M5_LSM9DS0.cpp
SFE_LSM9DS0 Library Source File
Jim Lindblom @ SparkFun Electronics
Original Creation Date: February 14, 2014 (Happy Valentines Day!)
https://github.com/sparkfun/LSM9DS0_Breakout
This file implements all functions of the LSM9DS0 class. Functions here range
from higher level stuff, like reading/writing LSM9DS0 registers to low-level,
hardware reads and writes. Both SPI and I2C handler functions can be found
towards the bottom of this file.
Development environment specifics:
IDE: Arduino 1.0.5
Hardware Platform: Arduino Pro 3.3V/8MHz
LSM9DS0 Breakout Version: 1.0
This code is beerware; if you see me (or any other SparkFun employee) at the
local, and you've found our code helpful, please buy us a round!
Distributed as-is; no warranty is given.
#include "M5_LSM9DS0.h"
#include <i2c_t3.h> // Wire library is used for I2C
#include <SPI.h> // SPI library is used for...SPI.
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
LSM9DS0::LSM9DS0(interface_mode interface, uint8_t gAddr, uint8_t xmAddr)
// interfaceMode will keep track of whether we're using SPI or I2C:
interfaceMode = interface;
// xmAddress and gAddress will store the 7-bit I2C address, if using I2C.
// If we're using SPI, these variables store the chip-select pins.
xmAddress = xmAddr;
gAddress = gAddr;
uint16_t LSM9DS0::begin(gyro_scale gScl, accel_scale aScl, mag_scale mScl,
gyro_odr gODR, accel_odr aODR, mag_odr mODR)
// Store the given scales in class variables. These scale variables
// are used throughout to calculate the actual g's, DPS,and Gs's.
gScale = gScl;
aScale = aScl;
mScale = mScl;
// Once we have the scale values, we can calculate the resolution
// of each sensor. That's what these functions are for. One for each sensor
calcgRes(); // Calculate DPS / ADC tick, stored in gRes variable
calcmRes(); // Calculate Gs / ADC tick, stored in mRes variable
calcaRes(); // Calculate g / ADC tick, stored in aRes variable
// Now, initialize our hardware interface.
if (interfaceMode == MODE_I2C) // If we're using I2C
initI2C(); // Initialize I2C
else if (interfaceMode == MODE_SPI) // else, if we're using SPI
initSPI(); // Initialize SPI
// To verify communication, we can read from the WHO_AM_I register of
// each device. Store those in a variable so we can return them.
uint8_t gTest = gReadByte(WHO_AM_I_G); // Read the gyro WHO_AM_I
uint8_t xmTest = xmReadByte(WHO_AM_I_XM); // Read the accel/mag WHO_AM_I
// Gyro initialization stuff:
initGyro(); // This will "turn on" the gyro. Setting up interrupts, etc.
setGyroODR(gODR); // Set the gyro output data rate and bandwidth.
setGyroScale(gScale); // Set the gyro range
// Accelerometer initialization stuff:
initAccel(); // "Turn on" all axes of the accel. Set up interrupts, etc.
setAccelODR(aODR); // Set the accel data rate.
setAccelScale(aScale); // Set the accel range.
// Magnetometer initialization stuff:
initMag(); // "Turn on" all axes of the mag. Set up interrupts, etc.
setMagODR(mODR); // Set the magnetometer output data rate.
setMagScale(mScale); // Set the magnetometer's range.
// Once everything is initialized, return the WHO_AM_I registers we read:
return (xmTest << 8) | gTest;
void LSM9DS0::initGyro()
/* CTRL_REG1_G sets output data rate, bandwidth, power-down and enables
Bits[7:0]: DR1 DR0 BW1 BW0 PD Zen Xen Yen
DR[1:0] - Output data rate selection
00=95Hz, 01=190Hz, 10=380Hz, 11=760Hz
BW[1:0] - Bandwidth selection (sets cutoff frequency)
Value depends on ODR. See datasheet table 21.
PD - Power down enable (0=power down mode, 1=normal or sleep mode)
Zen, Xen, Yen - Axis enable (o=disabled, 1=enabled) */
gWriteByte(CTRL_REG1_G, 0x0F); // Normal mode, enable all axes
/* CTRL_REG2_G sets up the HPF
Bits[7:0]: 0 0 HPM1 HPM0 HPCF3 HPCF2 HPCF1 HPCF0
HPM[1:0] - High pass filter mode selection
00=normal (reset reading HP_RESET_FILTER, 01=ref signal for filtering,
10=normal, 11=autoreset on interrupt
HPCF[3:0] - High pass filter cutoff frequency
Value depends on data rate. See datasheet table 26.
gWriteByte(CTRL_REG2_G, 0x00); // Normal mode, high cutoff frequency
/* CTRL_REG3_G sets up interrupt and DRDY_G pins
Bits[7:0]: I1_IINT1 I1_BOOT H_LACTIVE PP_OD I2_DRDY I2_WTM I2_ORUN I2_EMPTY
I1_INT1 - Interrupt enable on INT_G pin (0=disable, 1=enable)
I1_BOOT - Boot status available on INT_G (0=disable, 1=enable)
H_LACTIVE - Interrupt active configuration on INT_G (0:high, 1:low)
PP_OD - Push-pull/open-drain (0=push-pull, 1=open-drain)
I2_DRDY - Data ready on DRDY_G (0=disable, 1=enable)
I2_WTM - FIFO watermark interrupt on DRDY_G (0=disable 1=enable)
I2_ORUN - FIFO overrun interrupt on DRDY_G (0=disable 1=enable)
I2_EMPTY - FIFO empty interrupt on DRDY_G (0=disable 1=enable) */
// Int1 enabled (pp, active low), data read on DRDY_G:
gWriteByte(CTRL_REG3_G, 0x88);
/* CTRL_REG4_G sets the scale, update mode
Bits[7:0] - BDU BLE FS1 FS0 - ST1 ST0 SIM
BDU - Block data update (0=continuous, 1=output not updated until read
BLE - Big/little endian (0=data LSB @ lower address, 1=LSB @ higher add)
FS[1:0] - Full-scale selection
00=245dps, 01=500dps, 10=2000dps, 11=2000dps
ST[1:0] - Self-test enable
00=disabled, 01=st 0 (x+, y-, z-), 10=undefined, 11=st 1 (x-, y+, z+)
SIM - SPI serial interface mode select
0=4 wire, 1=3 wire */
gWriteByte(CTRL_REG4_G, 0x00); // Set scale to 245 dps
/* CTRL_REG5_G sets up the FIFO, HPF, and INT1
Bits[7:0] - BOOT FIFO_EN - HPen INT1_Sel1 INT1_Sel0 Out_Sel1 Out_Sel0
BOOT - Reboot memory content (0=normal, 1=reboot)
FIFO_EN - FIFO enable (0=disable, 1=enable)
HPen - HPF enable (0=disable, 1=enable)
INT1_Sel[1:0] - Int 1 selection configuration
Out_Sel[1:0] - Out selection configuration */
gWriteByte(CTRL_REG5_G, 0x00);
// Temporary !!! For testing !!! Remove !!! Or make useful !!!
configGyroInt(0x2A, 0, 0, 0, 0); // Trigger interrupt when above 0 DPS...
void LSM9DS0::initAccel()
/* CTRL_REG0_XM (0x1F) (Default value: 0x00)
Bits (7-0): BOOT FIFO_EN WTM_EN 0 0 HP_CLICK HPIS1 HPIS2
BOOT - Reboot memory content (0: normal, 1: reboot)
FIFO_EN - Fifo enable (0: disable, 1: enable)
WTM_EN - FIFO watermark enable (0: disable, 1: enable)
HP_CLICK - HPF enabled for click (0: filter bypassed, 1: enabled)
HPIS1 - HPF enabled for interrupt generator 1 (0: bypassed, 1: enabled)
HPIS2 - HPF enabled for interrupt generator 2 (0: bypassed, 1 enabled) */
xmWriteByte(CTRL_REG0_XM, 0x00);
/* CTRL_REG1_XM (0x20) (Default value: 0x07)
Bits (7-0): AODR3 AODR2 AODR1 AODR0 BDU AZEN AYEN AXEN
AODR[3:0] - select the acceleration data rate:
0000=power down, 0001=3.125Hz, 0010=6.25Hz, 0011=12.5Hz,
0100=25Hz, 0101=50Hz, 0110=100Hz, 0111=200Hz, 1000=400Hz,
1001=800Hz, 1010=1600Hz, (remaining combinations undefined).
BDU - block data update for accel AND mag
0: Continuous update
1: Output registers aren't updated until MSB and LSB have been read.
AZEN, AYEN, and AXEN - Acceleration x/y/z-axis enabled.
0: Axis disabled, 1: Axis enabled */
xmWriteByte(CTRL_REG1_XM, 0x57); // 100Hz data rate, x/y/z all enabled
//Serial.println(xmReadByte(CTRL_REG1_XM));
/* CTRL_REG2_XM (0x21) (Default value: 0x00)
Bits (7-0): ABW1 ABW0 AFS2 AFS1 AFS0 AST1 AST0 SIM
ABW[1:0] - Accelerometer anti-alias filter bandwidth
00=773Hz, 01=194Hz, 10=362Hz, 11=50Hz
AFS[2:0] - Accel full-scale selection
000=+/-2g, 001=+/-4g, 010=+/-6g, 011=+/-8g, 100=+/-16g
AST[1:0] - Accel self-test enable
00=normal (no self-test), 01=positive st, 10=negative st, 11=not allowed
SIM - SPI mode selection
0=4-wire, 1=3-wire */
xmWriteByte(CTRL_REG2_XM, 0x00); // Set scale to 2g
/* CTRL_REG3_XM is used to set interrupt generators on INT1_XM
Bits (7-0): P1_BOOT P1_TAP P1_INT1 P1_INT2 P1_INTM P1_DRDYA P1_DRDYM P1_EMPTY
// Accelerometer data ready on INT1_XM (0x04)
xmWriteByte(CTRL_REG3_XM, 0x04);
void LSM9DS0::initMag()
/* CTRL_REG5_XM enables temp sensor, sets mag resolution and data rate
Bits (7-0): TEMP_EN M_RES1 M_RES0 M_ODR2 M_ODR1 M_ODR0 LIR2 LIR1
TEMP_EN - Enable temperature sensor (0=disabled, 1=enabled)
M_RES[1:0] - Magnetometer resolution select (0=low, 3=high)
M_ODR[2:0] - Magnetometer data rate select
000=3.125Hz, 001=6.25Hz, 010=12.5Hz, 011=25Hz, 100=50Hz, 101=100Hz
LIR2 - Latch interrupt request on INT2_SRC (cleared by reading INT2_SRC)
0=interrupt request not latched, 1=interrupt request latched
LIR1 - Latch interrupt request on INT1_SRC (cleared by readging INT1_SRC)
0=irq not latched, 1=irq latched */
xmWriteByte(CTRL_REG5_XM, 0x94); // Mag data rate - 100 Hz, enable temperature sensor
/* CTRL_REG6_XM sets the magnetometer full-scale
Bits (7-0): 0 MFS1 MFS0 0 0 0 0 0
MFS[1:0] - Magnetic full-scale selection
00:+/-2Gauss, 01:+/-4Gs, 10:+/-8Gs, 11:+/-12Gs */
xmWriteByte(CTRL_REG6_XM, 0x00); // Mag scale to +/- 2GS
/* CTRL_REG7_XM sets magnetic sensor mode, low power mode, and filters
AHPM1 AHPM0 AFDS 0 0 MLP MD1 MD0
AHPM[1:0] - HPF mode selection
00=normal (resets reference registers), 01=reference signal for filtering,
10=normal, 11=autoreset on interrupt event
AFDS - Filtered acceleration data selection
0=internal filter bypassed, 1=data from internal filter sent to FIFO
MLP - Magnetic data low-power mode
0=data rate is set by M_ODR bits in CTRL_REG5
1=data rate is set to 3.125Hz
MD[1:0] - Magnetic sensor mode selection (default 10)
00=continuous-conversion, 01=single-conversion, 10 and 11=power-down */
xmWriteByte(CTRL_REG7_XM, 0x00); // Continuous conversion mode
/* CTRL_REG4_XM is used to set interrupt generators on INT2_XM
Bits (7-0): P2_TAP P2_INT1 P2_INT2 P2_INTM P2_DRDYA P2_DRDYM P2_Overrun P2_WTM
xmWriteByte(CTRL_REG4_XM, 0x04); // Magnetometer data ready on INT2_XM (0x08)
/* INT_CTRL_REG_M to set push-pull/open drain, and active-low/high
Bits[7:0] - XMIEN YMIEN ZMIEN PP_OD IEA IEL 4D MIEN
XMIEN, YMIEN, ZMIEN - Enable interrupt recognition on axis for mag data
PP_OD - Push-pull/open-drain interrupt configuration (0=push-pull, 1=od)
IEA - Interrupt polarity for accel and magneto
0=active-low, 1=active-high
IEL - Latch interrupt request for accel and magneto
4D - 4D enable. 4D detection is enabled when 6D bit in INT_GEN1_REG is set
MIEN - Enable interrupt generation for magnetic data
0=disable, 1=enable) */
xmWriteByte(INT_CTRL_REG_M, 0x09); // Enable interrupts for mag, active-low, push-pull
// This is a function that uses the FIFO to accumulate sample of accelerometer and gyro data, average
// them, scales them to gs and deg/s, respectively, and then passes the biases to the main sketch
// for subtraction from all subsequent data. There are no gyro and accelerometer bias registers to store
// the data as there are in the ADXL345, a precursor to the LSM9DS0, or the MPU-9150, so we have to
// subtract the biases ourselves. This results in a more accurate measurement in general and can
// remove errors due to imprecise or varying initial placement. Calibration of sensor data in this manner
// is good practice.
void LSM9DS0::calLSM9DS0(float * gbias, float * abias)
uint8_t data[6] = {0, 0, 0, 0, 0, 0};
int32_t gyro_bias[3] = {0, 0, 0}, accel_bias[3] = {0, 0, 0};
uint16_t samples, ii;
// First get gyro bias
byte c = gReadByte(CTRL_REG5_G);
gWriteByte(CTRL_REG5_G, c | 0x40); // Enable gyro FIFO
delay(20); // Wait for change to take effect
gWriteByte(FIFO_CTRL_REG_G, 0x20 | 0x1F); // Enable gyro FIFO stream mode and set watermark at 32 samples
delay(1000); // delay 1000 milliseconds to collect FIFO samples
samples = (gReadByte(FIFO_SRC_REG_G) & 0x1F); // Read number of stored samples
for(ii = 0; ii < samples ; ii++) { // Read the gyro data stored in the FIFO
int16_t gyro_temp[3] = {0, 0, 0};
gReadBytes(OUT_X_L_G, &data[0], 6);
gyro_temp[0] = (int16_t) (((int16_t)data[1] << 8) | data[0]); // Form signed 16-bit integer for each sample in FIFO
gyro_temp[1] = (int16_t) (((int16_t)data[3] << 8) | data[2]);
gyro_temp[2] = (int16_t) (((int16_t)data[5] << 8) | data[4]);
gyro_bias[0] += (int32_t) gyro_temp[0]; // Sum individual signed 16-bit biases to get accumulated signed 32-bit biases
gyro_bias[1] += (int32_t) gyro_temp[1];
gyro_bias[2] += (int32_t) gyro_temp[2];
gyro_bias[0] /= samples; // average the data
gyro_bias[1] /= samples;
gyro_bias[2] /= samples;
gbias[0] = (float)gyro_bias[0]*gRes; // Properly scale the data to get deg/s
gbias[1] = (float)gyro_bias[1]*gRes;
gbias[2] = (float)gyro_bias[2]*gRes;
gWriteByte(CTRL_REG5_G, c & ~0x40); // Disable gyro FIFO
delay(20);
gWriteByte(FIFO_CTRL_REG_G, 0x00); // Enable gyro bypass mode
// Now get the accelerometer biases
c = xmReadByte(CTRL_REG0_XM);
xmWriteByte(CTRL_REG0_XM, c | 0x40); // Enable accelerometer FIFO
xmWriteByte(FIFO_CTRL_REG, 0x20 | 0x1F); // Enable accelerometer FIFO stream mode and set watermark at 32 samples
samples = (xmReadByte(FIFO_SRC_REG) & 0x1F); // Read number of stored accelerometer samples
for(ii = 0; ii < samples ; ii++) { // Read the accelerometer data stored in the FIFO
int16_t accel_temp[3] = {0, 0, 0};
xmReadBytes(OUT_X_L_A, &data[0], 6);
accel_temp[0] = (int16_t) (((int16_t)data[1] << 8) | data[0]);// Form signed 16-bit integer for each sample in FIFO
accel_temp[1] = (int16_t) (((int16_t)data[3] << 8) | data[2]);
accel_temp[2] = (int16_t) (((int16_t)data[5] << 8) | data[4]);
accel_bias[0] += (int32_t) accel_temp[0]; // Sum individual signed 16-bit biases to get accumulated signed 32-bit biases
accel_bias[1] += (int32_t) accel_temp[1];
accel_bias[2] += (int32_t) accel_temp[2];
accel_bias[0] /= samples; // average the data
accel_bias[1] /= samples;
accel_bias[2] /= samples;
if(accel_bias[2] > 0L) {accel_bias[2] -= (int32_t) (1.0/aRes);} // Remove gravity from the z-axis accelerometer bias calculation
else {accel_bias[2] += (int32_t) (1.0/aRes);}
abias[0] = (float)accel_bias[0]*aRes; // Properly scale data to get gs
abias[1] = (float)accel_bias[1]*aRes;
abias[2] = (float)accel_bias[2]*aRes;
xmWriteByte(CTRL_REG0_XM, c & ~0x40); // Disable accelerometer FIFO
delay(20);
xmWriteByte(FIFO_CTRL_REG, 0x00); // Enable accelerometer bypass mode
void LSM9DS0::readAccel()
uint8_t temp[6]; // We'll read six bytes from the accelerometer into temp
xmReadBytes(OUT_X_L_A, temp, 6); // Read 6 bytes, beginning at OUT_X_L_A
ax = (temp[1] << 8) | temp[0]; // Store x-axis values into ax
ay = (temp[3] << 8) | temp[2]; // Store y-axis values into ay
az = (temp[5] << 8) | temp[4]; // Store z-axis values into az
void LSM9DS0::readMag()
uint8_t temp[6]; // We'll read six bytes from the mag into temp
xmReadBytes(OUT_X_L_M, temp, 6); // Read 6 bytes, beginning at OUT_X_L_M
mx = (temp[1] << 8) | temp[0]; // Store x-axis values into mx
my = (temp[3] << 8) | temp[2]; // Store y-axis values into my
mz = (temp[5] << 8) | temp[4]; // Store z-axis values into mz
void LSM9DS0::readTemp()
uint8_t temp[2]; // We'll read two bytes from the temperature sensor into temp
xmReadBytes(OUT_TEMP_L_XM, temp, 2); // Read 2 bytes, beginning at OUT_TEMP_L_M
temperature = (((int16_t) temp[1] << 12) | temp[0] << 4 ) >> 4; // Temperature is a 12-bit signed integer
void LSM9DS0::readGyro()
uint8_t temp[6]; // We'll read six bytes from the gyro into temp
gReadBytes(OUT_X_L_G, temp, 6); // Read 6 bytes, beginning at OUT_X_L_G
gx = (temp[1] << 8) | temp[0]; // Store x-axis values into gx
gy = (temp[3] << 8) | temp[2]; // Store y-axis values into gy
gz = (temp[5] << 8) | temp[4]; // Store z-axis values into gz
float LSM9DS0::calcGyro(int16_t gyro)
// Return the gyro raw reading times our pre-calculated DPS / (ADC tick):
return gRes * gyro;
float LSM9DS0::calcAccel(int16_t accel)
// Return the accel raw reading times our pre-calculated g's / (ADC tick):
return aRes * accel;
float LSM9DS0::calcMag(int16_t mag)
// Return the mag raw reading times our pre-calculated Gs / (ADC tick):
return mRes * mag;
void LSM9DS0::setGyroScale(gyro_scale gScl)
// We need to preserve the other bytes in CTRL_REG4_G. So, first read it:
uint8_t temp = gReadByte(CTRL_REG4_G);
// Then mask out the gyro scale bits:
temp &= 0xFF^(0x3 << 4);
// Then shift in our new scale bits:
temp |= gScl << 4;
// And write the new register value back into CTRL_REG4_G:
gWriteByte(CTRL_REG4_G, temp);
// We've updated the sensor, but we also need to update our class variables
// First update gScale:
gScale = gScl;
// Then calculate a new gRes, which relies on gScale being set correctly:
calcgRes();
void LSM9DS0::setAccelScale(accel_scale aScl)
// We need to preserve the other bytes in CTRL_REG2_XM. So, first read it:
uint8_t temp = xmReadByte(CTRL_REG2_XM);
// Then mask out the accel scale bits:
temp &= 0xFF^(0x3 << 3);
temp |= aScl << 3;
// And write the new register value back into CTRL_REG2_XM:
xmWriteByte(CTRL_REG2_XM, temp);
// First update aScale:
aScale = aScl;
// Then calculate a new aRes, which relies on aScale being set correctly:
calcaRes();
void LSM9DS0::setMagScale(mag_scale mScl)
// We need to preserve the other bytes in CTRL_REG6_XM. So, first read it:
uint8_t temp = xmReadByte(CTRL_REG6_XM);
// Then mask out the mag scale bits:
temp &= 0xFF^(0x3 << 5);
temp |= mScl << 5;
// And write the new register value back into CTRL_REG6_XM:
xmWriteByte(CTRL_REG6_XM, temp);
// First update mScale:
mScale = mScl;
// Then calculate a new mRes, which relies on mScale being set correctly:
calcmRes();
void LSM9DS0::setGyroODR(gyro_odr gRate)
// We need to preserve the other bytes in CTRL_REG1_G. So, first read it:
uint8_t temp = gReadByte(CTRL_REG1_G);
// Then mask out the gyro ODR bits:
temp &= 0xFF^(0xF << 4);
// Then shift in our new ODR bits:
temp |= (gRate << 4);
// And write the new register value back into CTRL_REG1_G:
gWriteByte(CTRL_REG1_G, temp);
void LSM9DS0::setAccelODR(accel_odr aRate)
// We need to preserve the other bytes in CTRL_REG1_XM. So, first read it:
uint8_t temp = xmReadByte(CTRL_REG1_XM);
// Then mask out the accel ODR bits:
temp |= (aRate << 4);
// And write the new register value back into CTRL_REG1_XM:
xmWriteByte(CTRL_REG1_XM, temp);
void LSM9DS0::setAccelABW(accel_abw abwRate)
// Then mask out the accel ABW bits:
temp &= 0xFF^(0x3 << 7);
temp |= (abwRate << 7);
void LSM9DS0::setMagODR(mag_odr mRate)
// We need to preserve the other bytes in CTRL_REG5_XM. So, first read it:
uint8_t temp = xmReadByte(CTRL_REG5_XM);
// Then mask out the mag ODR bits:
temp &= 0xFF^(0x7 << 2);
temp |= (mRate << 2);
// And write the new register value back into CTRL_REG5_XM:
xmWriteByte(CTRL_REG5_XM, temp);
void LSM9DS0::configGyroInt(uint8_t int1Cfg, uint16_t int1ThsX, uint16_t int1ThsY, uint16_t int1ThsZ, uint8_t duration)
gWriteByte(INT1_CFG_G, int1Cfg);
gWriteByte(INT1_THS_XH_G, (int1ThsX & 0xFF00) >> 8);
gWriteByte(INT1_THS_XL_G, (int1ThsX & 0xFF));
gWriteByte(INT1_THS_YH_G, (int1ThsY & 0xFF00) >> 8);
gWriteByte(INT1_THS_YL_G, (int1ThsY & 0xFF));
gWriteByte(INT1_THS_ZH_G, (int1ThsZ & 0xFF00) >> 8);
gWriteByte(INT1_THS_ZL_G, (int1ThsZ & 0xFF));
if (duration)
gWriteByte(INT1_DURATION_G, 0x80 | duration);
gWriteByte(INT1_DURATION_G, 0x00);
void LSM9DS0::calcgRes()
// Possible gyro scales (and their register bit settings) are:
// 245 DPS (00), 500 DPS (01), 2000 DPS (10). Here's a bit of an algorithm
// to calculate DPS/(ADC tick) based on that 2-bit value:
switch (gScale)
case G_SCALE_245DPS:
gRes = 245.0 / 32768.0;
case G_SCALE_500DPS:
gRes = 500.0 / 32768.0;
case G_SCALE_2000DPS:
gRes = 2000.0 / 32768.0;
void LSM9DS0::calcaRes()
// Possible accelerometer scales (and their register bit settings) are:
// 2 g (000), 4g (001), 6g (010) 8g (011), 16g (100). Here's a bit of an
// algorithm to calculate g/(ADC tick) based on that 3-bit value:
aRes = aScale == A_SCALE_16G ? 16.0 / 32768.0 :
(((float) aScale + 1.0) * 2.0) / 32768.0;
void LSM9DS0::calcmRes()
// Possible magnetometer scales (and their register bit settings) are:
// 2 Gs (00), 4 Gs (01), 8 Gs (10) 12 Gs (11). Here's a bit of an algorithm
// to calculate Gs/(ADC tick) based on that 2-bit value:
mRes = mScale == M_SCALE_2GS ? 2.0 / 32768.0 :
(float) (mScale << 2) / 32768.0;
void LSM9DS0::gWriteByte(uint8_t subAddress, uint8_t data)
// Whether we're using I2C or SPI, write a byte using the
// gyro-specific I2C address or SPI CS pin.
I2CwriteByte(gAddress, subAddress, data);
SPIwriteByte(gAddress, subAddress, data);
void LSM9DS0::xmWriteByte(uint8_t subAddress, uint8_t data)
// accelerometer-specific I2C address or SPI CS pin.
return I2CwriteByte(xmAddress, subAddress, data);
return SPIwriteByte(xmAddress, subAddress, data);
uint8_t LSM9DS0::gReadByte(uint8_t subAddress)
// Whether we're using I2C or SPI, read a byte using the
return I2CreadByte(gAddress, subAddress);
return SPIreadByte(gAddress, subAddress);
void LSM9DS0::gReadBytes(uint8_t subAddress, uint8_t * dest, uint8_t count)
// Whether we're using I2C or SPI, read multiple bytes using the
I2CreadBytes(gAddress, subAddress, dest, count);
SPIreadBytes(gAddress, subAddress, dest, count);
uint8_t LSM9DS0::xmReadByte(uint8_t subAddress)
return I2CreadByte(xmAddress, subAddress);
return SPIreadByte(xmAddress, subAddress);
void LSM9DS0::xmReadBytes(uint8_t subAddress, uint8_t * dest, uint8_t count)
I2CreadBytes(xmAddress, subAddress, dest, count);
SPIreadBytes(xmAddress, subAddress, dest, count);
void LSM9DS0::initSPI()
pinMode(gAddress, OUTPUT);
digitalWrite(gAddress, HIGH);
pinMode(xmAddress, OUTPUT);
digitalWrite(xmAddress, HIGH);
SPI.begin();
// Maximum SPI frequency is 10MHz, could divide by 2 here:
SPI.setClockDivider(SPI_CLOCK_DIV4);
// Data is read and written MSb first.
SPI.setBitOrder(MSBFIRST);
// Data is captured on rising edge of clock (CPHA = 0)
// Base value of the clock is HIGH (CPOL = 1)
SPI.setDataMode(SPI_MODE1);
void LSM9DS0::SPIwriteByte(uint8_t csPin, uint8_t subAddress, uint8_t data)
digitalWrite(csPin, LOW); // Initiate communication
// If write, bit 0 (MSB) should be 0
// If single write, bit 1 should be 0
SPI.transfer(subAddress & 0x3F); // Send Address
SPI.transfer(data); // Send data
digitalWrite(csPin, HIGH); // Close communication
uint8_t LSM9DS0::SPIreadByte(uint8_t csPin, uint8_t subAddress)
uint8_t temp;
// Use the multiple read function to read 1 byte.
// Value is returned to `temp`.
SPIreadBytes(csPin, subAddress, &temp, 1);
return temp;
void LSM9DS0::SPIreadBytes(uint8_t csPin, uint8_t subAddress,
// To indicate a read, set bit 0 (msb) to 1
// If we're reading multiple bytes, set bit 1 to 1
// The remaining six bytes are the address to be read
if (count > 1)
SPI.transfer(0xC0 | (subAddress & 0x3F));
SPI.transfer(0x80 | (subAddress & 0x3F));
for (int i=0; i<count; i++)
dest[i] = SPI.transfer(0x00); // Read into destination array
/* Use for Mini Add-On board
void LSM9DS0::initI2C()
// Setup for Master mode, pins 16/17, external pullups, 400kHz
Wire.begin(I2C_MASTER, 0x00, I2C_PINS_16_17, I2C_PULLUP_EXT, I2C_RATE_400);
// Wire.h read and write protocols
void LSM9DS0::I2CwriteByte(uint8_t address, uint8_t subAddress, uint8_t data)
Wire.beginTransmission(address); // Initialize the Tx buffer
Wire.write(subAddress); // Put slave register address in Tx buffer
Wire.write(data); // Put data in Tx buffer
Wire.endTransmission(); // Send the Tx buffer
uint8_t LSM9DS0::I2CreadByte(uint8_t address, uint8_t subAddress)
uint8_t data; // `data` will store the register data
Wire.endTransmission(I2C_NOSTOP); // Send the Tx buffer, but send a restart to keep connection alive
// Wire.endTransmission(false); // Send the Tx buffer, but send a restart to keep connection alive
Wire.requestFrom(address, (size_t) 1); // Read one byte from slave register address
data = Wire.read(); // Fill Rx buffer with result
return data; // Return data read from slave register
void LSM9DS0::I2CreadBytes(uint8_t address, uint8_t subAddress, uint8_t * dest, uint8_t count)
// Next send the register to be read. OR with 0x80 to indicate multi-read.
Wire.write(subAddress | 0x80); // Put slave register address in Tx buffer
//Wire.endTransmission(false); // Send the Tx buffer, but send a restart to keep connection alive
uint8_t i = 0;
Wire.requestFrom(address, (size_t) count); // Read bytes from slave register address
while (Wire.available()) {
dest[i++] = Wire.read(); } // Put read results in the Rx buffer
// Wire1 for using I2C pins 29/30 for Micro Add-On board
// Setup for Master mode, pins 29/30, external pullups, 400kHz
Wire1.begin(I2C_MASTER, 0x00, I2C_PINS_29_30, I2C_PULLUP_EXT, I2C_RATE_400);
//Wire.begin();
Wire1.beginTransmission(address); // Initialize the Tx buffer
Wire1.write(subAddress); // Put slave register address in Tx buffer
Wire1.write(data); // Put data in Tx buffer
Wire1.endTransmission(); // Send the Tx buffer
Wire1.endTransmission(I2C_NOSTOP); // Send the Tx buffer, but send a restart to keep connection alive
Wire1.requestFrom(address, (size_t) 1); // Read one byte from slave register address
data = Wire1.read(); // Fill Rx buffer with result
Wire1.write(subAddress | 0x80); // Put slave register address in Tx buffer
uint8_t i = 0;
Wire1.requestFrom(address, (size_t) count); // Read bytes from slave register address
while (Wire1.available()) {
dest[i++] = Wire1.read(); } // Put read results in the Rx buffer
