Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 95
Thread: Has anyone tried running the GSL16880 capacitive touchscreen controller with Teensy3?
  1. #51
    Jan 2015
    11
    pgm_read_byte_far doesn't work as it should because GCC compiler uses 16 bit addressing for pgm by default and cannot be changed. The only way to go beyond 64K is to use the GET_FAR_ADDRESS routine I found on the internet and keep track of indexes in case of arrays, because indexing won't work with this routine.
    #define GET_FAR_ADDRESS(var) \
    uint_farptr_t tmp; \
    __asm__ __volatile__( \
    "ldi %A0, lo8(%1)" "\n\t" \
    "ldi %B0, hi8(%1)" "\n\t" \
    "ldi %C0, hh8(%1)" "\n\t" \
    "clr %D0" "\n\t" \
    "=d" (tmp) \
    "p" (&(var)) \
    tmp; \
    The code above retrieves the 24-bit address in flash where your array's beginning is stored. Then you combine this with pgm_read like this:
    pgm_read_byte_far(GET_FAR_ADDRESS(GSLX680_FW[0].offset)+source_line*5);
    F_byte = pgm_read_dword_far(GET_FAR_ADDRESS(GSLX680_FW[0].val)+source_line*5);
    and you get the constants from the array. Number 5 is the struct size: 1uchar(1 byte) + 1 long int (4 bytes) = 5 bytes total
    It was hard to get it right but I'm proud I sorted it out in the end :-)
  2. #52
    Jan 2015
    Norway
    16
    I've tried to run wolfmanjm code on an Arduino Mega (1280). I ran without BIGFLASH.
    I get the following output:
    Starting
    Toggle Wake
    clr reg
    i2c write error: 4 E0
    reset_chip
    load_fw
    Firmware length: 21414
    reset_chip2
    startup_chip
    init done
    Then nothing more happens.
    Can it be related to CosR1 addressing issue ?
    CosR1: I didn't get exactly what you have done. Did you modify the code?
  3. #53
    Yea it is related, you need to make the mods he has suggested, as reading from Flash is not as straight forward as I had thought. It runs on teensy as there is no special program needed to read flash.
  4. #54
    Jan 2015
    Norway
    16
    I'm not sure I understand the modifications he suggested...
    Is it in the actual .ino file ?
    I'm using the compressed version.
    The code CosR1 suggests refers to GSLX680_FW which seems to be related to gslX680firmware.h...which is not compressed ?
    I'm a bit confused...
    Can you clarify ?
  5. #55
    yea one is compressed the other is not compressed, you can use the uncompressed one as the 1280 has more flash available.
    The issue is that the standard routine to read flash can not handle 24 bit addresses, so the hack he suggests will fix that. I have not tried it as I switched to using an arm board instead of an AVR based Arduino and that doesn't have this issue.
    I think there is an alternative solution too, send the firmware in blocks and increment the base address each time using the FAR macro so it never has to read more than 256 bytes of flash at a time.
  6. #56
    Jan 2015
    11
    I'm using the uncompressed version. I'm not familiar with the arduino so I can't help. If you are using GCC to compile for the arduino platform then 16-bit addressing is going to the a problem for you, too. You have to use the code I published here or it won't work. Use the GET_FAR_ADDRESS routine and then use the lines below to access the flash correctly and read the firmware.
  7. #57
    Jan 2015
    11
    _GSLX680_load_fw routine is where the changes are to be made. Find addr and F_byte and change these lines to
    addr = pgm_read_byte_far(GET_FAR_ADDRESS(GSLX680_FW[0].offset)+source_line*5);
  8. #58
    Jan 2015
    Norway
    16
    Thanks,
    Guess I have some reading to do. Need to understand a bit more how the memory stuff works on the Arduino.
    I'll let you know if I manage to sort things out :-)
  9. #59
    Jan 2015
    Norway
    16
    I've now done some testing.
    I'm using the compressed version. On Arduino MEGA (1280).
    28860 bytes of flash verified.
    It fails when trying to write to the GSL_STATUS_REG.
    I get:
    This indicates that I get error code 4 back when trying to write 0x88 to 0xe0 (which is GSL_STATUS_REG)
    This happens in the clr_reg and reset_chip.
    The firmware write sequence seems to be ok.
    Is this really related to the 64K thing ? Sounds strange...
  10. #60
    no that is unrelated, I think you can ignore those errors as they follow a reset and probably the chip is not ready yet.
  11. #61
    Jan 2015
    Norway
    16
    Have anyone verified that the compressed version works ?
  12. #62
    no I never got it to work, which is why I suggest you use the uncompressed version. I did write a verifier for it though and it compares byte to byte with the original.
  13. #63
    Jan 2015
    Norway
    16
    When using the uncompressed version on the Mega (1280) I get the message:
    Global variables use 28.083 bytes (342%) of dynamic memory....
    Any rewrite tricks to avoid this use of dynamic memory ?
    BTW: I've ordered a Teensy 3.1 to see if I can make it work on that one first.
  14. #64
    yea it needs to be put in flash not ram, the compressed one has the magic incantation for that.
  15. #65
    Jan 2015
    Norway
    16
    With that magic incantation the sketch was successfully uploaded to the Mega :-)
    I now use the uncompressed firmware, so I'll dig into that FAR memory issue...
  16. #66
    Jan 2015
    11
    While playing with the touch I found out 2 issues:
    1) Start-up delay was not enough, so after power-up allow around 1 sec before flashing the firmware to the touch controller. Then, after you get it to work you can decrease the delay. <-- this also led to errors when sending commands
    2) When the firmware was not loaded properly I got the same behavior you mention, i.e. some commands would fail (and in particular the clr_reg & reset_chip), so this is directly linked to the 64K thing.
  17. #67
    Jan 2015
    Norway
    16
    Ok, but the sequence in the code seems to be:
    Wake high
    wake low
    wake high
    clr_reg (where I get the 4 E0 write error)
    reset_chip (where I get the 4 E0 write error)
    load_fw (no errors here!)
    The 1 second delay you mention. Where should that be ? After wake high or after reset_chip ?
  18. #68
    Jan 2015
    Norway
    16
    ...and if I enable serial.print in the i2c_write function I get the following when loading firmware:
    i2c write: F0
    3,0,0,0,
    i2c write: 0
    C0,FF,A5,A5,
    i2c write: 4
    0,0,0,0,
    i2c write: 8
    E1,C4,10,E8
    Can anyone confirm that this is correct ?
    Update: A closer look shows that it stops firmware update when at firmware line 119... Interesting!...
    the sizeof(GSLX680_FW)/sizeof(struct fw_data) gives me: 102. That is wrong. How stupid can I be... I have an 8 bit counter there... argh !!!
  19. #69
    Jan 2015
    11
    Quote Originally Posted by helgelangehaug View Post
    Wake high
    wake low
    wake high
    The 1 second delay should be right after uC and touch power-up - before the first wake high
  20. #70
    Jan 2015
    Norway
    16
    YES !!!!
    It now works with the Arduino MEGA !
    I still get the 4 E0 errors, so I don't think that is related to the 64K issue.
    And I didn't need the 1 second delay...
    Now it's time to see if I can get the compressed version to work.
  21. #71
    Jan 2015
    Norway
    16
    wolfmanjm: I've forked wolfmanjm/GSL1680 and will continue on my own copy, if that's ok with you.
    wolfmanjm/CosR1: If it's ok with you, I'll try to make a small blog entry about all this. Along the same line as I did with the RA8875 based 7" here: https://weatherhelge.wordpress.com/2...d-upn-running/
    Great work! Thanks for the help. I'll let you know if I get the compressed version to work.
  22. #72
    Jan 2015
    11
    It OK with me
  23. #73
    Jan 2015
    Norway
    16
    I haven't heard from wolfmanjm, but I guess he don't mind. Here is the post: https://weatherhelge.wordpress.com/2...-with-arduino/
  24. #74
    Jan 2015
    11
    Nice one !!!
  25. #75
    Yes it is fine with me, can you send me a pull request so i can update my version with the version that works? thanks
