jimmayhugh
I'm testing a Teensy3.1 with the latest version of the UFTF Library and an iTeadStudio ITDB02-5.0 . I'm using the example provided in the library, with some Serial.println()s thrown in to see where I am.
The code compiles, but just before the Teensy Loader starts up, I get an error message "device node not found", and then the upload begins and completes. I'm currently using Teensyduino version 1.18 on a Debian 7.5 system.
Here's the stderr.txt as well
Any thoughts??
// UTFT_Demo_800x480 (C)2014 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of how to use most of the functions
// of the library with a supported display modules.
// This demo was made for modules with a screen resolution
// of 800x480 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
const long baudRate = 115200;
// Set the pins to the correct ones for your development shield
// Standard Arduino Mega/Due shield : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due : <display model>,25,26,27,28
// Teensy 3.x TFT Test Board : <display model>,23,22, 3, 4
// ElecHouse TFT LCD/SD Shield for Arduino Due : <display model>,22,23,31,33
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(ITDB50,23,22, 3, 4); //Teensy3.1
Serial.begin(baudRate);
randomSeed(analogRead(0));
// Setup the LCD
myGLCD.InitLCD();
myGLCD.setFont(SmallFont);
int buf[798];
int x, x2;
int y, y2;
int r;
// Clear the screen and draw the frame
Serial.println(F("Clear Screen"));
myGLCD.clrScr();
Serial.println(F("Draw Frame"));
myGLCD.setColor(255, 0, 0);
myGLCD.fillRect(0, 0, 799, 13);
myGLCD.setColor(64, 64, 64);
myGLCD.fillRect(0, 466, 799, 479);
myGLCD.setColor(255, 255, 255);
myGLCD.setBackColor(255, 0, 0);
myGLCD.print("* Universal Color TFT Display Library *", CENTER, 1);
myGLCD.setBackColor(64, 64, 64);
myGLCD.setColor(255,255,0);
myGLCD.print("<http://electronics.henningkarlsen.com>", CENTER, 467);
myGLCD.setColor(0, 0, 255);
myGLCD.drawRect(0, 14, 799, 465);
// Draw crosshairs
Serial.println(F("Draw Crosshairs"));
myGLCD.setBackColor(0, 0, 0);
myGLCD.drawLine(399, 15, 399, 464);
myGLCD.drawLine(1, 239, 798, 239);
for (int i=9; i<790; i+=10)
myGLCD.drawLine(i, 237, i, 242);
for (int i=19; i<470; i+=10)
myGLCD.drawLine(397, i, 402, i);
// Draw sin-, cos- and tan-lines
Serial.println(F("Draw Sin, Cos, Tan"));
myGLCD.setColor(0,255,255);
myGLCD.print("Sin", 5, 15);
for (int i=1; i<798; i++)
myGLCD.drawPixel(i,239+(sin(((i*1.13)*3.14)/180)*200));
myGLCD.setColor(255,0,0);
myGLCD.print("Cos", 5, 27);
myGLCD.drawPixel(i,239+(cos(((i*1.13)*3.14)/180)*200));
myGLCD.print("Tan", 5, 39);
myGLCD.drawPixel(i,239+(tan(((i*0.9)*3.14)/180)));
delay(2000);
myGLCD.setColor(0,0,0);
myGLCD.fillRect(1,15,798,464);
// Draw a moving sinewave
Serial.println(F("Draw Sine Wave"));
x=1;
for (int i=1; i<(798*20); i++)
x++;
if (x==799)
x=1;
if (i>799)
if ((x==399)||(buf[x-1]==239))
myGLCD.setColor(0,0,255);
myGLCD.drawPixel(x,buf[x-1]);
y=239+(sin(((i*1.65)*3.14)/180)*(200-(i / 100)));
myGLCD.drawPixel(x,y);
buf[x-1]=y;
delay(2000);
// Draw some random filled rectangles
Serial.println(F("Draw Circles"));
for (int i=0; i<50; i++)
myGLCD.setColor(random(255), random(255), random(255));
x=2+random(746);
y=16+random(397);
x2=x+50;
y2=y+50;
myGLCD.fillRect(x, y, x2, y2);
delay(2000);
// Draw some random filled, rounded rectangles
Serial.println(F("Draw Rectangles"));
x=2+random(746);
y=16+random(397);
x2=x+50;
y2=y+50;
myGLCD.fillRoundRect(x, y, x2, y2);
delay(2000);
// Draw some random filled circles
Serial.println(F("Draw Filled Circles"));
x=27+random(746);
y=41+random(397);
myGLCD.fillCircle(x, y, 25);
delay(2000);
// Draw some lines in a pattern
myGLCD.setColor (255,0,0);
for (int i=15; i<463; i+=5)
myGLCD.drawLine(1, i, (i*1.66)-10, 463);
for (int i=463; i>15; i-=5)
myGLCD.drawLine(798, i, (i*1.66)+30, 15);
myGLCD.setColor (0,255,255);
myGLCD.drawLine(1, i, 770-(i*1.66), 15);
myGLCD.drawLine(798, i, 810-(i*1.66), 463);
delay(2000);
// Draw some random circles
for (int i=0; i<250; i++)
x=32+random(736);
y=45+random(386);
r=random(30);
myGLCD.drawCircle(x, y, r);
delay(2000);
// Draw some random rectangles
Serial.println(F("Draw Filled Rectangles"));
x=2+random(796);
y=16+random(447);
x2=2+random(796);
y2=16+random(447);
myGLCD.drawRect(x, y, x2, y2);
delay(2000);
// Draw some random rounded rectangles
Serial.println(F("Draw Rounded Rectangles"));
x=2+random(796);
y=16+random(447);
x2=2+random(796);
y2=16+random(447);
myGLCD.drawRoundRect(x, y, x2, y2);
delay(2000);
x=2+random(796);
y=16+random(447);
x2=2+random(796);
y2=16+random(447);
myGLCD.drawLine(x, y, x2, y2);
delay(2000);
for (int i=0; i<10000; i++)
myGLCD.drawPixel(2+random(796), 16+random(447));
delay(2000);
myGLCD.fillScr(0, 0, 255);
myGLCD.fillRoundRect(320, 190, 479, 289);
myGLCD.print("That's it!", CENTER, 213);
myGLCD.print("Restarting in a", CENTER, 239);
myGLCD.print("few seconds...", CENTER, 252);
myGLCD.setColor(0, 255, 0);
myGLCD.setBackColor(0, 0, 255);
myGLCD.print("Runtime: (msecs)", CENTER, 450);
myGLCD.printNumI(millis(), CENTER, 465);
Serial.println(F("Done, delaying 1sec"));
delay (1000);
In file included from /home/jimm/teensyduino18/libraries/UTFT/UTFT.h:184:0,
from Teensy3_UTFT_Demo_800x480.ino:13:
/home/jimm/teensyduino18/libraries/UTFT/hardware/arm/HW_ARM_defines.h:30:0: warning: "pgm_read_word" redefined [enabled by default]
In file included from /home/jimm/teensyduino18/hardware/teensy/cores/teensy3/WProgram.h:11:0,
from /home/jimm/teensyduino18/hardware/teensy/cores/teensy3/Arduino.h:1,
from /home/jimm/teensyduino18/libraries/UTFT/UTFT.h:183,
/home/jimm/teensyduino18/hardware/teensy/cores/teensy3/avr/pgmspace.h:56:0: note: this is the location of the previous definition
/home/jimm/teensyduino18/libraries/UTFT/hardware/arm/HW_ARM_defines.h:31:0: warning: "pgm_read_byte" redefined [enabled by default]
/home/jimm/teensyduino18/hardware/teensy/cores/teensy3/avr/pgmspace.h:55:0: note: this is the location of the previous definition
Teensy3_UTFT_Demo_800x480.ino: In function 'void loop()':
Teensy3_UTFT_Demo_800x480.ino:57:68: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Teensy3_UTFT_Demo_800x480.ino:60:70: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Teensy3_UTFT_Demo_800x480.ino:79:28: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Teensy3_UTFT_Demo_800x480.ino:86:28: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Teensy3_UTFT_Demo_800x480.ino:93:28: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Teensy3_UTFT_Demo_800x480.ino:289:41: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Teensy3_UTFT_Demo_800x480.ino:290:46: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Teensy3_UTFT_Demo_800x480.ino:291:45: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Teensy3_UTFT_Demo_800x480.ino:295:47: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
from /home/jimm/teensyduino18/libraries/UTFT/UTFT.cpp:45:
/home/jimm/teensyduino18/libraries/UTFT/UTFT.cpp:85:80: note: #pragma message: Compiling for Teensy 3.x (MK20DX128VLH7 / MK20DX256VLH7)...
/home/jimm/teensyduino18/libraries/UTFT/UTFT.cpp: In member function 'void UTFT::printNumF(double, byte, int, int, char, int, char)':
/home/jimm/teensyduino18/libraries/UTFT/UTFT.cpp:1083:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/home/jimm/teensyduino18/libraries/UTFT/UTFT.cpp:1093:29: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/home/jimm/teensyduino18/libraries/UTFT/UTFT.cpp:1099:29: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
Opening Teensy Loader...
TeensyNet.ino: In function 'void EEPROMclear()':
TeensyNet.ino:3701:33: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
TeensyNet.ino:3715:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
In file included from TeensyNet.ino:112:0:
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_readAnything(uint16_t, T&, uint8_t) [with T = unsigned char; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:750:63: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h:95:11: warning: unused variable 'received' [-Wunused-variable]
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_readAnything(uint16_t, T&, uint8_t) [with T = char [16]; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:758:66: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_writeAnything(uint16_t, const T&, uint8_t) [with T = char [16]; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:888:69: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h:62:11: warning: unused variable 'sent' [-Wunused-variable]
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_readAnything(uint16_t, T&, uint8_t) [with T = chipStruct [36]; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:1104:74: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_readAnything(uint16_t, T&, uint8_t) [with T = chipActionStruct [12]; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:1121:79: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_readAnything(uint16_t, T&, uint8_t) [with T = chipPIDStruct [4]; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:1137:74: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_writeAnything(uint16_t, const T&, uint8_t) [with T = unsigned char; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:1167:60: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_writeAnything(uint16_t, const T&, uint8_t) [with T = chipStruct [36]; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:1169:75: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_writeAnything(uint16_t, const T&, uint8_t) [with T = chipActionStruct [12]; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:1186:79: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_writeAnything(uint16_t, const T&, uint8_t) [with T = chipPIDStruct [4]; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:1201:74: required from here
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In instantiation of 'uint16_t I2CEEPROM_writeAnything(uint16_t, const T&, uint8_t) [with T = unsigned char [128]; uint16_t = short unsigned int; uint8_t = unsigned char]':
TeensyNet.ino:3695:45: required from here
TeensyNet.ino: In function 'void updateActions(uint8_t)':
TeensyNet.ino:3675:52: warning: 'lcdUpdateStart' may be used uninitialized in this function [-Wmaybe-uninitialized]
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In function 'uint16_t I2CEEPROM_readAnything(uint16_t, T&, uint8_t) [with T = unsigned char; uint16_t = short unsigned int; uint8_t = unsigned char]':
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h:120:5: warning: 'totalRead' is used uninitialized in this function [-Wuninitialized]
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h: In function 'void readStructures()':
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h:120:5: warning: 'totalRead' may be used uninitialized in this function [-Wmaybe-uninitialized]
/home/jimm/sketchbook/libraries/I2CEEPROMAnything/I2CEEPROMAnything.h:93:15: note: 'totalRead' was declared here
/home/jimm/teensyduino18/libraries/OneWire/OneWire.cpp: In member function 'uint8_t OneWire::reset()':
/home/jimm/teensyduino18/libraries/OneWire/OneWire.cpp:139:14: warning: unused variable 'mask' [-Wunused-variable]
/home/jimm/teensyduino18/libraries/OneWire/OneWire.cpp: In member function 'void OneWire::write_bit(uint8_t)':
/home/jimm/teensyduino18/libraries/OneWire/OneWire.cpp:173:14: warning: unused variable 'mask' [-Wunused-variable]
/home/jimm/teensyduino18/libraries/OneWire/OneWire.cpp: In member function 'uint8_t OneWire::read_bit()':
/home/jimm/teensyduino18/libraries/OneWire/OneWire.cpp:201:14: warning: unused variable 'mask' [-Wunused-variable]
/home/jimm/teensyduino18/libraries/Ethernet/Dns.cpp: In member function 'uint16_t DNSClient::ProcessResponse(uint16_t, IPAddress&)':
/home/jimm/teensyduino18/libraries/Ethernet/Dns.cpp:285:29: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
/home/jimm/teensyduino18/libraries/Ethernet/Dns.cpp:287:50: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
/home/jimm/teensyduino18/libraries/Ethernet/Dns.cpp:304:28: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
/home/jimm/teensyduino18/libraries/Ethernet/Dns.cpp:313:29: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
/home/jimm/teensyduino18/libraries/Ethernet/Dhcp.cpp: In member function 'uint8_t DhcpClass::parseDHCPResponse(long unsigned int, uint32_t&)':
/home/jimm/teensyduino18/libraries/Ethernet/Dhcp.cpp:332:55: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
/home/jimm/teensyduino18/libraries/Ethernet/utility/socket.cpp: In function 'uint16_t igmpsend(SOCKET, const uint8_t*, uint16_t)':
/home/jimm/teensyduino18/libraries/Ethernet/utility/socket.cpp:316:11: warning: variable 'status' set but not used [-Wunused-but-set-variable]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp: In member function 'int EthernetBonjourClass::_closeMDNSSession()':
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:315:1: warning: no return statement in function returning non-void [-Wreturn-type]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp: In member function 'MDNSError_t EthernetBonjourClass::_sendMDNSMessage(uint32_t, uint32_t, int, int)':
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:375:77: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:405:77: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:414:77: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:431:77: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:439:80: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:444:80: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:447:34: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:467:77: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:504:77: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:522:77: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:536:1: warning: label 'errorReturn' defined but not used [-Wunused-label]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp: In member function 'MDNSError_t EthernetBonjourClass::_processMDNSQuery()':
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:666:48: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:806:54: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:902:55: warning: value computed is not used [-Wunused-value]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:902:55: warning: statement has no effect [-Wunused-value]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp: In member function 'void EthernetBonjourClass::_writeDNSName(const uint8_t*, uint16_t*, uint8_t*, int, int)':
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:1323:80: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:1334:77: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:1341:74: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp: In member function 'void EthernetBonjourClass::_writeMyIPAnswerRecord(uint16_t*, uint8_t*, int)':
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:1358:71: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:1368:71: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp: In member function 'void EthernetBonjourClass::_writeServiceRecordPTR(int, uint16_t*, uint8_t*, int, uint32_t)':
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:1416:71: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:1089:96: warning: 'peer_addr' may be used uninitialized in this function [-Wmaybe-uninitialized]
/home/jimm/sketchbook/libraries/EthernetBonjour/EthernetBonjour.cpp:1089:96: warning: 'xid' may be used uninitialized in this function [-Wmaybe-uninitialized]
/home/jimm/sketchbook/libraries/EthernetBonjour/utility/EthernetUtil.c:64:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
/home/jimm/sketchbook/libraries/EthernetBonjour/utility/EthernetUtil.c:65:0: warning: ignoring #pragma mark Private [-Wunknown-pragmas]
/home/jimm/teensyduino18/libraries/Wire/Wire.cpp: In member function 'uint8_t TwoWire::requestFrom(uint8_t, uint8_t, uint8_t)':
/home/jimm/teensyduino18/libraries/Wire/Wire.cpp:308:10: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
Any thoughts??
