sbfreddie
After switching all my SD card code form SD to SdFat once I got all the normal new lib errors worked thru I get what looks like a linker error:
Can anyone tell me which one of these include files is the guilty culprit for including malloc which seems to only work with AVR:
Any suggestions would be greatly appreciated!
Thanks,
Freddie
Using previously compiled: /var/folders/rb/y3bt7gq151x05xlwpzpzc0hm0000gt/T/build7533490590131683916.tmp/arduino/hooks.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=96000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX256__ -DTEENSYDUINO=118 -DTIME_T=1404214698 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Users/freddie/Documents/Arduino/libraries/arduino -I/Applications/Arduino.app/Contents/Resources/Java/libraries/OneWire -I/Applications/Arduino.app/Contents/Resources/Java/libraries/UTFT -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time -I/Users/freddie/Documents/Arduino/libraries/UTouch -I/Users/freddie/Documents/Arduino/libraries/DallasTemperature -I/Users/freddie/Documents/Arduino/libraries/SdFat -I/Users/freddie/Documents/Arduino/libraries/arduino/utility /Users/freddie/Documents/Arduino/libraries/arduino/malloc.c -o /var/folders/rb/y3bt7gq151x05xlwpzpzc0hm0000gt/T/build7533490590131683916.tmp/arduino/malloc.c.o
/Users/freddie/Documents/Arduino/libraries/arduino/malloc.c:67:26: warning: initialization makes pointer from integer without a cast [enabled by default]
/Users/freddie/Documents/Arduino/libraries/arduino/malloc.c: In function 'malloc':
/Users/freddie/Documents/Arduino/libraries/arduino/malloc.c:163:7: error: 'AVR_STACK_POINTER_REG' undeclared (first use in this function)
/Users/freddie/Documents/Arduino/libraries/arduino/malloc.c:163:7: note: each undeclared identifier is reported only once for each function it appears in
/Users/freddie/Documents/Arduino/libraries/arduino/malloc.c: In function 'realloc':
/Users/freddie/Documents/Arduino/libraries/arduino/malloc.c:359:9: error: 'AVR_STACK_POINTER_REG' undeclared (first use in this function)
// Arduino Libraries:
#include "Arduino.h"
#include "OneWire.h" //These are the libs for the One-Wire interface
//#include "SD.h" // We also need the SD card libraries for storing the data on the disk.
#include "UTFT.h" // We are going to use the TFT Display instead of the monitor
#include "Time.h" // Time is a library that provides timekeeping functionality for Teensy 3.1.
// User Libraries:
#include <UTouch.h> // We are also going to use the Touch Panel of the Display
#include <DallasTemperature.h> //This is for reading the DS18S20 Temp Sensors.
#include <SdFat.h>
//#include <SdFatUtil.h> // define FreeRam()
#include <ArduinoStream.h>
#include <bufstream.h>
#include <ios.h>
#include <iostream.h>
#include <istream.h>
#include <MinimumSerial.h>
#include <ostream.h>
#include <Sd2Card.h>
#include <SdBaseFile.h>
#include <SdFatConfig.h>
#include <SdFatmainpage.h>
#include <SdFatStructs.h>
#include <SdFile.h>
#include <SdInfo.h>
#include <SdSpi.h>
#include <SdStream.h>
#include <SdVolume.h>
Thanks,
Freddie
