Results 1 to 3 of 3
Thread: Wire Library missing size_t requestFrom(uint8_t address, size_t len, bool stopBit)
    Oct 2020
    5
    According to the Arduino API
    https://github.com/arduino/ArduinoCo...dwareI2C.h#L39
    Teensy Wire library is missing this function prototype
    this is causing ArduinoECCX08 to not work with teensy. I have create a PR https://github.com/PaulStoffregen/Wire/pull/36 would appreciate if some one from the team can review and merge it
    1,801
    In my view, the problem lies within the library itself. The only reason that the example code doesn't compile is because the private receiveResponse function requires a "size_t length" argument which is not necessary. Since it is a private function, the only calls to it are from within ECCX08.cpp and none of them actually NEED the length argument to be size_t. They can be "int", in fact in most cases uint8_t would suffice.
    Can you try replacing the receiveResponse function in ECCX08.cpp with this:
    int ECCX08Class::receiveResponse(void* response, size_t length)
      int retries = 20;
    //>>>PAH
    //#define ORIGINAL
    #ifdef ORIGINAL
      size_t responseSize = length + 3; // 1 for length header, 2 for CRC
      byte responseBuffer[responseSize];
      while (_wire->requestFrom((uint8_t)_address, (size_t)responseSize, (bool)true) != responseSize && retries--);
    #else
      int responseSize = (int)(length + 3); // 1 for length header, 2 for CRC
      while (_wire->requestFrom((int)_address, responseSize, 1) != responseSize && retries--);
      responseBuffer[0] = _wire->read();
      // make sure length matches
      if (responseBuffer[0] != responseSize) {
        return 0;
      for (size_t i = 1; _wire->available(); i++) {
        responseBuffer[i] = _wire->read();
      // verify CRC
      uint16_t responseCrc = responseBuffer[length + 1] | (responseBuffer[length + 2] << 8);
      if (responseCrc != crc16(responseBuffer, responseSize - 2)) {
        return 0;
      memcpy(response, &responseBuffer[1], length);
      return 1;
    I'm pretty sure it covers all contingencies but I have no way of testing it - other than it compiles
    Pete
    Oct 2020
    5
    I should have clarified the issue is not with the size_t but with the parameter bool sendstop.
    https://github.com/arduino-libraries...sue-1027169928
    the wire library is missing that. Also there have been other platforms which had the issue but people from arduino recommended have this change in the core of the platform. https://github.com/arduino-libraries...ment-886475456
    The second issue is with the BufferLength the default value is 32 but the ATECC608B chip has cases where it needs to send messages greater than that.
