I got what I believe is an equvalent display on ali express for 4 dollars and wanted to see if I coule use it to replace my oled on a project. I am currently getting errors. I am using sublime text with arduino 1.0.6 and newest teensyduino. It appears to mainly be an error of the SPI label so I thought maybe there is a different deffinition for 3.2? I am using the audio board and I have made the audio board changes in the doc on your teensy page for this lib
note: the actual display that I recieved is slightly different then pictured in the ali page. It has a micro sd and additional pins on the header that are all labeled NC Ill post a pic if I can figure out how.
http://www.aliexpress.com/item/Whol...39997.html?spm=2114.10010108.100010.47.It2BIh
I am trying out the adafruit lib now which at least compiles and uploads but no activity on the display. I also tried with arduino IDE 1.6.5.
[Stino - Start building "onoffbutton"...]
[ 1%] Creating /Users/AxiomCrux/Dropbox/Sketchbook/_Builds/onoffbutton/onoffbutton.ino.cpp.o...
In file included from /Applications/Arduino.1.0.6.app/Contents/Resources/Java/libraries/ILI9341_t3/examples/onoffbutton/onoffbutton.ino:8:0:
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoNotFull()':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:219:9: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoEmpty()':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:227:9: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitTransmitComplete()':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:233:12: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:234:9: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitTransmitComplete(uint32_t)':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:239:18: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:243:3: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writecommand_cont(uint8_t)':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:250:3: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata8_cont(uint8_t)':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:254:3: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata16_cont(uint16_t)':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:258:3: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writecommand_last(uint8_t)':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:263:3: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata8_last(uint8_t)':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:268:3: error: 'KINETISK_SPI0' was not declared in this scope
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata16_last(uint16_t)':
/Users/AxiomCrux/Dropbox/Sketchbook/libraries/ILI9341_t3/ILI9341_t3.h:273:3: error: 'KINETISK_SPI0' was not declared in this scope
[Stino - Exit with error code 1.]
