Page 24 of 24 FirstFirst ... 14 22 23 24
Results 576 to 581 of 581
Thread: Highly optimized ILI9341 (320x240 TFT color display) library
  1. #576
    5,424
    @KurtE and @Projectitis
    I incorporated the changes into my copy of the ILI9341_t3 library and the fonts do look nice - but as you said does take a bit longer but the quality is nicer especially for the larger fonts. I did test with the scrolltest.ino sketch but the fonts didn't seem to work as well but I don't have time to debug right now maybe later. But it does work.
    It is now pulled in to the ili9341_t3n library
    Kurt
  2. #577
    Senior Member Projectitis's Avatar
    Feb 2018
    New Zealand
    146
    Hi @mjs513 - I've got family here for a few days, but after that I'll take a look I have a fix for the speed that will make it actually faster than the standard non ant-aliased font rendering, and I'll also debug the scrolling. I realised that I haven't published the script to create anti-aliased fonts either, so I'll do that too!
    @KurtE - fantastic, thank you In my libraries I typedef ILI9341_t3_font_t as packedbdf_t so that it isn't named after a display. What do you think of this strategy going forward?
  3. #578
    Feb 2018
    New Zealand
    146
    Scripts and instructions to create packed BDF anti-aliased fonts here:
    https://github.com/projectitis/packedbdf
    Full description of packedbdf_t data type also in the repo. Many thanks to Paul, spook and others for their initial work on all this material!
    note: packedbdf_t and ILI9341_t3_font_t are the same thing.
  4. #579
    Feb 2018
    New Zealand
    146
    @mjs513 I have updated my branch of Paul's ILI9341_t3 library with more efficient anti-alias rendering. Its about 25% faster than the standard non-anti-aliased rendering!
    Normal rendering: 14971
    Anti-aliased rendering: 11551
    I'll take a look at what's happening with scrolltest now (on KurtE's t3n version).
    EDIT: Have made a new example in my version of _t3n. I just had to change the call to setTextColor to also specify the background color.
    It still looks slightly wrong when the text is printed on the green bar at the bottom of the white box - the text that extends into the white box still has a green background color behind it. Since I'm not entirely sure what your intention is with scrolltest, I'll leave it at that for now and let you look into it if it's a problem?
  5. #580
    Feb 2018
    New Zealand
    146
    Aaaand have improved the original font rendering speed (1bpp, non anti-aliased fonts) of ILI9341_t3:
    original 1bpp fonts 14971
    improved 1bpp fonts 11360 (~25% faster)
    (Compare to new anti-alias fonts 11551)
    Find updates here: https://github.com/projectitis/ILI93...ti-alias-fonts
  6. #581
    9,735
    Sounds like some good work
