Results 1 to 2 of 2
Thread: Cross Compiling for Teensy - Kinda - Scenario Help
    Greets all!!
    I am a little slow on some things and it took awhile for me to have a light bulb blow up over my head.
    On a project I am working on, my Teensy 3.1 is the nerve-center of most of the hardware control. The display and input are handled by a Arduino Pro Mini 328 5v, but the rest is all Teensy 3.1. I am also using a Raspberry Pi to communicate with the Teensy via serial to get sensor readings, project status, and feed all that to a MYSQL database. Under normal operation, I have the Teensy connected to a 3a 7 port hub that is connected to the RPi, just for power. I totally forgot that it might be recognized by the RPi, and sure enough, 'lsusb' at a terminal CLI confirmed that the Teensy was there (Bus 001 Device 005: ID 16c0:0483 VOTI Teensyduino Serial). HEY! I have OPTIONS HERE!!
    So now I am trying to figure out how I can program the Teensy from the RPi running Raspbian with code I compile on my Windows 7 laptop. The RPi is connected to my wireless network via the EDIMAX dongle (Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]) and is CLI only with no GUI. I imagine I can compile the program on my laptop, upload it to a directory on the RPi, and run something from the command line.
    Has anyone done this and if so could you steer me to a walk through / tutorial? Later on, I might explore programming the Arduino Pro Mini 328 5v from the Teensy 3.1, which would be weird because it would then be... Raspberry Pi >> Teensy 3.1 >> Arduino Pro Mini.
    Of course, the idea is that I can program all the subsystems with updates with one singular wireless connection.
    Thank you for your time!!!
    Jul 2013
    10
    Hi as long you just want upload the hexfile (colpiled on laptop) from you raspi to teensy, downnload the teensy_loader commandline mentieoned in http://forum.pjrc.com/threads/3654-T...ight=raspberry.
    Use the -r (reboot) option and manual reset your teensy by pushing the reset button (it took me a lot time to find it out).
    More diddicult would be to crosscompile on raspberry. The provided toolchain is buggy, I do compile on ubuntu to a shared drive on raspi, where I can upload the hex file.
Tags for this Thread
