TheNorthForty
I'm trying to locate the mac.h library referenced in this sketch. Can anyone point me in the right direction?
I'm using a Teensy3.1 via Arduino 1.05 on a macbook air running Mavericks. If I'm in the wrong forum, just let me know.
source
source
HTML:
https://gist.github.com/natcl/9604245
//version3 - 8th March 2014 - uses universeSize and requires first_universe_number
// libraries
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <OctoWS2811.h>
#include <mac.h>
/* uses libs and open licence stufffrom many sources incl. PJRC and ArtisticLicence.*/
//this sketch is a cut down test for receiving Art-net packages via ethernet
* To get this to work for you, YOU NEED TO CHANGE:
* 1) the mac address and IP info to same as your artnet sender
* 2) change leds per strip and universe size (universeSize is size of software output universe selected)
* 3) ensure buff2 size is large enough to take complete led array data set for each frame
* 4) check first_universe_number, can be found using test sketch (usually is 1, sometimes is zero).
*for example, in pixelcontroller i have set the array of 60*8 leds, the universe size set to 30
* and the IP set to 192, 168, 1, 10, and port always remains 6454. At the moment, I can only get
* the frame rate max at 15fps, with 480 leds
*so for the sketch, I have ledsPerStrip=60, and I need to set universe size to 30
* number of channels and channel buffer go to 90 automatically (as 3*30). buff2 size can be smaller or biggger
* depending on the total array buffer size requied.
//-------------------- for OctoWS8211--------------------//
const int ledsPerStrip = 60;//CHANGE FOR YOUR SETUP
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
//----------------end of octows2811 inputs----------------//
byte ip[] = {192, 168, 2, 2}; // the IP adress of your device, that should be in same universe of the network you are using
unsigned int localPort = 6454; // DO NOT CHANGE artnet UDP port is by default 6454
//---------------artnet and buffers------------//
const int startUniverse = 0; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as zero.
const int numberOfChannels= 180; // Total number of channels you want to receive (1 led = 3 channels)
const int ArtNetHeaderSize = 18; // Do not change
byte channelBuffer[numberOfChannels]; // buffer to store filetered DMX data//SHOULD BE SAME AS numberOfChannels
const int MAX_BUFFER_UDP = 530; // leave as is
char packetBuffer[MAX_BUFFER_UDP]; //buffer to store incoming data
EthernetUDP Udp;
// Art-Net packet parsing
char packetID[8]; // ID of the packet, should be "Art-Net" else ignore
byte sequence;
int incomingUniverse;
int dmxDataLength;
int packetSize;
read_mac();
//setup ethernet and udp socket
Ethernet.begin(mac,ip);
Udp.begin(localPort);
delay(250);
Serial.println("end of setup");
Serial.println("waiting for incoming Artnet to start");
//if nothing appears after this, then the loop is not receiving your
//artnet package
leds.begin();
showInit(); //show an led array to confirm
packetSize = Udp.parsePacket();
if (packetSize)
Udp.read(packetBuffer, MAX_BUFFER_UDP);
//-------read incoming universe and sequence number and check for data series-------------//
for (int i = 0 ; i < 8 ; i++)
packetID[i] = packetBuffer[i];
sequence = packetBuffer[12];
incomingUniverse = packetBuffer[14] | packetBuffer[15] << 8;
dmxDataLength = packetBuffer[17] | packetBuffer[16] << 8;
//-----this section can be commented out if not debugging
printPacketInfo();
//------read one universe and put into the right part of the display buffer----//
for (int i = 0 ; i < dmxDataLength ; i++)
int bufferIndex = i + ((incomingUniverse - startUniverse) * dmxDataLength);
if (bufferIndex < numberOfChannels) // to verify
channelBuffer[bufferIndex] = byte(packetBuffer[ArtNetHeaderSize + i]);
//------send to leds----//
for (int i = 0; i < ledsPerStrip * 8; i++)
leds.setPixel(i, channelBuffer[(i) * 3], channelBuffer[(i * 3) + 1], channelBuffer[(i * 3) + 2]);
leds.show();
void printPacketInfo()
Serial.print("Received packet of size ");//all print can be removed if not debugging
Serial.println(packetSize);
Serial.print("universe number = ");
Serial.print(incomingUniverse);
Serial.print(" ");
Serial.print("data length = ");
Serial.print(dmxDataLength);
Serial.print(" ");
Serial.print("sequence n0. = ");
Serial.println(sequence);
//for (int i = 0 ; i < numberOfChannels ; i++){
//Serial.print(channelBuffer[i], DEC);
//Serial.print(" ");
//---create initial image---//
void showInit() {
//-----set all black----//
for (int i=0; i < 1000; i++) {
leds.setPixel(i, (0,0,0));}
leds.show();
//-----set display area size to blue-----//
for (int i=0; i < ledsPerStrip*8; i++) {
leds.setPixel(i, (0,0,50));
leds.show();
