In looking at the Teensy 3.0/3.1 schematic, I'm a bit confused as to what to do with pin 4 from the USB Micro connector. I'm integrating a Teensy onto a board, with a built in USB hub (so I won't actually be using a USB connector direct to the MK20/MINI54, it'll be a downstream device on a Cypress hub IC). Should pin 4 be left floating? So Mini54 P0.0 connects only to MK20 PTA1, and not to the USB chain at all? Or should it be connected to ground? (Ground supposedly would identify it as a 'host,' though I'm not sure how that applies here...)
Thanks!
Thanks!
