I'm writing a template class that uses interrupts. For every specialization, I have to make sure that the ISR name matches the template arguments. That's tedious and error-prone.
I'm not trying to change the way teensyduino works, but would it be theoretically possible to create an interrupt handler table with specialized template functions? The "classic" C table looks like this:
Instead, we could move the whole table out of the "extern C" declaration and use a template function:
And specialize ISRs in headers:
That would facilitate e.g. passing a DMA channel as a template parameter to a driver class, which then specializes the handler for this DMA channel interrupt. I'm just not sure if it *can* work, that's why I didn't try yet. Any thoughts on this?
Regards
Christoph
__attribute__ ((section(".vectors"), used))
void (* const gVectors[])(void) =
(void (*)(void))((unsigned long)&_estack), // 0 ARM: Initial Stack Pointer
ResetHandler, // 1 ARM: Initial Program Counter
nmi_isr,
template<typename T>
void handler(void)
... // what the "unused_isr" handler does
Handler<Reset>, // 1 ARM: Initial Program Counter
Handler<Nmi>,
template<>
void Handler<Dma::Channel<3> > (void)
Regards
Christoph
