Results 1 to 3 of 3
Thread: Malloc error on Teensy 3.1 using Mac OS 10.9 and Arduino IDE
    Currently Sarande, Albania
    66
    After switching all my SD card code form SD to SdFat once I got all the normal new lib errors worked thru I get what looks like a linker error:
      Using previously compiled: /var/folders/rb/y3bt7gq151x05xlwpzpzc0hm0000gt/T/build7533490590131683916.tmp/arduino/hooks.c.o
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=96000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX256__ -DTEENSYDUINO=118 -DTIME_T=1404214698 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Users/freddie/Documents/Arduino/libraries/arduino -I/Applications/Arduino.app/Contents/Resources/Java/libraries/OneWire -I/Applications/Arduino.app/Contents/Resources/Java/libraries/UTFT -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time -I/Users/freddie/Documents/Arduino/libraries/UTouch -I/Users/freddie/Documents/Arduino/libraries/DallasTemperature -I/Users/freddie/Documents/Arduino/libraries/SdFat -I/Users/freddie/Documents/Arduino/libraries/arduino/utility /Users/freddie/Documents/Arduino/libraries/arduino/malloc.c -o /var/folders/rb/y3bt7gq151x05xlwpzpzc0hm0000gt/T/build7533490590131683916.tmp/arduino/malloc.c.o
    /Users/freddie/Documents/Arduino/libraries/arduino/malloc.c:67:26: warning: initialization makes pointer from integer without a cast [enabled by default]
    /Users/freddie/Documents/Arduino/libraries/arduino/malloc.c: In function 'malloc':
    /Users/freddie/Documents/Arduino/libraries/arduino/malloc.c:163:7: error: 'AVR_STACK_POINTER_REG' undeclared (first use in this function)
    /Users/freddie/Documents/Arduino/libraries/arduino/malloc.c:163:7: note: each undeclared identifier is reported only once for each function it appears in
    /Users/freddie/Documents/Arduino/libraries/arduino/malloc.c: In function 'realloc':
    /Users/freddie/Documents/Arduino/libraries/arduino/malloc.c:359:9: error: 'AVR_STACK_POINTER_REG' undeclared (first use in this function)
    Can anyone tell me which one of these include files is the guilty culprit for including malloc which seems to only work with AVR:
    // Arduino Libraries:
    #include "Arduino.h"
    #include "OneWire.h" //These are the libs for the One-Wire interface
    //#include "SD.h"  // We also need the SD card libraries for storing the data on the disk.
    #include "UTFT.h"  // We are going to use the TFT Display instead of the monitor
    #include "Time.h"  // Time is a library that provides timekeeping functionality for Teensy 3.1.
    // User Libraries:
    #include <UTouch.h>  // We are also going to use the Touch Panel of the Display
    #include <DallasTemperature.h> //This is for reading the DS18S20 Temp Sensors.
    #include <SdFat.h>
    //#include <SdFatUtil.h>  // define FreeRam()
    #include <ArduinoStream.h>
    #include <bufstream.h>
    #include <ios.h>
    #include <iostream.h>
    #include <istream.h>
    #include <MinimumSerial.h>
    #include <ostream.h>
    #include <Sd2Card.h>
    #include <SdBaseFile.h>
    #include <SdFatConfig.h>
    #include <SdFatmainpage.h>
    #include <SdFatStructs.h>
    #include <SdFile.h>
    #include <SdInfo.h>
    #include <SdSpi.h>
    #include <SdStream.h>
    #include <SdVolume.h>
    Any suggestions would be greatly appreciated!
    Thanks,
    Freddie
    26,791
    Perhaps whatever you installed in /Users/freddie/Documents/Arduino/libraries/arduino ?
    66
    Paul:
    Thanks, that was what was responsible for all the errors.
    I have no idea were that folder came from, very strange!
    Thanks again,
    Freddie
