help needed for newbie
karolis
New member
Hello
I just bought teensy2++ and i was playing with it.
i noticed one thing. IF i declare LED pin at start of my program it works fine(it bright), but if i change it in void setup or loop it becomes not very bright can someone tell me why?
int led = 7;
  pinMode (led, OUTPUT);
led = 8;
digitalWrite (led, HIGH);
I want to make this shorter
int led1 = 7;
int led2 = 8;
int led3 = 9;
int led4 = 10;
int led5 = 11;
  pinMode (led1, OUTPUT);
  pinMode (led2, OUTPUT);
  pinMode (led3, OUTPUT);
  pinMode (led4, OUTPUT);
  pinMode (led5, OUTPUT);
//led1
digitalWrite (led1, HIGH);
delay (50);
digitalWrite (led1, LOW);
delay (50);
delay (50);
delay (50);
//led2
digitalWrite (led2, HIGH);
delay (50);
digitalWrite (led2, LOW);
delay (50);
delay (50);
delay (50);
//led3
digitalWrite (led3, HIGH);
delay (50);
digitalWrite (led3, LOW);
delay (50);
delay (50);
delay (50);
//led4
digitalWrite (led4, HIGH);
delay (50);
digitalWrite (led4, LOW);
delay (50);
delay (50);
delay (50);
//led5
digitalWrite (led5, HIGH);
delay (50);
digitalWrite (led5, LOW);
delay (50);
delay (50);
delay (50);
In your first section of code pin 7 is correctly configured as an output but pin 8 is not, so it remains a default input.
When you set pin 8 to high it is still an input and you are just activating it's internal pull up resistor. That is why the
LED would be very dim. Your second section of code is the correct way to declare outputs. Hope that helps.
To shorten your second section of code you could do something like:
int led1 = 7;
int led2 = 8;
int led3 = 9;
int led4 = 10;
int led5 = 11;
for (int i=7; i <= 11; i++)
digitalWrite(i,HIGH);
delay(50);
digitalWrite(i,LOW);
delay(50);
MY idea was to make second part of the code shorter in this way.
int led = 7;
delay (1000);
led ++;
while (led == 11);
But now, I know its a wrong way:) So i need to figure out the right way :)(
You might try:
int led = 7;
delay (1000);
led ++;
while (led > 11);
Maybe this?
int firstLED = 7;
int lastLED = 11;
  for (int i=firstLED; i <= lastLED; i++) {
    pinMode (i, OUTPUT);
    digitalWrite (i, HIGH);
    delay (50);
    digitalWrite (i, LOW);
    delay (50);
    delay (50);
    delay (50);
