T3.1 WIZ820io Safari Webserver Crash
jmercer
Hello to everyone,
I'm hoping someone could replicate or shed light on my problem.
Hardware: T3.1, WIZ820io w/ PJRC Adaptor, Mac computer. I'm running a straight cable directly from the mac into the WIZ.
Software: Teensyduino 1.18, Arduino 1.0.5, WebServer.ino sketch from Ethernet examples, Safari browser 7.0.3
I modified the stock WebServer sketch for mac address and ip. Also added a ifdef to remove the refresh directive for the http header.
Here's my sketch: View attachment WebServerOriginalExample.ino
I can run this setup successfully all day. I've run separate stress tests accessing the sd card and hiting the webserver every sec and everything seems OK.
Problem: I created a bookmark in Safari to access the server and the server crashes nearly every time I use it.
The request header when I paste the server ip into Safari and sent it to a freshly rebooted setup:
new client
GET / HTTP/1.1
Host: 169.254.11.144
Accept-Encoding: gzip, deflate
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_2) AppleWebKit/537.75.14 (KHTML, like Gecko) Version/7.0.3 Safari/537.75.14
Accept-Language: en-us
DNT: 1
Connection: keep-alive
client disonnected
Now I can press the Safari refresh icon as many times as I please to get:
new client
GET / HTTP/1.1
DNT: 1
Cache-Control: max-age=0
client disonnected
Everything is fine. I save the page as a bookmark and put it on the favorites bar, press it and get:
new client
GET / HTTP/1.1
DNT: 1
client disonnected
And the server hangs never to be heard from again.
So the server is able to read the client header and print it to serial, then something happens. I don't know at what level its failing at hardware, software, ethernet, SPI. I do know, from a separate test, I can crash the web server and still be reading the SD card into the serial monitor.
I tried this in Firefox without this problem, however, I found that if I quickly bounce the refresh icon on Firefox, the server crashes without sending a reply at all.
I'm not really interested in browser bugs and quirks, but I am interested in protecting the server.
Any ideas for keeping the server alive? or detecting and restarting it if it locks up?
Let me know if there is a better forum to post this question.
