Page 2 of 2 FirstFirst 1 2
Results 26 to 45 of 45
Thread: Teensyduino 1.20 Release Candidate #1 Available
  1. #26
    The recommended change to using 16MHz XTAL source for CAN0 peripheral is merged into master. If you need anything for pulling it into 1.20 let me know.
    https://github.com/teachop/FlexCAN_Library
    P.S. Paul I had a question here:
    http://forum.pjrc.com/threads/24720-...ll=1#post50777
  2. #27
    Dear Paul,
    #define FTM_CONF_BDMMODE  (((n) & 3) << 6)   // Behavior when in debug mode
    #define FTM_CONF_NUMTOF     (((n) & 31) << 0) // ratio of counter overflows
    must be
    #define FTM_CONF_BDMMODE(n) (((n) & 3) << 6)   // Behavior when in debug mode
    #define FTM_CONF_NUMTOF(n)    (((n) & 31) << 0) // ratio of counter overflows
    why do you don't use _MASK extension
    like -> FTM_MODE_FTMEN_MASK;
    i must rewritten some example Code!
    Barney
  3. #28
    10
    I've at home a Teensy3.0 and I use it with OctoWS2811 and 256leds/strip.
    With that number of leds a free byte of ram is a free byte !
    I don't care to have USB serial, I just need to be able to flash the teensy.
    I'll be nice to have an option to disable it.
    With this small (ugly?) patch which add an option : USB_NONE, I save ~1.2kB of ram.
    index 248cb1e..8508e85 100644
    --- a/hardware/teensy/boards.txt
    +++ b/hardware/teensy/boards.txt
    @@ -146,6 +146,7 @@ teensy3.build.option3=-D__MK20DX128__
     teensy3.build.option4=-DTEENSYDUINO=120
     teensy3.build.cppoption1=-fno-rtti
     teensy3.build.linkoption1=-mthumb
    +teensy3.build.linkoption2=-Wl,-Map,map.out
     teensy3.build.additionalobject1=-larm_cortexM4l_math
     teensy3.build.linkscript=mk20dx128.ld
     teensy3.build.architecture=arm-none-eabi
    @@ -162,6 +163,8 @@ teensy3.build.dependency=true
     teensy3.build.time_t=true
     #teensy3.build.linker_relaxation=true
     teensy3.build.post_compile_script=teensy_post_compile
    +teensy3.menu.usb.none.name=None
    +teensy3.menu.usb.none.build.define0=-DUSB_NONE
     teensy3.menu.usb.serial.name=Serial
     teensy3.menu.usb.serial.build.define0=-DUSB_SERIAL
     teensy3.menu.usb.hid.name=Keyboard + Mouse + Joystick
    diff --git a/hardware/teensy/cores/teensy3/usb_desc.h b/hardware/teensy/cores/teensy3/usb_desc.h
    index c3cf15c..f1240e6 100644
    --- a/hardware/teensy/cores/teensy3/usb_desc.h
    +++ b/hardware/teensy/cores/teensy3/usb_desc.h
    @@ -83,7 +83,27 @@ let me know?  http://forum.pjrc.com/forums/4-Suggestions-amp-Bug-Reports
    -#if defined(USB_SERIAL)
    +#if defined(USB_NONE)
    +  #define VENDOR_ID            0x16C0
    +  #define PRODUCT_ID           0x0483
    +  #define MANUFACTURER_NAME    {'T','e','e','n','s','y','d','u','i','n','o'}
    +  #define MANUFACTURER_NAME_LEN        11
    +  #define PRODUCT_NAME         {'U','S','B',' ','F','l','a','s','h'}
    +  #define PRODUCT_NAME_LEN     9
    +  #define EP0_SIZE             8
    +  #define NUM_ENDPOINTS                0
    +  #define NUM_USB_BUFFERS      0
    +  #define NUM_INTERFACE                2
    +  #define CDC_STATUS_INTERFACE 0
    +  #define CDC_DATA_INTERFACE   1
    +  #define CDC_ACM_ENDPOINT     2
    +  #define CDC_RX_ENDPOINT       3
    +  #define CDC_TX_ENDPOINT       4
    +  #define CDC_ACM_SIZE          16
    +  #define CDC_RX_SIZE           64
    +  #define CDC_TX_SIZE           64
    +  #define CONFIG_DESC_SIZE     (9+9+5+5+4+5+7+9+7+7)
    +#elif defined(USB_SERIAL)
       #define DEVICE_CLASS         2       // 2 = Communication Class
    diff --git a/hardware/teensy/cores/teensy3/yield.cpp b/hardware/teensy/cores/teensy3/yield.cpp
    index 55e7d29..16ae996 100644
    --- a/hardware/teensy/cores/teensy3/yield.cpp
    +++ b/hardware/teensy/cores/teensy3/yield.cpp
    @@ -40,7 +40,9 @@ void yield(void)
            if (running) return; // TODO: does this need to be atomic?
            running = 1;
    +#ifdef USB_SERIAL
            if (Serial.available()) serialEvent();
    +#endif
            if (Serial1.available()) serialEvent1();
            if (Serial2.available()) serialEvent2();
            if (Serial3.available()) serialEvent3();
    This patch should be improvable. I just tried to reduce the USB buffers to save RAM.
    Same thing for VectorsRam, if we don't need to change the vector table, it's 256 bytes of ram wasted :/
    diff --git a/hardware/teensy/cores/teensy3/mk20dx128.c b/hardware/teensy/cores/teensy3/mk20dx128.c
    index d9a751f..04abe32 100644
    --- a/hardware/teensy/cores/teensy3/mk20dx128.c
    +++ b/hardware/teensy/cores/teensy3/mk20dx128.c
    @@ -407,9 +407,13 @@ void ResetHandler(void)
            while (dest < &_ebss) *dest++ = 0;
            // default all interrupts to medium priority level
    +#if defined(STATIC_VECTOR_TABLE)
    +       SCB_VTOR = (uint32_t)_VectorsFlash;     // use vector table in FLASH
    +#else
            for (i=0; i < NVIC_NUM_INTERRUPTS + 16; i++) _VectorsRam[i] = _VectorsFlash[i];
    -       for (i=0; i < NVIC_NUM_INTERRUPTS; i++) NVIC_SET_PRIORITY(i, 128);
            SCB_VTOR = (uint32_t)_VectorsRam;       // use vector table in RAM
    +#endif
    +       for (i=0; i < NVIC_NUM_INTERRUPTS; i++) NVIC_SET_PRIORITY(i, 128);
            // hardware always starts in FEI mode
            //  C1[CLKS] bits are written to 00
  4. #29
    10
    Anyway, FASTRUN is a great idea !
    It gives a serious boost on my plasma-like effect on ILI9341 : 134.7ms / frame => 62.3 ms / frame (-53% ... more than x2 !)
    I now run my plasma effect @16fps, tx !
  5. #30
    Sep 2013
    SF Bay Area
    17
    Tried to DL
    Mac OS-X:
    http://www.pjrc.com/teensy/td_120-rc1/teensyduino.dmg
    Multiple times today... Something seems just not quite right. Are others able to DL this?
    -A
  6. #31
    Boston, MA, USA
    1,108
    Is there a simple example showing how to use FASTRUN?
  7. #32
    Senior Member xxxajk's Avatar
    Nov 2013
    Buffalo, NY USA
    528
    This is actually in-the-works :-) If you run at < 20MHz, it will screw up too. I need to see if Paul has fixed this issue yet. With NO USB you can even do your own USB stuff, which is what I need.
  8. #33
    20,566
    Quote Originally Posted by Alkorin View Post
    Is this code published anywhere? I'd love to give it a try, if it's available.
  9. #34
    Nov 2013
    Buffalo, NY USA
    528
    I have two bugs reported on github.
    The first bug is actually a set of bugs.
    port[abcde]_isr should be prefixed with __attribute__((weak)) to allow them to be overridden. https://github.com/PaulStoffregen/cores/issues/34
    Second bug is that micros() can't be called from within an ISR because it will enable interrupts. https://github.com/PaulStoffregen/cores/issues/35
    There are a lot of other timing functions that also depend on it. Any of them used within an ISR will enable IRQs, which is bad.
  10. #35
    Boston, MA, USA
    1,108
    Self bump because I would like to know how to use FASTRUN
    Quote Originally Posted by Nantonos View Post
  11. #36
    Oct 2012
    19
    Tested with current 64-bit Ubuntu 14.04 against current 64-bit Arduino code. Solves a problem I was having with Teensy 3.1 where the USB serial ports weren't appearing. Well done!
  12. #37
    Jun 2014
    Johannesburg, South Africa
    18
    I am trying to get serial event() to work - this code works on AVR but not on teensy - any suggestions (or corrections :-) )
    char tempBuffer[100] = {0};
    const int MaxInput  = 10;
    elapsedMillis hBeat;     // "waiting" starts at zero
      while (!Serial); // wait for connection to terminal emulator
      Serial.println("Enter something");
      if (hBeat >= 1000)
        Serial.println(".");
        hBeat = 0; // reset count
    void serialEvent()
      static unsigned int input_pos = 0;
      //Serial.println("+"); // debug so we know this has been called
      while (Serial.available())
        char inByte = (char)Serial.read();
        switch (inByte)
        case '\n':   // end of text
          tempBuffer [input_pos] = 0;  // terminating null byte
          Serial.println(tempBuffer);
          input_pos = 0;
        default:
          // only allow alphabet and punctuation chrs
          if (inByte >= 32 && inByte <= 126)
            // keep adding if not full ... allow for terminating null byte
            if (input_pos < (MaxInput - 1)) tempBuffer[input_pos++] = inByte;
          } // end if((inByte ....
    5,421
    What version of the Teensyduino are you running? I believe this has been added for the current beta 1.20rc2 (maybe rc1 as well).
  14. #39
    Sometimesyou need to fix nested interrupt locking
    Quote Originally Posted by xxxajk View Post
    Hi, I saw this post looking through the release notes. I also saw Paul closed your issue seeming to say it wasn't broken.
    This notion of nested interrupt locking has come up before in this forum. And there seems to be this notion that because
    you can use interrupt priority with our ARM MCU you don't have to worry about the interrupt locking issue. But that's
    just sort of wrong I think. As you point out, the problem comes up with nested critical sections. Much current Teensy/Arduino code uses __disable_interrupt and __enable_interrupt to protect a critical section. However, if a call
    is made inside a critical section to code that tries to also implement a critical section the same way then the code
    breaks because the nested __enable_interrupts call unconditionally enables the interrupts breaking the critical section.
    So, for any critical sections that can potentially be nested I use the inline routines I wrote below instead. It's a bit
    more overhead but than the unconditional routines but they work. And they have to be used as you also note.
    static inline uint32_t sl_hw_lock(void) __attribute__((always_inline, unused));
    static inline void sl_hw_unlock(uint32_t primask) __attribute__((always_inline,
        unused));
     * Lock interrupts to start a critical section.
     * When used with sl_hw_unlock() this function starts a critical section that
     * works properly even if nested in another critical section because it reads
     * the PRIMASK value so it can be restored.
     * @return the priority mask (PRIMASK) register value upon entry
    sl_hw_lock(void)
        uint32_t  primask;
        asm volatile("mrs %0, primask\n" : "=r" (primask)::);
        __disable_irq();
        return primask;
     * Unlock interrupts to end a critical section.
     * When used with sl_hw_lock() this function ends a critical section that works
     * properly even if nested in another critical section because it uses the
     * previous interrupt locking state (defined by PRIMASK) to selectively unlock
     * interrupts.
     * @param primask   The previous priority mask (PRIMASK) register value as
     *                  returned by sl_hw_lock().
    static inline void
        if (primask == 0) {
            __enable_irq();
    When this came up a while ago on the forum there was an argument that it wasn't a problem. The well composed thread is:
    http://forum.pjrc.com/threads/24098-...rrupt-locking)
    Well, I just wrote my code the way I knew I needed it.
  15. #40
    Jun 2014
    18
    I downloaded v1.20rc1 - so perhaps I need rc2 - anyone got a link for me - above is only rc1 as far I can see?
  16. #41
    Jun 2014
    18
  17. #42
    Jun 2014
    18
    Installed 1.20 rc2 serialevent() still not working - is there anything else to perhaps preconfigure ?
  18. #43
    5,421
    Another question, when you say it works on an Arduino? Which one? If normal Atmega328 or the like, than you are using IO pins 0,1 for the serial device and not USB input?
    If so pins 0, 1 on the Teensy 3/3.1 as well as Arduino like Leonardo that are atmega 32u4 based is not the Serial object, but instead Serial1 object... So in that case you need to change your code to use serialEvent1() and Serial1 ...
  19. #44
    20,566
    Quote Originally Posted by shanevanj View Post
    Please post this in this problem in the Suggestinos & Bug Reports section, as a new thread.
    http://forum.pjrc.com/forums/4-Sugge...mp-Bug-Reports
    Remember the forum rule: Always post complete source code & details to reproduce any issue!
  20. #45
    Jun 2014
    18
    Tested with an UNO (code below) using default USB connection as serial port inn both cases (teensy 3.1 and UNO) - UNO it works - teensy does not - moving this to Bug reports as suggested by Paul below.
    long prevMillis = 0;
    int loopDelay = 1000;
      if (millis() > prevMillis + loopDelay)
        prevMillis = millis(); // reset count
    void serialEvent()
        switch (inByte)
          input_pos = 0;
        default:
