Results 1 to 3 of 3
Thread: Addressing pins of PORT A or B
    I am trying to control the pins of PORT B or A, I can control the first 4 pins but not beyond.
    Following the table found in this thread, I made a simple example, it should blink a LED set on pin 0:
    //PortA[4:5, 12:13] = {33, 24, 3, 4}
    //PortB[0:3, 16:19] = {16, 17, 19, 18, 0, 1, 32, 25}
    //PortC[0:11] = {15, 22, 23, 9, 10, 13, 11, 12, 28, 27, 29, 30}
    //PortD[0:7] = {2, 14, 7, 8, 6, 20, 21, 5}
    //PortE[0:1] = {31, 26}
    uint16_t const PIN = 65536; // 2^16 according to the reference table
    int led = 0;
      pinMode(led, OUTPUT);
      GPIOB_PDOR |=  PIN;// pin HIGH
      delay(1000);               // wait for a second
      GPIOB_PDOR &=~ PIN;// pin LOW
    What is the proper way to control these pins?
    1,492
    In hex 65536 is 10000 which means that it can't be represented in 16 bits, so PIN is zero because it is uint16_t.
    If you are using Teensy3.x you need PIN to be declared as uint32_t.
    Pete
    Thanks Pete,
    indeed it was an obvious mistake... and it's not the first time I make it!
