// Arduino demo sketch for testing RFM12B + ENC28J60 ethernet
// Listens for RF12 messages and displays valid messages on a webpage
// Memory usage exceeds 1K, so use Atmega328 or decrease history/buffers
// This sketch is derived from RF12eth.pde:
// May 2010, Andras Tucsni, http://opensource.org/licenses/mit-license.php
// The EtherCard library is based on Guido Socher's driver, licensed as GPL2.
// Based on Mods by jcw, 2010-05-20, Jeelabs.org
// Author: Glyn Hudson and Trystan lea openenergymonitor.org
// Date: 2/5/2011
// mods: working John Beale - May 5-7 2011
// based on info in http://tuxgraphics.org/electronics/200905/embedded-tcp-ip-stack.shtml
// 22 162 ms 162 ms 162 ms pepper.tuxgraphics.org [77.37.2.152]
#include <EtherCard.h>
#include <Ports.h>
#include <RF12.h> // needed to avoid a linker error :(
// ethernet interface mac address
// D4-28-B2-FF-E2-F6
static byte mymac[6] = { 0xd4,0x28,0xb2,0xff,0xe2,0xf6 };
// ethernet interface ip address
static byte myip[4] = { 192,168,10,140 };
// gateway ip address
static byte gwip[4] = { 192,168,10,1 };
// remote website ip address and port
static byte hisip[4] = { 184,106,153,149 }; // address of remote server: ThingSpeak
static word hisport = 80;
// fixed RF12 settings
#define MYNODE 31 //node ID of nanode
#define freq RF12_915MHZ //frequency
#define group 212 //network group
//Data Structure to be received
typedef struct { //data structure to be received, must be same as on transmitter
int sec;
int power;
int temp;
} Payload;
Payload measurement;
EtherCard eth;
MilliTimer requestTimer;
int test=1767;
unsigned long lastRead; // millisecond timestamp of last analog input reading
static BufferFiller bufill;
static byte buf[300]; // a very small tcp/ip buffer is enough here
char tsHeader[] PROGMEM = "GET /update?key=MySecretKey&field1=";
char host[] PROGMEM = "api.thingspeak.com";
// called to fill in a request to send out data to the client
static word my_datafill_cb (byte fd) {
BufferFiller bfill = eth.tcpOffset(buf);
bfill.emit_p(PSTR("$F$D&field2=$D&field3=$D"),
tsHeader,measurement.sec,measurement.power,measurement.temp);
bfill.emit_p(PSTR(" HTTP/1.1\r\n" "Host: $F\r\n" "\r\n"),host);
return bfill.position();
// called when the client request is complete
static byte my_result_cb (byte fd, byte status, word off, word len) {
Serial.print("<<< reply ");
Serial.println((int) status);
Serial.print((const char*) buf + off);
return 0;
void setup () {
Serial.begin(57600);
Serial.println("\n[EtherServe test]");
char ipaddr[18];
mk_net_str(ipaddr,myip,4,'.',10);
Serial.print("My IP: ");
Serial.println(ipaddr);
eth.spiInit();
eth.initialize(mymac);
eth.initIp(mymac, myip, 80);
eth.clientSetGwIp(gwip); // outgoing requests need a gateway
eth.clientSetServerIp(hisip);
rf12_initialize(MYNODE, freq,group);
delay(1000); // wait a second, just to be on safe side
pinMode(0,INPUT); // use pin 0 as (analog) input
requestTimer.set(1); // send first request as soon as possible
char okHeader[] PROGMEM =
"HTTP/1.0 200 OK\r\n"
"Content-Type: text/html\r\n"
"Pragma: no-cache\r\n"
static void homePage(BufferFiller& buf) {
buf.emit_p(PSTR("$F\r\n"
"<html><body>Analog Data<br>Time:$D Power:$D Temp:$D</body></html>"),
okHeader,measurement.sec,measurement.power,measurement.temp);
void loop () {
word len = eth.packetReceive(buf, sizeof buf);
word pos = eth.packetLoop(buf, len); // receive data from ENC28J60
if (pos) { // pos !=0 of there was a valid HTTP GET received
bufill = eth.tcpOffset(buf);
char* data = (char *) buf + pos;
Serial.println(data);
//receive buf hasn't been clobbered by reply yet
if (strncmp("GET / ", data, 6) == 0) homePage(bufill);
eth.httpServerReply(buf,bufill.position()); // send web page data
// Receive data from RFM12
//if (rf12_recvDone() && rf12_crc == 0 && (rf12_hdr & RF12_HDR_CTL) == 0 )
if (rf12_recvDone() && rf12_crc == 0 && rf12_len==sizeof(Payload) ) {
measurement=*(Payload*) rf12_data; //decode packet binary data into known data structure (same as Tx) http://jeelabs.org/2010/12/08/binary-packet-decoding-%E2%80%93-part-2/
Serial.print("Data: "); Serial.println(measurement.power);
if ((millis() - lastRead) > 1000) {
lastRead = millis();
measurement.sec = (int) (lastRead / 1000);
measurement.power = analogRead(0);
measurement.temp = analogRead(1);
if (eth.clientWaitingGw())
return;
if (requestTimer.poll(120000)) {
Serial.print(">>> PUT# ");
byte id = eth.clientTcpReq(my_result_cb, my_datafill_cb, hisport);
Serial.println((int) id);
