Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 51 to 75 of 227
Thread: ILI9163C 128x128 TFT driver
  1. #51
    Hey guys! after messing around with the library and the code quite a bit I got the TFT working with an Arduino Nano. I have a eBay $4 knockoff Arduino Nano and the red version of the TFT.
    Pins : (TFT => Arduino)
    SCK => 13 (D13),
    SDA => 11 (D11),
    CS => 7 (D7),
    DC => 9 (D9),
    RST => 8 (D8),
    I also changed this line:
    TFT_ILI9163C tft = TFT_ILI9163C(__CS, __DC, 23);
    to
    TFT_ILI9163C tft = TFT_ILI9163C(__CS, __DC, __RST);
    and used
    #define __RST 8
    Other than those pins I just used 3v3 for power and LED (LED w/ resistor).
    I hope this helps anyone who is having issues getting it working! This setup should apply exactly the same for any Arduino with the ATmega328 chips (Nano, Uno, Pro Mini etc).
    Email me if you have any questions! Thanks!
  2. #52
    even though this thread is kinda old, i have got this library to work natively with the teensy audio library!
    portable media player anyone?
  3. #53
    Thank You - This new library port is appreciated.
    I wonder if there could possibly be a typo in your readme.md in the "Pay Attention to connections" section.
    You say
    "- Teensy 3 and LC cannot use any pin for CS and RS(DC) but should be choosen as follows:
    pins:2,6,9 or 10,15 or 20,13 for CS and RS."
    Since pin 13 is usually SPI SCK... Perhaps you intended to say ... "20,21 for CS and RS." ?????
  4. #54
    Indeed, you're right, will fix it once I get on my pc
  5. #55
    Senior Member sumotoy's Avatar
    Venezia, Italia
    421
    even though this thread is kinda old, i have ported this library to work natively with the teensy audio library! (example included)
    An PJRC Audio board compatible version, updated and faster version (even SPI transaction compatible) than old one exist already:
    Link
    UPDATE
    Looking your ported library, it's looks the same link above, bit per bit...
  6. #56
    well, somehow mine didn't work, i had to replace these functions:
    writecommand_cont
    writedata8_cont
    writedata16_cont
    writecommand_last
    writedata8_last
    writedata16_last
    note that i'm using the sd and tft on the same spi line.
  7. #57
    20,780
    Starting and stopping SPI transactions for each piece of data is probably much less efficient than starting before an entire command and ending afterwards.
  8. #58
    true, hough this was the only way it worked for me
  9. #59
    Venezia, Italia
    421
    Paul it's right, this is a very inefficent way, I'm actually fixing this as it should.
  10. #60
    Nov 2015
    Canada
    2
    Hey there,
    I'm trying to use your library with this LCD:
    https://www.digikey.ca/product-detai...3-T-ND/4429437
    It has a built in ILI9163C controller but the SPI isn't broken out to the flat flex cable.
    It just has the parallel interface available.
    I didn't see a way to enable parallel communication from the teensy so I was wondering if
    you think I could use your library with a shift register?
  11. #61
    Venezia, Italia
    421
    It's possible, you have to modify all SPI functions to parallel. Did you consider buy an SPI version from china market? Have seen as low as 3US time ago! Probably it cost 1 US more than a shift register...
  12. #62
    those spi based ones are as low as 3.19USD (free international shipment)
    ebay link: ebay.com/itm/141196897388
  13. #63
    Nov 2015
    Canada
    2
    I might try getting this one working. I didn't even realize the incompatibility when I researched the part; I just found lcd with controller 'x' and googled library for controller 'x' and thought, "perfect."
    Looking at the controller's datasheet was a bit of an eye opener for me.
    I'm definitely going to purchase an SPI version, it seems there's loads available from aliexpress as well: aliexpress.com/wholesale?catId=0&initiative_id=SB_20151126093518& SearchText=ILI9163C
  14. #64
    Jan 2016
    1
    Hi sumotoy,
    I am planning to get the TFT LCD and links it with a temperature sensor using an Arduino UNO. Can the LCD reads and displays the reading collected from the temperature sensor? I am not familiar with SPI screen, thanks lot if you could help.
  15. #65
    Unhappy
ID:	6963Click image for larger version.
    I use the same lcd, and the code you have posted here, But i have a problem my lcd is a part where the screen seems like it doesn't work, maybe i have a error with the code?
    Could you help me ?
    /* Binary sketch size: 10,188 bytes (of a 30,720 byte maximum)
       Tested and documented by M. Ray Burnette 20140812
       Compiled with Arduino 1.0.5 for Arduino Nano (clone)
       WARNING: direct GLCD wiring requires that Arduino run at 3.3 Volts maximum!
    #include <Adafruit_GFX.h>
    #include <TFT_ILI9163C.h>
    // All wiring required, only 3 defines for hardware SPI on 328P
    #define __DC 9
    #define __CS 10
    // MOSI --> (SDA) --> D11
    #define __RST 12
    // SCLK --> (SCK) --> D13
    // Color definitions
    #define	BLACK   0x0000
    #define	BLUE    0x001F
    #define	RED     0xF800
    #define	GREEN   0x07E0
    #define CYAN    0x07FF
    #define MAGENTA 0xF81F
    #define YELLOW  0xFFE0
    #define WHITE   0xFFFF
      tft.begin();
    void loop(){
      testLines(random(0x00ff,0xffff));
      testText();
      delay(5000);
    unsigned long testText() {
      tft.fillScreen();
      unsigned long start = micros();
      tft.setCursor(0, 0);
      tft.setTextColor(WHITE);
      tft.setTextSize(1);
      tft.println("Hello World!");
      tft.setTextColor(YELLOW);
      tft.setTextSize(2);
      tft.println(1234.56);
      tft.setTextColor(RED);
      tft.setTextSize(3);
      tft.println(0xDEAD, HEX);
      tft.println();
      tft.setTextColor(GREEN);
      tft.setTextSize(4);
      tft.println("Hello");
      return micros() - start;
      delay(5000);
    unsigned long testLines(uint16_t color) {
      tft.fillScreen();
      unsigned long start, t;
      int           x1, y1, x2, y2,
      w = tft.width(),
      h = tft.height();
      tft.fillScreen();
      x1 = y1 = 0;
      y2    = h - 1;
      start = micros();
      for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
      x2    = w - 1;
      for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
      t     = micros() - start; // fillScreen doesn't count against timing
      tft.fillScreen();
      x1    = w - 1;
      y1    = 0;
      y2    = h - 1;
      start = micros();
      x2    = 0;
      t    += micros() - start;
      tft.fillScreen();
      x1    = 0;
      y1    = h - 1;
      y2    = 0;
      start = micros();
      x2    = w - 1;
      tft.fillScreen();
      x1    = w - 1;
      y1    = h - 1;
      y2    = 0;
      start = micros();
      x2    = 0;
  16. #66
    I fixed editing the file TFT_ILI9163C_settings.h and I set #define __144_BLACK_PCB__//128x128
    That's all for me.
    Thank you again.
  17. #67
    Venezia, Italia
    421
    Ok, looks like a new strain of the Red PCB display it's spreading all over, it looks exact like the old Red PCB one, same text on the back but display has no text around border, it's a bit smaller than common one and it uses yellow pins (but this can change in future). It works in rotation 0,1 but NOT in 2,3 and I even not sure it uses ILI9163C!!! I got one of this display just today but many users complain not working well with current library in rotation 2,3, this is what I want discover in these days.
    Some vendor says it's a ST7735, most says ILI9163C and others II9165(!). If you have projects that needs rotation 2 or 3 please consider that I still try to figure out what controller it uses!!!
    UPDATE
    It doesn't like to use ILI9163C, many commands shows a small offset and react strange on slide, also a couple of commands does nothing (but RED,BLACK,BLUE and old version yes)
  18. #68
    Thank you sumotoy for your effort.
  19. #69
    Venezia, Italia
    421
    I solved the problem with thes new RED PCB Yellow Pin display, tomorrow (sunday 17,4,2016) I will post 1.0r6 that include this display and has an updated structure to support easily any type of incoming chinese strain.
  20. #70
    Exelent Sumotoy, let me know when you post the solution. Thanks
  21. #71
    Venezia, Italia
    421
    It's already done, it's a quite large update, there's still some minor tuning on color parameters (different between display's) but today I definetively release it.
  22. #72
    Great !!! thank you
  23. #73
    Venezia, Italia
    421
    Version 1.0r6 online, as always Teensy fly with this!
    Library mostly redesigned, now display's are in separate files and it's easy to handle any possible future strain.
    UPDATE
    Paul, can you use the latest 1.0r6 for future Teensyduino releases? It works much better and has support for the new yellow pin display, impossible with old version.
    GitHub page
  24. #74
    Thank's sumotoy I try the new library but I think maybe I have a error . What do you think ? See when make the scroll
  25. #75
    Venezia, Italia
    421
    Easy to fix, just need to know what display you have and if you used the scroll example of the library (and rotation 0?)...
