Results 1 to 9 of 9
Thread: Connecting all inputs/outputs teensy 3.1
    Mar 2014
    Valencia
    58
    Hi agan guys
    I am a newbie in electronics and controller boards. I have a teensy 3.1 and i am testing it.
    I have one little question.
    The teensy 3.1 has the starndard pins (inputs/outputs) but in the backside, there are more extra pins but with a golden plates.
    Which is the best way to connect the cables or connectors? Only by welding? Or Are there other ways?
    Thanks in advance.
    ps=I have been looking for in google and forums the answer but i haven't found it.
    3,768
    Ultimately, you will need to use solder or the equivalent glue to attach wires to the bottom. If you want to use it in a breadboard/perfboard setup, you might want to attach the Teensy to this breakout board, that brings out all of the pins: https://www.tindie.com/products/logl...t=directsearch
    In terms of terminology, the term you want for attaching wires to the Teensy is soldering. Welding tends to mean using very high temps to attach steel/iron, which would destroy a Teensy.
    Mar 2014
    Valencia
    58
    Hi again
    Thank you very much for all information
    Cheers
    ps=I wanted to say Soldering...but google translator is ......
    Sorry for my english
    22,278
    You can solder pins to the bottom-side pads. If you do add pins, please understand the bottom pads are not strong to allow the pins to be repeated unplugged from a tight socket. They simply do not have the same mechanical strength as the through-hole pads. The bottom side pads are really only useful for a permanent soldered connection.
    Mar 2014
    Valencia
    58
    That's Ok Paul
    Cheers
    Germany
    990
    Hi Carcaes1,
    just soldered a shrouded pin header to the bottom pads of a teensy 3.1. It was easier than I thought in the begining.
ID:	1896 Click image for larger version.
    I used a small piece of breadboard to align the pinheader like in the second picture. You then solder one pin to fix the pinheader. Remove the breadboard and solder the rest of the pins.
    Fits nicely and is only a couple of minutes work.
ID:	1900 Click image for larger version.
    Best wishes
    Lutz
    Mar 2014
    Valencia
    58
    Thank you very much!!!
    3,768
    In case you haven't seen it yet, there is a thread talking about adding a shield to bring out the pins shared with an Arduino to an Arduino shield: http://forum.pjrc.com/threads/25620-...ld-DIY-Adaptor.
    The member freto announced his own variant of the shield, that brings out all of the pins: https://www.tindie.com/products/fret...rd-and-shield/.
    In terms of Luni's stripboard, that is nice as well. I would worry about the reset button being pushed by accident if the Teensy is mounted upside down, and there isn't enough of a height clearance to make sure the button clears the ground.
    Germany
    990
    The board is not mounted upside down. I only used the stripboard to keep the smd pinheader in the correct position during soldering of the first pins. (maybe sharing that simple idea helps somebody). The breakout board at Tindie looks usefull indeed, I'll see if somebody in Europe sells those.
