Chopsticks
While i'm busy with my project for measuring ECG signals, there are some issues which came across.
I've managed to write 2 analog signals synchronous to the sdcard.
But at this very moment:
a) I'm using an usb-to-I2C adapter which is connected to my Teensy and digital potentiometer (parallel).
b) With LabVIEW i can adjust the resistor value on the digital potentiometer by using the usb-to-i2c module.
c) I'm using an usb-6008 tool from NI to measure/analyze the analog values that comes out of the sensor. I haven't used the teensy I2C yet but i've managed to control this module by LabVIEW
The problem:
When I upload the code which measures the adc values and write the values to an SD-card, there is noise on the output of the sensor. Keep in mind, the output is determined by the digital potentiometer (adjustable gain amplifier).
The digital potentiometer is connected with the i2c-bus on teensy and the usb-to-i2c module.
Anyhow... when i upload an example of the teensy's i2c_t3 library (slave). i don't get those interference on my output signal...
So i thought it could be the settings? So i adjusted my code where the i2c slave settings has been included. But even in this scenario, the results are still worse..
I quess this has something to do with the MISO/MOSI/CS/SCLK, which interferes the i2c output?
The question:
1) What could the problem be?
2) Is it possible to use i2c and write to sd card at the same time? without interfering each other?
Code File:
https://github.com/WildeSkippy/Sourcefiles/
"Teensy 3.1 - ADC Measurement + SD Write + I2C"
Anyone can help with this?
Greetings!
Klaas
The problem:
The question:
Code File:
/* Example for synchonized measurements using both ADC present in Teensy 3.1
* You can change the number of averages, bits of resolution and also the comparison value or range.
//Inclusing Libraries
#include <ADC.h>
#include <string.h>
#include <Time.h>
// I2C - Libraries
#include <i2c_t3.h>
#ifdef I2C_DEBUG
#include <rbuf.h> // linker fix
//Define ADC Inputs
#define ADC_0 1
#define ADC_1 1
// I2C - Command definitions
#define WRITE 0x10
#define READ 0x20
// I2C - Function prototypes
void receiveEvent(size_t len);
void requestEvent(void);
// I2C - Memory
#define MEM_LEN 256
uint8_t mem[MEM_LEN];
uint8_t cmd;
size_t addr;
//Teensy 3.1 has the LED on pin 13
//const int ledPin = 13;
const int readPin0 = A2; //ADC read A2
const int readPin1 = A3; //ADC read A3
const int chipSelect = 10; //CS(SS) select SD-Card
ADC *adc = new ADC(); // adc object
File myFile;
char filename[] = "00000000.txt";
//pinMode(ledPin, OUTPUT);
pinMode(readPin0, INPUT); //Read analog signal pin1
pinMode(readPin1, INPUT); //Read analog signal pin2
//Set Serial
// while (!Serial); // Wait for Arduino Serial Monitor to open
//Set Time
if (timeStatus()!= timeSet) {
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
//Set ADC (Averaging and Resolution)
adc->setAveraging(16, ADC_0); // set number of averages
adc->setResolution(12), ADC_0; // set bits of resolution
adc->setAveraging(16, ADC_1); // set number of averages
adc->setResolution(12, ADC_1); // set bits of resolution
// always call the compare functions after changing the resolution!
//adc->enableCompare(1.0/3.3*adc.getMaxValue(), 0, ADC_0); // measurement will be ready if value < 1.0V
//adc->enableCompareRange(1.0*adc.getMaxValue(ADC_1)/3.3, 2.0*adc.getMaxValue(ADC_1)/3.3, 0, 1, ADC_1); // ready if value lies out of [1.0,2.0] V
//delay(100);
Serial.println("end setup");
Serial.println("");
//Initializing SD Card for writing
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(chipSelect, OUTPUT);
if (!SD.begin(chipSelect)) {
Serial.println("Initialization failed!");
return;
Serial.println("Initialization done.");
getFileName();
createFileName();
// Setup for Slave mode, address 0x44, pins 18/19, external pullups, 400kHz
Wire.begin(I2C_SLAVE, 0x44, I2C_PINS_18_19, I2C_PULLUP_EXT, I2C_RATE_100);
// init vars
cmd = 0;
addr = 0;
for(size_t i=0; i < MEM_LEN; i++)
mem[i] = 0;
// register events
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
//int value0 = 0;
//int value1 = 0;
ADC::Sync_result result;
if (Serial.available()) {
time_t t = processSyncMessage();
if (t != 0) {
Teensy3Clock.set(t); // set the RTC
setTime(t);
//delay(5000);
myFile = SD.open(filename, FILE_WRITE);
//ADC values
result = adc->analogSynchronizedRead(readPin0, readPin1);
int ADCvalue_0 = result.result_adc0;
int ADCvalue_1 = result.result_adc1;
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
if( (result.result_adc0 !=ADC_ERROR_VALUE) && (result.result_adc1 !=ADC_ERROR_VALUE) ) {
// the test results below were obtained commenting out all Serial.print*() and the delay() lines
// the decimal point is a comma, print.cpp has been changed for this. instead of a point, a comma has been used
//GPIOC_PTOR = 1<<5;
Serial.print("Time: ");
digitalClockDisplay_WriteToSerial();
Serial.print("\t(ADC0): ");
Serial.print(ADCvalue_0*3.3/adc->adc0->getMaxValue(), DEC);
Serial.print("\tA3(ADC1): ");
Serial.println(ADCvalue_1*3.3/adc->adc1->getMaxValue(), DEC);
if (myFile) {
(digitalClockDisplay_WriteToSD());
myFile.print("\t");
myFile.print(10*ADCvalue_0*3.3/adc->adc0->getMaxValue(), DEC);
myFile.print("\t");
myFile.println(10*ADCvalue_1*3.3/adc->adc1->getMaxValue(), DEC);
//close the file:
myFile.close();
//Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("Error 1: Can't open file!");
Serial.println("Error 2: Comparison failed");
GPIOC_PTOR = 1<<5;
delay(4);
void readFile(){
// re-open the file for reading:
myFile = SD.open(filename);
if (myFile) {
Serial.println("Last file:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
Serial.println("Error 3: Can't open file");
void getFileName(){
filename[0] = (month()/10)%10 + '0'; //To get 1st digit from year() '2';
filename[1] = month()%10 + '0'; //To get 2nd digit from year() '0';
filename[2] = (day()/10)%10 + '0'; //To get 3rd digit from year() '1';
filename[3] = day()%10 + '0'; //To get 4th digit from year() '4';
filename[4] = (hour()/10)%10 + '0'; //To get 1st digit from month() '0';
filename[5] = hour()%10 + '0'; //To get 2nd digit from month() '5';
filename[6] = (minute()/10)%10 + '0'; //To get 1st digit from day() '1';
filename[7] = minute()%10 + '0'; //To get 2nd digit from day() '6';
/*filename[0] = (year()/1000)%10 + '0'; //To get 1st digit from year() '2';
filename[1] = (year()/100)%10 + '0'; //To get 2nd digit from year() '0';
filename[2] = (year()/10)%10 + '0'; //To get 3rd digit from year() '1';
filename[3] = year()%10 + '0'; //To get 4th digit from year() '4';
filename[4] = (month()/10)%10 + '0'; //To get 1st digit from month() '0';
filename[5] = month()%10 + '0'; //To get 2nd digit from month() '5';
filename[6] = (day()/10)%10 + '0'; //To get 1st digit from day() '1';
filename[7] = day()%10 + '0'; //To get 2nd digit from day() '6'; */
filename[8] = '.';
filename[9] = 't';
filename[10] = 'x';
filename[11] = 't';
Serial.println(filename);
void createFileName(){
//Check file name exist?
if (SD.exists(filename)) {
Serial.println("exists.");
else {
Serial.println("Filename doesn't exist.");
Serial.println("Creating a new file");
myFile.print("Date: ");
myFile.print(day());
myFile.print("-");
myFile.print(month());
myFile.print("-");
myFile.print(year());
myFile.print("\t");
myFile.print(hour());
myFile.print(":");
myFile.print(minute());
myFile.print(":");
myFile.println(second());
myFile.close();
void digitalClockDisplay_WriteToSerial() {
// digital clock display of the time
Serial.print(day());
Serial.print("-");
Serial.print(month());
Serial.print("-");
Serial.print(year());
Serial.print("\t");
Serial.print(hour());
printDigits(minute());
printDigits(second());
//Serial.println("\t");
void digitalClockDisplay_WriteToSD() {
// myFile.print(day());
// myFile.print("-");
// myFile.print(month());
// myFile.print(year());
// myFile.print("\t");
myFile.print(":");
myFile.print(":");
myFile.print(second());
myFile.print(",");
myFile.print(millis());
time_t getTeensy3Time()
return Teensy3Clock.get();
/* code to process time sync messages from the serial port */
#define TIME_HEADER "T" // Header tag for serial time sync message
unsigned long processSyncMessage() {
unsigned long pctime = 0L;
const unsigned long DEFAULT_TIME = 1357041600; // Jan 1 2013
if(Serial.find(TIME_HEADER)) {
pctime = Serial.parseInt();
return pctime;
if( pctime < DEFAULT_TIME) { // check the value is a valid time (greater than Jan 1 2013)
pctime = 0L; // return 0 to indicate that the time is not valid
return pctime;
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
// handle Rx Event (incoming I2C request/data)
if(Wire.available())
// grab command
cmd = Wire.readByte();
switch(cmd)
case WRITE:
addr = Wire.readByte(); // grab addr
while(Wire.available())
if(addr < MEM_LEN) // drop data beyond mem boundary
mem[addr++] = Wire.readByte(); // copy data to mem
Wire.readByte(); // drop data if mem full
case READ:
// handle Tx Event (outgoing I2C data)
switch(cmd)
case READ:
Wire.write(&mem[addr], MEM_LEN-addr); // fill Tx buffer (from addr location to end of mem)
// print I2C status
void print_i2c_status(void)
switch(Wire.status())
case I2C_WAITING: Serial.print("I2C waiting, no errors\n"); break;
case I2C_ADDR_NAK: Serial.print("Slave addr not acknowledged\n"); break;
case I2C_DATA_NAK: Serial.print("Slave data not acknowledged\n"); break;
case I2C_ARB_LOST: Serial.print("Bus Error: Arbitration Lost\n"); break;
default: Serial.print("I2C busy\n"); break;
Greetings!
Klaas
