touchRead on pin 0 not working
Hi there,
I'm using the touchRead library on a number of pins on my Teensy 3.1, and for the most part it's working great.
The only exception is pin 0, which is marked as a Touch pin on the reference card. When I try to print the output of touchRead(0) I just get a steady stream of "65535" in the output window.
Is this because pin 0 is also the RX1 pin? Is there a way around this? I'd like to use all the touch pins, if possible.
Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
