#include "LSM9DS0.h"
#include <MovingAverageFilter.h>
#include <Filters.h>
#define LSM9DS0_XM 0x1D // Would be 0x1E if SDO_XM is LOW
#define LSM9DS0_G 0x6B // Would be 0x6A if SDO_G is LOW
#define ACC_RUNAVG 5 // Number of Run average samples for Accelerometers
#define GYR_RUNAVG 5 // Number of Run average samples for Gyros
int INT1XM = 16; // INT1XM tells us when accel data is ready
int INT2XM = 17; // INT2XM tells us when mag data is ready
int DRDYG = 12; // DRDYG tells us when gyro data is ready
// global constants for 9 DoF fusion and AHRS (Attitude and Heading Reference System)
//For Mahoni
#define GyroMeasError PI * (40.0f / 180.0f) // gyroscope measurement error in rads/s (shown as 3 deg/s)
#define GyroMeasDrift PI * (1.0f / 180.0f) // gyroscope measurement drift in rad/s/s (shown as 0.0 deg/s/s)
// There is a tradeoff in the beta parameter between accuracy and response speed.
// In the original Madgwick study, beta of 0.041 (corresponding to GyroMeasError of 2.7 degrees/s) was found to give optimal accuracy.
// However, with this value, the LSM9SD0 response time is about 10 seconds to a stable initial quaternion.
// Subsequent changes also require a longish lag time to a stable output, not fast enough for a quadcopter or robot car!
// By increasing beta (GyroMeasError) by about a factor of fifteen, the response time constant is reduced to ~2 sec
// I haven't noticed any reduction in solution accuracy. This is essentially the I coefficient in a PID control sense;
// the bigger the feedback coefficient, the faster the solution converges, usually at the expense of accuracy.
// In any case, this is the free parameter in the Madgwick filtering and fusion scheme.
#define beta sqrt(3.0f / 4.0f) * GyroMeasError // compute beta
#define zeta sqrt(3.0f / 4.0f) * GyroMeasDrift // compute zeta, the other free parameter in the Madgwick scheme usually set to a small or zero value
#define Kp 2.0f * 5.0f //0.5*(2.0f * 0.5f)// 2.0f these are the free parameters in the Mahony filter and fusion scheme, Kp for proportional feedback, Ki for integral
#define Ki 0.0f //0.5*(2.0f * 0.1f) //0.005f
float eInt[3] = {0.0f, 0.0f, 0.0f};
volatile float integralFBx, integralFBy, integralFBz;
float sampleFreq=500;
MovingAverageFilter gx_avg(GYR_RUNAVG);
MovingAverageFilter gy_avg(GYR_RUNAVG);
MovingAverageFilter gz_avg(GYR_RUNAVG);
MovingAverageFilter ax_avg(ACC_RUNAVG);
MovingAverageFilter ay_avg(ACC_RUNAVG);
MovingAverageFilter az_avg(ACC_RUNAVG);
FilterOnePole high_pass_gx( HIGHPASS, 0.5 );
FilterOnePole high_pass_gy( HIGHPASS, 0.5 );
FilterOnePole high_pass_gz( HIGHPASS, 0.5 );
FilterTwoPole high_pass_gx( HIGHPASS_BESSEL, 0.2 );
FilterTwoPole high_pass_gy( HIGHPASS_BESSEL, 0.2 );
FilterTwoPole high_pass_gz( HIGHPASS_BESSEL, 0.2 );
static const int16_t dec_tbl[37][73] = \
{150,145,140,135,130,125,120,115,110,105,100,95,90,85,80,75,70,65,60,55,50,45,40,35,30,25,20,15,10,5,0,-4,-9,-14,-19,-24,-29,-34,-39,-44,-49,-54,-59,-64,-69,-74,-79,-84,-89,-94,-99,104,109,114,119,124,129,134,139,144,149,154,159,164,169,174,179,175,170,165,160,155,150}, \
{143,137,131,126,120,115,110,105,100,95,90,85,80,75,71,66,62,57,53,48,44,39,35,31,27,22,18,14,9,5,1,-3,-7,-11,-16,-20,-25,-29,-34,-38,-43,-47,-52,-57,-61,-66,-71,-76,-81,-86,-91,-96,101,107,112,117,123,128,134,140,146,151,157,163,169,175,178,172,166,160,154,148,143}, \
{130,124,118,112,107,101,96,92,87,82,78,74,70,65,61,57,54,50,46,42,38,34,31,27,23,19,16,12,8,4,1,-2,-6,-10,-14,-18,-22,-26,-30,-34,-38,-43,-47,-51,-56,-61,-65,-70,-75,-79,-84,-89,-94,100,105,111,116,122,128,135,141,148,155,162,170,177,174,166,159,151,144,137,130}, \
{111,104,99,94,89,85,81,77,73,70,66,63,60,56,53,50,46,43,40,36,33,30,26,23,20,16,13,10,6,3,0,-3,-6,-9,-13,-16,-20,-24,-28,-32,-36,-40,-44,-48,-52,-57,-61,-65,-70,-74,-79,-84,-88,-93,-98,103,109,115,121,128,135,143,152,162,172,176,165,154,144,134,125,118,111}, \
{85,81,77,74,71,68,65,63,60,58,56,53,51,49,46,43,41,38,35,32,29,26,23,19,16,13,10,7,4,1,-1,-3,-6,-9,-13,-16,-19,-23,-26,-30,-34,-38,-42,-46,-50,-54,-58,-62,-66,-70,-74,-78,-83,-87,-91,-95,100,105,110,117,124,133,144,159,178,160,141,125,112,103,96,90,85 }, \
{62,60,58,57,55,54,52,51,50,48,47,46,44,42,41,39,36,34,31,28,25,22,19,16,13,10,7,4,2,0,-3,-5,-8,-10,-13,-16,-19,-22,-26,-29,-33,-37,-41,-45,-49,-53,-56,-60,-64,-67,-70,-74,-77,-80,-83,-86,-89,-91,-94,-97,101,105,111,130,109,84,77,74,71,68,66,64,62 }, \
{46,46,45,44,44,43,42,42,41,41,40,39,38,37,36,35,33,31,28,26,23,20,16,13,10,7,4,1,-1,-3,-5,-7,-9,-12,-14,-16,-19,-22,-26,-29,-33,-36,-40,-44,-48,-51,-55,-58,-61,-64,-66,-68,-71,-72,-74,-74,-75,-74,-72,-68,-61,-48,-25,2,22,33,40,43,45,46,47,46,46 }, \
{36,36,36,36,36,35,35,35,35,34,34,34,34,33,32,31,30,28,26,23,20,17,14,10,6,3,0,-2,-4,-7,-9,-10,-12,-14,-15,-17,-20,-23,-26,-29,-32,-36,-40,-43,-47,-50,-53,-56,-58,-60,-62,-63,-64,-64,-63,-62,-59,-55,-49,-41,-30,-17,-4,6,15,22,27,31,33,34,35,36,36 }, \
{30,30,30,30,30,30,30,29,29,29,29,29,29,29,29,28,27,26,24,21,18,15,11,7,3,0,-3,-6,-9,-11,-12,-14,-15,-16,-17,-19,-21,-23,-26,-29,-32,-35,-39,-42,-45,-48,-51,-53,-55,-56,-57,-57,-56,-55,-53,-49,-44,-38,-31,-23,-14,-6,0,7,13,17,21,24,26,27,29,29,30 }, \
{25,25,26,26,26,25,25,25,25,25,25,25,25,26,25,25,24,23,21,19,16,12,8,4,0,-3,-7,-10,-13,-15,-16,-17,-18,-19,-20,-21,-22,-23,-25,-28,-31,-34,-37,-40,-43,-46,-48,-49,-50,-51,-51,-50,-48,-45,-42,-37,-32,-26,-19,-13,-7,-1,3,7,11,14,17,19,21,23,24,25,25 }, \
{21,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,21,20,18,16,13,9,5,1,-3,-7,-11,-14,-17,-18,-20,-21,-21,-22,-22,-22,-23,-23,-25,-27,-29,-32,-35,-37,-40,-42,-44,-45,-45,-45,-44,-42,-40,-36,-32,-27,-22,-17,-12,-7,-3,0,3,7,9,12,14,16,18,19,20,21,21 }, \
{18,19,19,19,19,19,19,19,19,19,19,19,19,19,19,19,18,17,16,14,10,7,2,-1,-6,-10,-14,-17,-19,-21,-22,-23,-24,-24,-24,-24,-23,-23,-23,-24,-26,-28,-30,-33,-35,-37,-38,-39,-39,-38,-36,-34,-31,-28,-24,-19,-15,-10,-6,-3,0,1,4,6,8,10,12,14,15,16,17,18,18 }, \
{16,16,17,17,17,17,17,17,17,17,17,16,16,16,16,16,16,15,13,11,8,4,0,-4,-9,-13,-16,-19,-21,-23,-24,-25,-25,-25,-25,-24,-23,-21,-20,-20,-21,-22,-24,-26,-28,-30,-31,-32,-31,-30,-29,-27,-24,-21,-17,-13,-9,-6,-3,-1,0,2,4,5,7,9,10,12,13,14,15,16,16 }, \
{14,14,14,15,15,15,15,15,15,15,14,14,14,14,14,14,13,12,11,9,5,2,-2,-6,-11,-15,-18,-21,-23,-24,-25,-25,-25,-25,-24,-22,-21,-18,-16,-15,-15,-15,-17,-19,-21,-22,-24,-24,-24,-23,-22,-20,-18,-15,-12,-9,-5,-3,-1,0,1,2,4,5,6,8,9,10,11,12,13,14,14 }, \
{12,13,13,13,13,13,13,13,13,13,13,13,12,12,12,12,11,10,9,6,3,0,-4,-8,-12,-16,-19,-21,-23,-24,-24,-24,-24,-23,-22,-20,-17,-15,-12,-10,-9,-9,-10,-12,-13,-15,-17,-17,-18,-17,-16,-15,-13,-11,-8,-5,-3,-1,0,1,1,2,3,4,6,7,8,9,10,11,12,12,12 }, \
{11,11,11,11,11,12,12,12,12,12,11,11,11,11,11,10,10,9,7,5,2,-1,-5,-9,-13,-17,-20,-22,-23,-23,-23,-23,-22,-20,-18,-16,-14,-11,-9,-6,-5,-4,-5,-6,-8,-9,-11,-12,-12,-12,-12,-11,-9,-8,-6,-3,-1,0,0,1,1,2,3,4,5,6,7,8,9,10,11,11,11 }, \
{10,10,10,10,10,10,10,10,10,10,10,10,10,10,9,9,9,7,6,3,0,-3,-6,-10,-14,-17,-20,-21,-22,-22,-22,-21,-19,-17,-15,-13,-10,-8,-6,-4,-2,-2,-2,-2,-4,-5,-7,-8,-8,-9,-8,-8,-7,-5,-4,-2,0,0,1,1,1,2,2,3,4,5,6,7,8,9,10,10,10 }, \
{9,9,9,9,9,9,9,10,10,9,9,9,9,9,9,8,8,6,5,2,0,-4,-7,-11,-15,-17,-19,-21,-21,-21,-20,-18,-16,-14,-12,-10,-8,-6,-4,-2,-1,0,0,0,-1,-2,-4,-5,-5,-6,-6,-5,-5,-4,-3,-1,0,0,1,1,1,1,2,3,3,5,6,7,8,8,9,9,9 }, \
{9,9,9,9,9,9,9,9,9,9,9,9,8,8,8,8,7,5,4,1,-1,-5,-8,-12,-15,-17,-19,-20,-20,-19,-18,-16,-14,-11,-9,-7,-5,-4,-2,-1,0,0,1,1,0,0,-2,-3,-3,-4,-4,-4,-3,-3,-2,-1,0,0,0,0,0,1,1,2,3,4,5,6,7,8,8,9,9 }, \
{9,9,9,8,8,8,9,9,9,9,9,8,8,8,8,7,6,5,3,0,-2,-5,-9,-12,-15,-17,-18,-19,-19,-18,-16,-14,-12,-9,-7,-5,-4,-2,-1,0,0,1,1,1,1,0,0,-1,-2,-2,-3,-3,-2,-2,-1,-1,0,0,0,0,0,0,0,1,2,3,4,5,6,7,8,8,9 }, \
{8,8,8,8,8,8,9,9,9,9,9,9,8,8,8,7,6,4,2,0,-3,-6,-9,-12,-15,-17,-18,-18,-17,-16,-14,-12,-10,-8,-6,-4,-2,-1,0,0,1,2,2,2,2,1,0,0,-1,-1,-1,-2,-2,-1,-1,0,0,0,0,0,0,0,0,0,1,2,3,4,5,6,7,8,8 }, \
{8,8,8,8,9,9,9,9,9,9,9,9,9,8,8,7,5,3,1,-1,-4,-7,-10,-13,-15,-16,-17,-17,-16,-15,-13,-11,-9,-6,-5,-3,-2,0,0,0,1,2,2,2,2,1,1,0,0,0,-1,-1,-1,-1,-1,0,0,0,0,-1,-1,-1,-1,-1,0,0,1,3,4,5,7,7,8 }, \
{8,8,9,9,9,9,10,10,10,10,10,10,10,9,8,7,5,3,0,-2,-5,-8,-11,-13,-15,-16,-16,-16,-15,-13,-12,-10,-8,-6,-4,-2,-1,0,0,1,2,2,3,3,2,2,1,0,0,0,0,0,0,0,0,0,0,-1,-1,-2,-2,-2,-2,-2,-1,0,0,1,3,4,6,7,8 }, \
{7,8,9,9,9,10,10,11,11,11,11,11,10,10,9,7,5,3,0,-2,-6,-9,-11,-13,-15,-16,-16,-15,-14,-13,-11,-9,-7,-5,-3,-2,0,0,1,1,2,3,3,3,3,2,2,1,1,0,0,0,0,0,0,0,-1,-1,-2,-3,-3,-4,-4,-4,-3,-2,-1,0,1,3,5,6,7 }, \
{6,8,9,9,10,11,11,12,12,12,12,12,11,11,9,7,5,2,0,-3,-7,-10,-12,-14,-15,-16,-15,-15,-13,-12,-10,-8,-7,-5,-3,-1,0,0,1,2,2,3,3,4,3,3,3,2,2,1,1,1,0,0,0,0,-1,-2,-3,-4,-4,-5,-5,-5,-5,-4,-2,-1,0,2,3,5,6 }, \
{6,7,8,10,11,12,12,13,13,14,14,13,13,11,10,8,5,2,0,-4,-8,-11,-13,-15,-16,-16,-16,-15,-13,-12,-10,-8,-6,-5,-3,-1,0,0,1,2,3,3,4,4,4,4,4,3,3,3,2,2,1,1,0,0,-1,-2,-3,-5,-6,-7,-7,-7,-6,-5,-4,-3,-1,0,2,4,6 }, \
{5,7,8,10,11,12,13,14,15,15,15,14,14,12,11,8,5,2,-1,-5,-9,-12,-14,-16,-17,-17,-16,-15,-14,-12,-11,-9,-7,-5,-3,-1,0,0,1,2,3,4,4,5,5,5,5,5,5,4,4,3,3,2,1,0,-1,-2,-4,-6,-7,-8,-8,-8,-8,-7,-6,-4,-2,0,1,3,5 }, \
{4,6,8,10,12,13,14,15,16,16,16,16,15,13,11,9,5,2,-2,-6,-10,-13,-16,-17,-18,-18,-17,-16,-15,-13,-11,-9,-7,-5,-4,-2,0,0,1,3,3,4,5,6,6,7,7,7,7,7,6,5,4,3,2,0,-1,-3,-5,-7,-8,-9,-10,-10,-10,-9,-7,-5,-4,-1,0,2,4 }, \
{4,6,8,10,12,14,15,16,17,18,18,17,16,15,12,9,5,1,-3,-8,-12,-15,-18,-19,-20,-20,-19,-18,-16,-15,-13,-11,-8,-6,-4,-2,-1,0,1,3,4,5,6,7,8,9,9,9,9,9,9,8,7,5,3,1,-1,-3,-6,-8,-10,-11,-12,-12,-11,-10,-9,-7,-5,-2,0,1,4 }, \
{4,6,8,11,13,15,16,18,19,19,19,19,18,16,13,10,5,0,-5,-10,-15,-18,-21,-22,-23,-22,-22,-20,-18,-17,-14,-12,-10,-8,-5,-3,-1,0,1,3,5,6,8,9,10,11,12,12,13,12,12,11,9,7,5,2,0,-3,-6,-9,-11,-12,-13,-13,-12,-11,-10,-8,-6,-3,-1,1,4 }, \
{3,6,9,11,14,16,17,19,20,21,21,21,19,17,14,10,4,-1,-8,-14,-19,-22,-25,-26,-26,-26,-25,-23,-21,-19,-17,-14,-12,-9,-7,-4,-2,0,1,3,5,7,9,11,13,14,15,16,16,16,16,15,13,10,7,4,0,-3,-7,-10,-12,-14,-15,-14,-14,-12,-11,-9,-6,-4,-1,1,3 }, \
{4,6,9,12,14,17,19,21,22,23,23,23,21,19,15,9,2,-5,-13,-20,-25,-28,-30,-31,-31,-30,-29,-27,-25,-22,-20,-17,-14,-11,-9,-6,-3,0,1,4,6,9,11,13,15,17,19,20,21,21,21,20,18,15,11,6,2,-2,-7,-11,-13,-15,-16,-16,-15,-13,-11,-9,-7,-4,-1,1,4 }, \
{4,7,10,13,15,18,20,22,24,25,25,25,23,20,15,7,-2,-12,-22,-29,-34,-37,-38,-38,-37,-36,-34,-31,-29,-26,-23,-20,-17,-13,-10,-7,-4,-1,2,5,8,11,13,16,18,21,23,24,26,26,26,26,24,21,17,12,5,0,-6,-10,-14,-16,-16,-16,-15,-14,-12,-10,-7,-4,-1,1,4 }, \
{4,7,10,13,16,19,22,24,26,27,27,26,24,19,11,-1,-15,-28,-37,-43,-46,-47,-47,-45,-44,-41,-39,-36,-32,-29,-26,-22,-19,-15,-11,-8,-4,-1,2,5,9,12,15,19,22,24,27,29,31,33,33,33,32,30,26,21,14,6,0,-6,-11,-14,-15,-16,-15,-14,-12,-9,-7,-4,-1,1,4 }, \
{6,9,12,15,18,21,23,25,27,28,27,24,17,4,-14,-34,-49,-56,-60,-60,-60,-58,-56,-53,-50,-47,-43,-40,-36,-32,-28,-25,-21,-17,-13,-9,-5,-1,2,6,10,14,17,21,24,28,31,34,37,39,41,42,43,43,41,38,33,25,17,8,0,-4,-8,-10,-10,-10,-8,-7,-4,-2,0,3,6 }, \
{22,24,26,28,30,32,33,31,23,-18,-81,-96,-99,-98,-95,-93,-89,-86,-82,-78,-74,-70,-66,-62,-57,-53,-49,-44,-40,-36,-32,-27,-23,-19,-14,-10,-6,-1,2,6,10,15,19,23,27,31,35,38,42,45,49,52,55,57,60,61,63,63,62,61,57,53,47,40,33,28,23,21,19,19,19,20,22 }, \
{168,173,178,176,171,166,161,156,151,146,141,136,131,126,121,116,111,106,101,-96,-91,-86,-81,-76,-71,-66,-61,-56,-51,-46,-41,-36,-31,-26,-21,-16,-11,-6,-1,3,8,13,18,23,28,33,38,43,48,53,58,63,68,73,78,83,88,93,98,103,108,113,118,123,128,133,138,143,148,153,158,163,168}, \
float deltat = 0.0f; // integration interval for both filter schemes
uint32_t lastUpdate = 0; // used to calculate integration interval
uint32_t now = 0; // used to calculate integration interval
//float abias[3] = {0, 0, 0}, gbias[3] = {-0.7, -6, -4};
float abias[3] = {0, 0, 0}, gbias[3] = {0, 0, 0};
LSM9DS0 dof(MODE_I2C, LSM9DS0_G, LSM9DS0_XM);
//Adafruit_BMP280 bme;
/// \fn get_declination
/// \brief Return declination from gps coordinates \n
uint32_t FreeMem(){ // for Teensy 3.0
uint32_t stackTop;
uint32_t heapTop;
// current position of the stack.
stackTop = (uint32_t) &stackTop;
// current position of heap.
void* hTop = malloc(1);
heapTop = (uint32_t) hTop;
free(hTop);
// The difference is (approximately) the free, available ram.
return stackTop - heapTop;
float get_declination(float lat, float lon)
int16_t decSW, decSE, decNW, decNE, lonmin, latmin;
float decmin, decmax;
uint8_t latmin_index, lonmin_index;
latmin = floor(lat/5)*5;
lonmin = floor(lon/5)*5;
latmin_index= (90+latmin)/5;
lonmin_index= (180+lonmin)/5;
decSW = dec_tbl[latmin_index][lonmin_index];
decSE = dec_tbl[latmin_index][lonmin_index+1];
decNE = dec_tbl[latmin_index+1][lonmin_index+1];
decNW = dec_tbl[latmin_index+1][lonmin_index];
decmin = (lon - lonmin) / 5 * (decSE - decSW) + decSW;
decmax = (lon - lonmin) / 5 * (decNE - decNW) + decNW;
return (lat - latmin) / 5 * (decmax - decmin) + decmin;
/// \fn MahonyQuaternionUpdate
/// \brief Return quaternions from 9 dof data \n
void MahonyQuaternionUpdate(float ax, float ay, float az, float gx, float gy, float gz, float mx, float my, float mz)
float q1 = q[0], q2 = q[1], q3 = q[2], q4 = q[3]; // short name local variable for readability
float norm;
float hx, hy, bx, bz;
float vx, vy, vz, wx, wy, wz;
float ex, ey, ez;
float pa, pb, pc;
// Auxiliary variables to avoid repeated arithmetic
float q1q1 = q1 * q1;
float q1q2 = q1 * q2;
float q1q3 = q1 * q3;
float q1q4 = q1 * q4;
float q2q2 = q2 * q2;
float q2q3 = q2 * q3;
float q2q4 = q2 * q4;
float q3q3 = q3 * q3;
float q3q4 = q3 * q4;
float q4q4 = q4 * q4;
// Normalise accelerometer measurement
norm = invSqrt(ax * ax + ay * ay + az * az);
if (norm == 0.0f) return; // handle NaN
norm = 1.0f / norm; // use reciprocal for division
ax *= norm;
ay *= norm;
az *= norm;
// Normalise magnetometer measurement
norm = invSqrt(mx * mx + my * my + mz * mz);
mx *= norm;
my *= norm;
mz *= norm;
// Reference direction of Earth's magnetic field
hx = 2.0f * mx * (0.5f - q3q3 - q4q4) + 2.0f * my * (q2q3 - q1q4) + 2.0f * mz * (q2q4 + q1q3);
hy = 2.0f * mx * (q2q3 + q1q4) + 2.0f * my * (0.5f - q2q2 - q4q4) + 2.0f * mz * (q3q4 - q1q2);
bx = sqrt((hx * hx) + (hy * hy));
bz = 2.0f * mx * (q2q4 - q1q3) + 2.0f * my * (q3q4 + q1q2) + 2.0f * mz * (0.5f - q2q2 - q3q3);
// Estimated direction of gravity and magnetic field
vx = 2.0f * (q2q4 - q1q3);
vy = 2.0f * (q1q2 + q3q4);
vz = q1q1 - q2q2 - q3q3 + q4q4;
wx = 2.0f * bx * (0.5f - q3q3 - q4q4) + 2.0f * bz * (q2q4 - q1q3);
wy = 2.0f * bx * (q2q3 - q1q4) + 2.0f * bz * (q1q2 + q3q4);
wz = 2.0f * bx * (q1q3 + q2q4) + 2.0f * bz * (0.5f - q2q2 - q3q3);
// Error is cross product between estimated direction and measured direction of gravity
ex = (ay * vz - az * vy) + (my * wz - mz * wy);
ey = (az * vx - ax * vz) + (mz * wx - mx * wz);
ez = (ax * vy - ay * vx) + (mx * wy - my * wx);
if (Ki > 0.0f)
eInt[0] += ex; // accumulate integral error
eInt[1] += ey;
eInt[2] += ez;
eInt[0] = 0.0f; // prevent integral wind up
eInt[1] = 0.0f;
eInt[2] = 0.0f;
// Apply feedback terms
gx = gx + Kp * ex + Ki * eInt[0];
gy = gy + Kp * ey + Ki * eInt[1];
gz = gz + Kp * ez + Ki * eInt[2];
// Integrate rate of change of quaternion
pa = q2;
pb = q3;
pc = q4;
q1 = q1 + (-q2 * gx - q3 * gy - q4 * gz) * (0.5f * deltat);
q2 = pa + (q1 * gx + pb * gz - pc * gy) * (0.5f * deltat);
q3 = pb + (q1 * gy - pa * gz + pc * gx) * (0.5f * deltat);
q4 = pc + (q1 * gz + pa * gy - pb * gx) * (0.5f * deltat);
// Normalise quaternion
norm = sqrt(q1 * q1 + q2 * q2 + q3 * q3 + q4 * q4);
norm = 1.0f / norm;
q[0] = q1 * norm;
q[1] = q2 * norm;
q[2] = q3 * norm;
q[3] = q4 * norm;
/// \fn MadgwickQuaternionUpdate
void AHRSupdate(float gx, float gy, float gz, float ax, float ay, float az, float mx, float my, float mz) {
float recipNorm;
float q0 = q[0], q1 = q[1], q2 = q[2], q3 = q[3];
float q0q0, q0q1, q0q2, q0q3, q1q1, q1q2, q1q3, q2q2, q2q3, q3q3;
float halfex = 0.0f, halfey = 0.0f, halfez = 0.0f;
float qa, qb, qc;
q0q0 = q0 * q0;
q0q1 = q0 * q1;
q0q2 = q0 * q2;
q0q3 = q0 * q3;
q1q1 = q1 * q1;
q1q2 = q1 * q2;
q1q3 = q1 * q3;
q2q2 = q2 * q2;
q2q3 = q2 * q3;
q3q3 = q3 * q3;
if((mx != 0.0f) && (my != 0.0f) && (mz != 0.0f)) {
// Use magnetometer measurement only when valid (avoids NaN in magnetometer normalisation)
float halfwx, halfwy, halfwz;
recipNorm = invSqrt(mx * mx + my * my + mz * mz);
mx *= recipNorm;
my *= recipNorm;
mz *= recipNorm;
hx = 2.0f * (mx * (0.5f - q2q2 - q3q3) + my * (q1q2 - q0q3) + mz * (q1q3 + q0q2));
hy = 2.0f * (mx * (q1q2 + q0q3) + my * (0.5f - q1q1 - q3q3) + mz * (q2q3 - q0q1));
bx = sqrt(hx * hx + hy * hy);
bz = 2.0f * (mx * (q1q3 - q0q2) + my * (q2q3 + q0q1) + mz * (0.5f - q1q1 - q2q2));
// Estimated direction of magnetic field
halfwx = bx * (0.5f - q2q2 - q3q3) + bz * (q1q3 - q0q2);
halfwy = bx * (q1q2 - q0q3) + bz * (q0q1 + q2q3);
halfwz = bx * (q0q2 + q1q3) + bz * (0.5f - q1q1 - q2q2);
// Error is sum of cross product between estimated direction and measured direction of field vectors
halfex = (my * halfwz - mz * halfwy);
halfey = (mz * halfwx - mx * halfwz);
halfez = (mx * halfwy - my * halfwx);
if((ax != 0.0f) && (ay != 0.0f) && (az != 0.0f)) {
float halfvx, halfvy, halfvz;
recipNorm = invSqrt(ax * ax + ay * ay + az * az);
ax *= recipNorm;
ay *= recipNorm;
az *= recipNorm;
halfvx = q1q3 - q0q2;
halfvy = q0q1 + q2q3;
halfvz = q0q0 - 0.5f + q3q3;
halfex += (ay * halfvz - az * halfvy);
halfey += (az * halfvx - ax * halfvz);
halfez += (ax * halfvy - ay * halfvx);
if(halfex != 0.0f && halfey != 0.0f && halfez != 0.0f) {
// Compute and apply integral feedback if enabled
if(Ki > 0.0f) {
integralFBx += Ki * halfex * (deltat); // integral error scaled by Ki
integralFBy += Ki * halfey * (deltat);
integralFBz += Ki * halfez * (deltat);
gx += integralFBx; // apply integral feedback
gy += integralFBy;
gz += integralFBz;
else {
integralFBx = 0.0f; // prevent integral windup
integralFBy = 0.0f;
integralFBz = 0.0f;
// Apply proportional feedback
gx += Kp * halfex;
gy += Kp * halfey;
gz += Kp * halfez;
gx *= (0.5f * (deltat)); // pre-multiply common factors
gy *= (0.5f * (deltat));
gz *= (0.5f * (deltat));
qa = q0;
qb = q1;
qc = q2;
q0 += (-qb * gx - qc * gy - q3 * gz);
q1 += (qa * gx + qc * gz - q3 * gy);
q2 += (qa * gy - qb * gz + q3 * gx);
q3 += (qa * gz + qb * gy - qc * gx);
recipNorm = invSqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3);
q0 *= recipNorm;
q1 *= recipNorm;
q2 *= recipNorm;
q3 *= recipNorm;
q[0] = q0;
q[1] = q1;
q[2] = q2;
q[3] = q3;
void MadgwickQuaternionUpdate(float ax, float ay, float az, float gx, float gy, float gz, float mx, float my, float mz)
float norm;
float hx, hy, _2bx, _2bz;
float s1, s2, s3, s4;
float qDot1, qDot2, qDot3, qDot4;
float _2q1mx;
float _2q1my;
float _2q1mz;
float _2q2mx;
float _4bx;
float _4bz;
float _2q1 = 2.0f * q1;
float _2q2 = 2.0f * q2;
float _2q3 = 2.0f * q3;
float _2q4 = 2.0f * q4;
float _2q1q3 = 2.0f * q1 * q3;
float _2q3q4 = 2.0f * q3 * q4;
norm = sqrt(ax * ax + ay * ay + az * az);
norm = 1.0f/norm;
ax *= norm;
ay *= norm;
az *= norm;
norm = sqrt(mx * mx + my * my + mz * mz);
norm = 1.0f/norm;
mx *= norm;
my *= norm;
mz *= norm;
_2q1mx = 2.0f * q1 * mx;
_2q1my = 2.0f * q1 * my;
_2q1mz = 2.0f * q1 * mz;
_2q2mx = 2.0f * q2 * mx;
hx = mx * q1q1 - _2q1my * q4 + _2q1mz * q3 + mx * q2q2 + _2q2 * my * q3 + _2q2 * mz * q4 - mx * q3q3 - mx * q4q4;
hy = _2q1mx * q4 + my * q1q1 - _2q1mz * q2 + _2q2mx * q3 - my * q2q2 + my * q3q3 + _2q3 * mz * q4 - my * q4q4;
_2bx = sqrt(hx * hx + hy * hy);
_2bz = -_2q1mx * q3 + _2q1my * q2 + mz * q1q1 + _2q2mx * q4 - mz * q2q2 + _2q3 * my * q4 - mz * q3q3 + mz * q4q4;
_4bx = 2.0f * _2bx;
_4bz = 2.0f * _2bz;
// Gradient decent algorithm corrective step
s1 = -_2q3 * (2.0f * q2q4 - _2q1q3 - ax) + _2q2 * (2.0f * q1q2 + _2q3q4 - ay) - _2bz * q3 * (_2bx * (0.5f - q3q3 - q4q4) + _2bz * (q2q4 - q1q3) - mx) + (-_2bx * q4 + _2bz * q2) * (_2bx * (q2q3 - q1q4) + _2bz * (q1q2 + q3q4) - my) + _2bx * q3 * (_2bx * (q1q3 + q2q4) + _2bz * (0.5f - q2q2 - q3q3) - mz);
s2 = _2q4 * (2.0f * q2q4 - _2q1q3 - ax) + _2q1 * (2.0f * q1q2 + _2q3q4 - ay) - 4.0f * q2 * (1.0f - 2.0f * q2q2 - 2.0f * q3q3 - az) + _2bz * q4 * (_2bx * (0.5f - q3q3 - q4q4) + _2bz * (q2q4 - q1q3) - mx) + (_2bx * q3 + _2bz * q1) * (_2bx * (q2q3 - q1q4) + _2bz * (q1q2 + q3q4) - my) + (_2bx * q4 - _4bz * q2) * (_2bx * (q1q3 + q2q4) + _2bz * (0.5f - q2q2 - q3q3) - mz);
s3 = -_2q1 * (2.0f * q2q4 - _2q1q3 - ax) + _2q4 * (2.0f * q1q2 + _2q3q4 - ay) - 4.0f * q3 * (1.0f - 2.0f * q2q2 - 2.0f * q3q3 - az) + (-_4bx * q3 - _2bz * q1) * (_2bx * (0.5f - q3q3 - q4q4) + _2bz * (q2q4 - q1q3) - mx) + (_2bx * q2 + _2bz * q4) * (_2bx * (q2q3 - q1q4) + _2bz * (q1q2 + q3q4) - my) + (_2bx * q1 - _4bz * q3) * (_2bx * (q1q3 + q2q4) + _2bz * (0.5f - q2q2 - q3q3) - mz);
s4 = _2q2 * (2.0f * q2q4 - _2q1q3 - ax) + _2q3 * (2.0f * q1q2 + _2q3q4 - ay) + (-_4bx * q4 + _2bz * q2) * (_2bx * (0.5f - q3q3 - q4q4) + _2bz * (q2q4 - q1q3) - mx) + (-_2bx * q1 + _2bz * q3) * (_2bx * (q2q3 - q1q4) + _2bz * (q1q2 + q3q4) - my) + _2bx * q2 * (_2bx * (q1q3 + q2q4) + _2bz * (0.5f - q2q2 - q3q3) - mz);
norm = sqrt(s1 * s1 + s2 * s2 + s3 * s3 + s4 * s4); // normalise step magnitude
norm = 1.0f/norm;
s1 *= norm;
s2 *= norm;
s3 *= norm;
s4 *= norm;
// Compute rate of change of quaternion
qDot1 = 0.5f * (-q2 * gx - q3 * gy - q4 * gz) - beta * s1;
qDot2 = 0.5f * (q1 * gx + q3 * gz - q4 * gy) - beta * s2;
qDot3 = 0.5f * (q1 * gy - q2 * gz + q4 * gx) - beta * s3;
qDot4 = 0.5f * (q1 * gz + q2 * gy - q3 * gx) - beta * s4;
// Integrate to yield quaternion
q1 += qDot1 * deltat;
q2 += qDot2 * deltat;
q3 += qDot3 * deltat;
q4 += qDot4 * deltat;
norm = sqrt(q1 * q1 + q2 * q2 + q3 * q3 + q4 * q4); // normalise quaternion
norm = 1.0f/norm;
q[0] = q1 * norm;
q[1] = q2 * norm;
q[2] = q3 * norm;
q[3] = q4 * norm;
/// \fn sensor_9dof_configure
/// \brief Configure 9dof sensor \n
/// \detailed
/// 1. Set 4G diapason for accels \n
/// 2. Set 245 degree per second diapason for gyros \n
/// 3. Set 2 Gauss diapason for magnetometers \n
void sensor_9dof_configure()
pinMode(INT1XM, INPUT);
pinMode(INT2XM, INPUT);
pinMode(DRDYG, INPUT);
dof.begin();
dof.setAccelScale(dof.A_SCALE_6G);
dof.setGyroScale(dof.G_SCALE_500DPS);
dof.setMagScale(dof.M_SCALE_2GS);
// Set output data rates
dof.setAccelODR(dof.A_ODR_800); // Set accelerometer update rate at 100 Hz
dof.setAccelABW(dof.A_ABW_50); // Choose lowest filter setting for low noise 380 Hz (bandwidth 20, 25, 50, 100 Hz), or 760 Hz (bandwidth 30, 35, 50, 100 Hz)
dof.setGyroODR(dof.G_ODR_95_BW_125); // Set gyro update rate to 190 Hz with the smallest bandwidth for low noise
dof.setMagODR(dof.M_ODR_100); // Set magnetometer to update every 80 ms
dof.calLSM9DS0(gbias, abias);
/// \fn
/// \brief Scale accels data by factor 1.5 (see datasheet) \n
void scale_accel_16g(){ //need to set abias
dof.ax = 1.5 * dof.ax;
dof.ay = 1.5 * dof.ay;
dof.az = 1.5 * dof.az;
/// \fn sensor_9dof_read
/// \brief Read 9dof sensor \n
void sensor_9dof_read()
float declination;
static float prev_yaw;
float gx_q, gy_q, gz_q;
if(digitalRead(DRDYG)){
dof.readGyro(); // Read raw gyro data
gx = dof.calcGyro(dof.gx) - gbias[0]; // Convert to degrees per seconds
gy = dof.calcGyro(dof.gy) - gbias[1];
gz = dof.calcGyro(dof.gz) - gbias[2];
gx = high_pass_gx.input(gx_avg.process(dof.calcGyro(dof.gx) - gbias[0]));
gy = high_pass_gy.input(gy_avg.process(dof.calcGyro(dof.gy) - gbias[1]));
gz = high_pass_gz.input(gz_avg.process(dof.calcGyro(dof.gz) - gbias[2]));
if(digitalRead(INT1XM)){
dof.readAccel(); // Read raw accelerometer data
#if defined ACCEL_16G
scale_accel_16g();
ax = dof.calcAccel(dof.ax)- abias[0]; // Convert to g's
ay = dof.calcAccel(dof.ay)- abias[1];
az = dof.calcAccel(dof.az)- abias[2];
ax = ax_avg.process(dof.calcAccel(dof.ax)- abias[0]);
ay = ay_avg.process(dof.calcAccel(dof.ay)- abias[1]);
az = az_avg.process(dof.calcAccel(dof.az)- abias[2]);
if(digitalRead(INT2XM)){
dof.readMag(); // Read raw magnetometer data
mx = dof.calcMag(dof.mx); // Convert to Gauss
my = dof.calcMag(dof.my);
mz = dof.calcMag(dof.mz);
dof.readTemp();
temp = 21.0 + (float) dof.temperature/8.0;
//Normalize accelerometer raw values.
float accXnorm = ax/sqrt(pow(ax,2) + pow(ay,2) + pow(az,2));
float accYnorm = ay/sqrt(pow(ax,2) + pow(ay,2) + pow(az,2));
//Calculate pitch and roll
//pitch = asin(-accXnorm);
//roll = asin(accYnorm/cos(pitch));
float magXcomp = mx*cos(pitch) - mz*sin(pitch);
float magYcomp = mx*sin(roll)*sin(pitch)+my*cos(roll)+mz*sin(roll)*cos(pitch);
float magZcomp = mx*cos(roll)*sin(pitch)+my*sin(roll)-mz*cos(roll)*cos(pitch);
declination = get_declination (gps.venus838data_filter.Latitude, gps.venus838data_raw.Longitude);
heading = yaw + declination;
inclination = 90 - 180*atan2f(sqrt(sq(magYcomp)+sq(magXcomp)),magZcomp)/M_PI;
if (magZcomp < 0)
inclination = - inclination;
/* Removed to differentiate pid frequency from sample freq.
//MadgwickQuaternionUpdate(ax, ay, az, gx*PI/180.0f, gy*PI/180.0f, gz*PI/180.0f, mx, my, mz);
MahonyQuaternionUpdate(ax, ay, az, gx*PI/180.0f, gy*PI/180.0f, gz*PI/180.0f, mx, my, mz);
//MahonyQuaternionUpdate(ax, ay, az, gx*PI/180.0f, gy*PI/180.0f, gz*PI/180.0f, mx, my, mz);
roll = atan2(2*(q[0]*q[1]+q[2]*q[3]),(1-2*(sq(q[1])+sq(q[2]))))*180.0/M_PI;
pitch = asin(2*(q[0]*q[2]-q[3]*q[1]))*180.0/M_PI;
yaw = atan2(2*(q[0]*q[3]+q[1]*q[2]), (1-2*(sq(q[2])+sq(q[3]))))*180.0/M_PI;
if ((az < 0)&&(pitch > 0))
pitch = 180 - pitch; // pitch change from 0 to 180 degree
if ((az < 0)&&(pitch < 0))
pitch = - 180 - pitch; // pitch change from 0 to -180 degree
if (magZcomp < 0)
now = micros();
deltat = ((now - lastUpdate)/1000000.0f); // set integration time by time elapsed since last filter update
lastUpdate = now;
Serial.println(deltat);
//print_9dof_data();
/// \fn print_9dof_data
/// \brief Print 9dof data in serial \n
void graph_9dof_data() {
Serial.print(ax);
Serial.print(" ");
Serial.print(ay);
Serial.print(" ");
Serial.println(az);
//Serial.print(" ");
//Serial.println(q[3]);
//Serial.print(gy);
//Serial.println(gz);
void update_quaternions(){
//roll = atan2(2*(q[0]*q[1]+q[2]*q[3]),(1-2*(sq(q[1])+sq(q[2]))))*180.0/M_PI;
//pitch = asin(2*(q[0]*q[2]-q[3]*q[1]))*180.0/M_PI;
//yaw = atan2(2*(q[0]*q[3]+q[1]*q[2]), (1-2*(sq(q[2])+sq(q[3]))))*180.0/M_PI;
//AHRSupdate(gx*PI/180.0f, gy*PI/180.0f, gz*PI/180.0f, ax, ay, az, mx, my, mz);
yaw = atan2(2.0f * (q[1] * q[2] + q[0] * q[3]), q[0] * q[0] + q[1] * q[1] - q[2] * q[2] - q[3] * q[3]);
pitch = -asin(2.0f * (q[1] * q[3] - q[0] * q[2]));
roll = atan2(2.0f * (q[0] * q[1] + q[2] * q[3]), q[0] * q[0] - q[1] * q[1] - q[2] * q[2] + q[3] * q[3]);
pitch *= 180.0f / PI;
yaw *= 180.0f / PI;
roll *= 180.0f / PI;
// declination = get_declination (gps.venus838data_filter.Latitude, gps.venus838data_raw.Longitude);
// heading = yaw + declination;
// inclination = 90 - 180*atan2f(sqrt(sq(magYcomp)+sq(magXcomp)),magZcomp)/M_PI;
// if (magZcomp < 0)
// inclination = - inclination;
now = micros();
lastUpdate = now;
//Serial.println(deltat);
void print_9dof_data()
Serial.print("Delta T: "); Serial.println(deltat, 4);
// print out accelleration data
Serial.print("Accel X: "); Serial.print(ax*ACC_SCALE, 3); Serial.print(" ");
Serial.print(" \tY: "); Serial.print(ay*ACC_SCALE, 3); Serial.print(" ");
Serial.print(" \tZ: "); Serial.print(az*ACC_SCALE, 3); Serial.println(" \mg");
// print out magnetometer data
Serial.print("Magn. X: "); Serial.print(mx, 3); Serial.print(" ");
Serial.print(" \tY: "); Serial.print(my, 3); Serial.print(" ");
Serial.print(" \tZ: "); Serial.print(mz, 3); Serial.println(" \tgauss");
// print out gyroscopic data
Serial.print("Gyro X: "); Serial.print(gx, 3); Serial.print(" ");
Serial.print(" \tY: "); Serial.print(gy, 3); Serial.print(" ");
Serial.print(" \tZ: "); Serial.print(gz, 3); Serial.println(" \tdps");
// print out temperature data
Serial.print("Temp: "); Serial.print(temp); Serial.println(" *C");
// 'orientation' should have valid .roll and .pitch fields
Serial.println(F("Orientation: "));
Serial.print("Roll: ");
Serial.println(roll, 7);
Serial.print("Pitch: ");
Serial.println(pitch, 7);
Serial.print("Yaw: ");
Serial.println(yaw, 7);
Serial.print("Heading: ");
Serial.println(heading, 7);
Serial.print("Inclination: ");
Serial.println(inclination, 7);
Serial.print("Pressure: "); Serial.print(bmp280_pressure, 3); Serial.println(" \mBar");
Serial.print(F(" "));
Serial.println(FreeMem());
Serial.print(q[0], 7);
Serial.print(",");
Serial.print(q[1], 7);
Serial.print(",");
Serial.print(q[2], 7);
Serial.print(",");
Serial.print(q[3], 7);
Serial.println(",");
Serial.print(ax,7);
Serial.print("\t");
Serial.print(ay,7);
Serial.print("\t");
Serial.print(az,7);
Serial.print("\t");
Serial.println(0);
float invSqrt(float number) {
union {
float f;
int32_t i;
} y;
y.f = number;
y.i = 0x5f375a86 - (y.i >> 1);
y.f = y.f * ( 1.5f - ( number * 0.5f * y.f * y.f ) );
return y.f;
