Lightweight Teensy3.x Fibers Library (C++) Available
wwg
(Edit)The Fibers class has become a C++ template class(/Edit)
For those who are looking for coroutine support without the use of an RTOS, I have made the initial version of the Fibers library in my git repository at:
git@github.com:ve3wwg/teensy3_lib.git
See subdirectory teensy3/fibers.
This is a C++ Fibers template class library for use on the Teensy-3.x. This will only appeal to the non-Arduino IDE users unfortunately, since it is tricky to build into that toolchain (but can be done if someone wants to tackle it).
Additionally, this library requires a symbol to be added to the mk20dx256*.ld loader script. This is necessary so that it can optionally determine how much stack a given fiber (or main routine) uses. Look for instructions at the end of the file fibers.hpp.
Library Notes:
In your main program, or suitable place:
#include <fibers.hpp>
Fibers<> fibers;     // Make global to allow other modules to invoke fibers.yield()
By default, the template class Fibers declares room for 15 fibers + main (16). To explicitly declare this use:
Fibers<[B]16[/B]> fibers;
If you want a non-default main stack size, use:
Fibers<> fibers([B]2000[/B]);  // Use 2000 bytes for main fiber stack (bytes)
Create a new Fiber
From any fiber:
fibers.create(foo,foo_arg,3000);  // Returns a fiber ID as unsigned
Runs foo as a coroutine:
void foo(void *arg) {
Yield
To yield control to the next fiber in round-robin fashion, from main fiber or a coroutine, simply:
fibers.yield();
Determining Stack Size
To determine the stack size(s), instrument the Fibers class first:
Fibers<> fibers(2000,[B]true[/B]);    // true = "instrument" enable
Allow your fibers to run for a while and at some point do:
bytes[0] = fibers.stack_size(0);   // Approx main stack bytes used
bytes[1] = fibers.stack_size(1);   // Approx fiber #1 stack bytes used
...etc...
It is not strictly necessary to create a fiber, if you just want to determine the main fiber's stack usage. In this case, just:
Fibers<> fibers(main_stack_size,[B]true[/B]); // Instantiate with "instrumentation" enabled
After main has run for a while, or prior to exit:
main_stack_bytes = fibers.stack_size(0);
Testing
April 29/2014: This library has been successfully tested on a Teensy-3.1, with the following caveat: Do not allow your fiber/coroutine to exit. This is an area that needs work.
Update - May 4, 2014
The library has been enhanced to allow a fiber (coroutine) to return (exit) and remain stopped. In essence, it becomes trapped in a loop that just performs a yield() call. It's state also is changed to FiberReturned. In this state, it is now possible re-use that fiber, by invoking the method Fibers::restart(). Here you can change the function pointer and argument (the existing allocated stack however, cannot be changed).
This restart capability makes it possible to set up "worker threads" and re-use them upon demand. The fiber must be in the FiberReturned state however.
There are now additionally a Fiber::state() and Fiber::join() method calls. The FIber::join() is extremely useful for blocking the caller's control until the indicated fiber has terminated.
All of these details can be found in the fibers.hpp function.
The previously used assembler module has been replaced with inline asm .cpp module. This should make it easily possible to use from an Arduino sketch (to be tested). A minor modification to the mk20dx256.ld script is required, however to define where the stack begins (for instrumented stack measurements).
The lightweight fiber library has moved to its own project at github, for easier use by Arduino IDE users:
https://github.com/ve3wwg/teensy3_fibers
Git url:
git@github.com:ve3wwg/teensy3_fibers.git
There is an example sketch included in the above repo, but I'll copy it here for your reading convenience:
// Example Sketch illustrating the use of the fibers library.
#include <fibers.h>
// Allocate up to main + 5 fibers:
Fibers<6> fibers(2000); // main loop() is allocated 2000 bytes of stack
int ledm = 13;          // Main LED on teensy 3.x
int led0 = 0;           // Digital pin 0
int led1 = 1;           // Digital pin 1
int led2 = 2;           // Alter to suit
int led3 = 3;           //  your wiritng preference
uint32_t ffoo = 0;      // fibers.create() index for the foo() fiber
uint32_t fbar = 0;      // fibers.create() index for bar() etc.
uint32_t fzoo = 0;
void yield() {
  fibers.yield();      // Yield cpu to next fiber in round-robin sequence
static void
toggle(int led,int& led_state) {
  led_state ^= 1;                              // Alternate state on/off
  digitalWrite(led,led_state&1 ? HIGH : LOW);  // LED on/off
// First fiber (coroutine)
static void foo(void *arg) {
  unsigned count = 0;
  int led0_state = 0;
  while ( count++ < 35 ) {
    toggle(led0,led0_state);
    delay(230);
  digitalWrite(led0,LOW);
// 2nd fiber (coroutine)
static void bar(void *arg) {
  unsigned count = 0;
  int led1_state = 0;
  while ( count++ < 40 ) {
    toggle(led1,led1_state);
    delay(250);
  digitalWrite(led1,LOW);
// 3rd fiber (coroutine)
static void zoo(void *arg) {
  unsigned count = 0;
  int led2_state = 0;
  while ( count++ < 47 ) {
    toggle(led2,led2_state);
    delay(270);
  digitalWrite(led2,LOW);
  pinMode(ledm,OUTPUT);
  pinMode(led0,OUTPUT);
  pinMode(led1,OUTPUT);
  pinMode(led2,OUTPUT);
  pinMode(led3,OUTPUT);
  digitalWrite(ledm,HIGH);
  digitalWrite(led3,LOW);
  ffoo = fibers.create(foo,0,1000);  // Create first coroutine foo(0)
  fbar = fibers.create(bar,0,1200);  // Create 2nd coroutine bar(0)
  fzoo = fibers.create(zoo,0,1100);  // Create 3rd coroutine zoo(0)
// main thread
  unsigned count = 0;
  int ledm_state = 0;
  digitalWrite(ledm,LOW);        // Turn off Teensy LED while main loops
  while ( count++ < 20 ) {      // Loop only 20 times in main
    toggle(led3,ledm_state);    // Toggle led3 while main thread runs
    delay(350);
  digitalWrite(ledm,HIGH);      // Teensy LED on means it is doing joins
  digitalWrite(led3,HIGH);
  fibers.join(ffoo);            // Stop here until foo() returns
  fibers.join(fbar);            // Stop here until bar() returns
  fibers.join(fzoo);            // Stop here until zoo() returns
  digitalWrite(led3,LOW);       // Indicate pause before restarts
  delay(3000);
  fibers.restart(0,foo,0);      // Restart foo(0) at next yield()
  fibers.restart(1,bar,0);      // Restart bar(0) at next yield()
  fibers.restart(2,zoo,0);      // etc..
// End arduino_fibers.ino
This sketch requires 4 LEDs to be wired up to see the full effect. LEDs 0, 1, and 2 blink as the fibers (coroutines) foo(), bar() and zoo() blink their respective LEDs at slightly different rates. When the given coroutine "returns", the respective LED will be lit solid. The main loop() blinks the LED3 for the shortest period of time. When it exits its blink loop, it then joins with fibers foo(), bar() and zoo() in that sequence. When the joins have completed, all four LEDs 0 thru 3 will be lit for 3 seconds before the sketch repeats.
The teensy LED (13) is lit as it is doing joins with the other threads. It turns off, while it is performing its own blink action on LED3. I used a bar graph LED (RBG 1000), but you can of course use whatever you have on hand.
It looks great, as I see in the github description, it's possible now to use it as a normal library in arduino? I'm a bit confused because you said before that it wasn't that easy.
When I first developed the library, I used a separate assembler language module, which I don't believe will be handled by the IDE. I've since converted it to a .cpp module, using inline asm where it was needed. That change made it possible to just #include it into a sketch.
Read the API... are there API methods for MUTEXs, semaphores, queues, etc? Methods for ISRs to use to put data in queue, set a semaphore, etc?
Note sure about the point that you are making, but this class does not need to, nor is designed to replace mutexes, queues or semaphores. It is simply a way to provide cooperative multitasking in a lightweight object.
Hi wwg,
I just started using your fibers library and I like what i see so far. It's actually the most compatible scheduler for the teensyunio core i've used through your use of yield. Though I'm seeing a possible bug with your example. If I comment out "bar" and "zoo" fibers the foo fiber does not restart. I've narrowed it down to restart fiber routine. In the example you have "fiberx" for "foo" set to 0, isn't that the main thread? So shouldn't the fiberx parameter be ffoo (1)? Here is whittled down example that shows what I mean.
#include <fibers.h>
uint32_t fzoo = 0;
void yield() {
  unsigned count = 0;
    Serial.println("foo");
    delay(230);
  unsigned count = 0;
    //Serial.println("bar");
    delay(250);
  unsigned count = 0;
    //Serial.println("zoo");
    delay(270);
  pinMode(LED_BUILTIN, OUTPUT);
  while(!Serial);
  Serial.printf("ffoo: %i | fbar: %i | fzoo: %i\n", ffoo, fbar, fzoo);
  fibers.join(ffoo);
  fibers.restart(0,foo,0);// error in restarting
  //fibers.restart(ffoo,foo,0);// resumes as normal
// main thread
    int state = fibers.state(ffoo);
    Serial.print("Fiber State: ");
    Serial.println(state);
Maybe I'm missing something?
duff
Hi wwg,
#include <fibers.h>
  while(!Serial);
  fibers.join(ffoo);
  // fibers.restart(0,foo,0);// error in restarting
duff
No, I think you found typos! Yes, indeed 0 is the main thread. The value used in the restart method should be the index returned in the fibers.create() method. So yes, use ffoo in the example, not zero. I'll fix the example program on github in the mean time.
Thanks for pointing that out.
Warren
I'm trying to use this on a teensy 3.6, and I'm running into a linker problem. Maybe there's just a line missing in the instructions. I've added at the end of the teensyduino linker script (mk66fx1m0.ld):
	.stack :
	    . = ALIGN(4);
        _sstack = .;
	    . = . + _minimum_stack_size;
	    . = ALIGN(4);
	} >RAM
	_estack = ORIGIN(RAM) + LENGTH(RAM);
(the last line is part of the original file). However, _minimum_stack_size is missing and the linker complains. Do I need to define that in the linker script as well or is there another way to sneak it into the application?
This is the sketch I'm trying to compile and test:
#include <fibers.h>
Fibers<2> fibers(2000);
void yield() {fibers.yield();}
#define LED LED_BUILTIN
static void stuff(void* arg)
  pinMode(LED, OUTPUT);
  digitalWriteFast(LED, 1);
  int count = 0;
  while(count < 10)
    delay(250);
    digitalWriteFast(LED, !digitalReadFast(LED));
    count++;
  auto fStuff = fibers.create(stuff, nullptr, 1000);
  int count = 0;
  while(count < 10)
    delay(250);
    Serial.printf("c = %d\n", count);
    count++;
  fibers.join(fStuff);
One question regarding this sketch: I'm not doing anything in loop(). Is it ok to use fibers just from setup() if it's a "one-shot" application?
I have a version that works that is based off this fibers library here. No linker scripts edits involved either.
One thing to look out for is you need to call the 'yield' function in any loop you do or the other tasks will be starved. Luckily 'delay(x)' calls yield but delyMicroseconds does not so be careful on how you use that. Another thing is dynamic memory allocations won't work with this scheduler library, so no printf, String, Malloc, New etc... Besides that it works great for many projects I've done. I used it with the Audio Library with no issues since each task at running priority 255 (User Level). I actually used a modified version in my TeensyTracks library to play songs from samples and synthesized Audio Objects.
OK that's kinda bad because I need dynamic memory for my graphics library. Why can't I allocate memory dynamically? Can we somehow implement support for dynamic memory?
Also it doesn't seem to like a task returning, but I'd like to do that as well.
Because this uses static memory for your tasks and the dynamic alloction could step all over that area. I did look at the Placement New allocation in that you allocate a memory space globably and do smaller memory allocation from that memory pool.
If a task retuns it stays in paused state until you start it again.
In other words if tasks are created from a memory pool it could allow for dynamic memory with malloc?
This might shed some light on it here, i haven't looked into this for awhile. Where do you do malloc calls in a library? If so where I'll take a look.
What I wrote above doesn't make sense given your description of a possible workaround.
However, since malloc works on the heap and the fibers have statically allocated stack space (don't they?), I don't see the reason why malloc shouldn't work. The two regions would only overlap if one of them grows too much, but that is also the case when I don't use any kind of multitasking at all.
I seem to be missing a crucial point here.
yes it is statically allocated.
The article you kinked to above only explains placement new, alignment and related issues, but it doesn't explain why your library doesn't allow me to use malloc.
About my application: I have written my own widget classes on top of uGFX, and each widget can have a parent. They are created dynamically and parents can delete their children, so that I can open and close dialogues, for example. I basically do something like
Widget* pW = new Widget(nullptr); // root widget
Widget* pB = new Button(pW, width, height); // button is now a child of the root widget, and the root widget takes care of deletion
//... let it live for a while
delete pW; // deletes pB as well
There's no (public) library yet, but I might just upload the code so that you can have a look. It's in an early stage so it might be possible to restructure it entirely to make static allocation possible. As it is, parents delete their children and that makes use of the heap/malloc necessary unless I write my own memory manager. That would probably suck (both the task and the resulting code).
I've seen issues with printf so thats why I say that but maybe if your careful it won't hang. I did some tests with malloc and it ran fine but then the US election madness took over, now I'm in shock!
I managed to take dynamic memory out of my widgets, but at the cost of signals and slots. I'll do some more testing with that, and then move on to using them in fibers. You say that your library is based on the Fibers library, but what does it actually provide? Fibers, coroutines, or something else? I'm just curious about the wording...
Its cooperative multitasking, meaning that tasks must yield for other tasks to run so yes these are considered fibers still.
I'm late to the party here (sorry, but been busy).
The fibres library should work just fine with malloc/free/printf et al. assuming stack and heap are properly set up. Because the context switch only happens when yield() is called, you'll never interrupt printf or malloc type functions. The only thing left that you have to be careful about is what your interrupt service routines are doing. Those occur at any time (when not blocked) and should thus not being doing anything with malloc/free etc.
Warren.
