,
    I have troubles running the ADC example "synchronizedMeasurements" as is.
    Issue:
    After compilation (without any errors reported by the compiler) the serial monitor stays empty and no data is displayed.
    I think the reason is the first line in the example
    #ifdef ADC_DUAL_ADCS
    Possible reason:
    Since ADC_DUAL_ADCS is defined later in the code by including "settings_defines.h" via ADC.h -->ADC_Module.h-->settings_defines.h,
    I'm not sure how the compiler reacts to the first line.
    Possible solution:
    If the first and last lines in the example are commented out the example is running fine.
    Could someone provide some insight why I get no error at compile time.
    Does anyone else have such a problem or it is due to my particular system?
    Thanks!
    The above issue was tested on board Teensy 3.5 / Arduino IDE v1.8.13/ Teensyduino v1.53
