Results 1 to 3 of 3
Thread: Teensy 3.1 OctoWS2811 Adaptor with LPD8806
    May 2014
    6
    Hello, I want to know if can I use Teensy 3.1 OctoWS2811 Adaptor with LPD8806 IC?
    Where can I found a skematic diagram to wire Teensy 3.1 and LED Strips LPD8806 and the library to control the LEDs?
    Thank you.
    25,082
    Quote Originally Posted by rumenigg View Post
    No, not really in any way that makes sense.
    You could use pairs of the signals to control the clock and data pins on LPD8806, but since none of the pins are to the SPI port DOUT or SCLK pins, you'd be stuck with bit bashing. That's probably not very useful.
    May 2014
    6
    Thank you for your reply Paul.
    Paul, How many LEDs LPD8806 can I control with teensy 3.1?
    Where can I find any schematic to wire LED Strips LPD8806?
