Page 5 of 24 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Results 101 to 125 of 581
Thread: Highly optimized ILI9341 (320x240 TFT color display) library
  1. #101
    Chipping Norton, UK
    273
    Paul, thanks for your time and dedication to the cause as ever, Adafruit's libraries both work fine with the Adafruit_ILI9341 library showing better speeds. The results of each, corrupted output aside, are shown below.
    I have wired the reset pin and changed the ILI9341_t3 constructor to:
    // For the Adafruit shield, these are the default.
    #define TFT_RST  8
    #define TFT_DC  9
    #define TFT_CS 10
    // Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
    ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST);
    Is that the correct syntax for specifying the reset and do I need to do anything else as I am still getting the corruption?
    Results:
    Begin Adafruit_ILI9340 Test!
    Benchmark Time (microseconds)
    Screen fill 1945672
    Text 148299
    Lines 1488543
    Horiz/Vert Lines 161468
    Rectangles (outline) 104783
    Rectangles (filled) 4040175
    Circles (filled) 686411
    Circles (outline) 649668
    Triangles (outline) 472213
    Triangles (filled) 1379234
    Rounded rects (outline) 267230
    Rounded rects (filled) 4434364
    Done!
    ILI9341 Test!
    Display Power Mode: 0x9C
    MADCTL Mode: 0x48
    Pixel Format: 0x5
    Image Format: 0x9C
    Self Diagnostic: 0x0
    Screen fill 1194090
    Text 83368
    Lines 809350
    Horiz/Vert Lines 98596
    Rectangles (outline) 63663
    Rectangles (filled) 2479508
    Circles (filled) 400018
    Circles (outline) 352556
    Triangles (outline) 256761
    Triangles (filled) 834986
    Rounded rects (outline) 150474
    Rounded rects (filled) 2714640
    Done!
    ILI9341_t3 Test!
    Display Power Mode: 0xCE
    MADCTL Mode: 0x24
    Pixel Format: 0x2
    Image Format: 0xCE
    Self Diagnostic: 0xE0
    Screen fill 280114
    Text 19429
    Lines 73327
    Horiz/Vert Lines 23146
    Rectangles (outline) 14671
    Rectangles (filled) 581718
    Circles (filled) 95539
    Circles (outline) 95510
    Triangles (outline) 17807
    Triangles (filled) 197552
    Rounded rects (outline) 39902
    Rounded rects (filled) 637639
    Done!
  2. #102
    5,421
    Did you try with the reset line installed and used? As I mentioned, I had better luck with the 2.2" when I did that earlier. Maybe later I will tyr to hook it back up and see. My guess is that it is an initialization timing issue...
  3. #103
    Chipping Norton, UK
    273
    Kurt, thanks for your time. I did try the reset line, see the code section of my last post. I seem to have got it working now but I had some intermittent issues. May have been a breadboard issue as I stripped it all down and rebuilt it and it seems fine now.
    Can you look at my last post and see if I have it correct with regard to the reset?
  4. #104
    Dec 2014
    17
    ILI9341_t3: YFY! It works. Speeding up the LCD text draws was my next task and Boom! It's done with no effort with Paul's library. Thanks, anyone who contributed. I'm using a T3 with the 2.3" color LCD over SPI. It was sad how slow it ran with the Adafruit driver, about 1/3 second to redraw about half the screen with medium size text. Now, 50mS.
    Next up is to get decent fonts up instead of the "minecraft" 5x7 horror. I see several projects for this but everything I've tried so far requires more Arduino/T3/C brains or less lazyness on my part. There is Adafruit_mfGFX from pkourany (https://github.com/pkourany/Adafruit_mfGFX_Library), and ILI9341_due from marekburiak with a port of gText and some fast SPI DMA drivers for Arduino Due (http://marekburiak.github.io/ILI9341_due/). And gText for Arduino itself. Then I see comments on this forum about some work on fonts, how far has that gone? I've tried the options I've mentioned but nothing just builds for the T3 with teensyduino 1.20. What thinks ye the best place to start?
  5. #105
    Mar 2013
    15
    Text overwrite problem
    Hi all -
    It appears there is a problem with text overwrite - if the background is transparent, then the old text is not overwritten properly. If you do set a separate text BG color, then things work as expected. The problem looks to be in drawChar, the "if (fgcolor == bgcolor)" code doesn't properly overwrite previous characters.
    I made a quick small test program to confirm. The top line will print correctly, the lower one will get mangled with the old and new text:
    Code example here (Using Teensy 3.1, :
    #include "SPI.h"
    #include "ILI9341_t3.h"
    #define TFT_DC 9
    #define TFT_CS 10
    #define XOFFSET 10
    tft.begin();
    tft.setTextSize(3);
    tft.setRotation(3);
    tft.setCursor(0, 0);
    tft.setTextColor(ILI9341_WHITE,ILI9341_BLUE );
    tft.println("Test Text");
    tft.setCursor(0, 120);
    tft.setTextColor(ILI9341_WHITE );
    delay(3000);
    tft.println("Overwrite Text");
    tft.setTextColor(ILI9341_WHITE);
    void loop(void) {
  6. #106
    5,421
    I think you can say that is by design. That is as you said transparent. So it only sets the high bits and leaves the other bits as it found them. If you wish for it to be filled in, then set the background color. Hint, set the background color as it also speeds up the drawing.
    Kurt
  7. #107
    Mar 2013
    15
    Hey Kurt - thanks for the quick reply -
    Ah I get it - Since I am am using ILI9341_BLACK as my background, then when I set the text color I should do it this way:
    tft.setTextColor(ILI9341_WHITE,ILI9341_BLACK);
    Ok that works -
  8. #108
    ILI9341 not working with color display, Teensy3.1 + purple board
    Sorry to annoy you guys, this must be really, really silly but I can't get this to work.
    I am trying the optimized library with the color display, teensy 3.1 and the purple board.
    The display is lit, but it does not show anything.
    This is what I see from the serial port
    ILI9341 Test!
    Display Power Mode: 0x0
    MADCTL Mode: 0x0
    Pixel Format: 0x0
    Image Format: 0x0
    Screen fill 280110
    Text 19592
    Lines 73325
    Horiz/Vert Lines 23153
    Rectangles (outline) 14667
    Rectangles (filled) 581724
    Circles (filled) 95757
    Circles (outline) 96128
    Triangles (outline) 17804
    Triangles (filled) 197581
    Rounded rects (outline) 40183
    Rounded rects (filled) 637588
    Done!
    Any ideas where to look ?
    I have two of the color display board, and I get the same values/messages from the serial port (including Display Power Mode 0x0 ...)
    Thanks,
  9. #109
    20,570
    Quote Originally Posted by alfa66 View Post
    We can't see how you built this (and what went wrong). You must post photos if you want useful help.
  10. #110
    Jun 2013
    Southern Colorado
    66
    A good place to start would be to double check your connections outlined here: http://www.pjrc.com/store/display_ili9341.html
  11. #111
    Hi Paul, thank you.
    everything works when I put it on the breadboard.
    I might have done something wrong with the purple board... (i ordered a batch of 3 from OshPark, and 3 sets of components from DigiKey)
    I will build another purple board, then keep debugging.
  12. #112
    Paul,
    the purple board has the RST signal connected to pin 8 of Teensy 3.1
    So I guess I will have to add the RST control to the graphicstest program.
    Sorry if this is already documented and I missed it.
    May I recommend to update graphicstest in your library distribution with a comment about the Purple Board ? It may save some time to the next noob
  13. #113
    20,570
    Opps, yes, you're right. RST is connected to pin 8 instead of VCC.
    Does adding this in setup(), before starting the display, make it work?
    pinMode(8, OUTPUT);
    digitalWrite(8, HIGH);
  14. #114
    Hi Paul,
    tried that, did not work.
    This is how I made it work:
    #define TFT_DC 9
    #define TFT_CS 10
    #define TFT_RST 8 // for the purple board
    //#define TFT_DC 20
    //#define TFT_CS 21
    Since I figured out that ILI9341_t3 had an optional RST argument.
    Love your products, and the community that you are building around them.
  15. #115
    20,570
    I've added a link on the OSH Park shared PCB page, to this thread. Hopefully that will help anyone else who hits this issue.
    I also created a revised copy of the PCB and ordered 3 from OSH Park.
  16. #116
    Paul,
    can you please check the DC plug of the PCB?
    I did not ordered mines from Mouser, I already had some (maybe they are not the right ones).
    When I connect the power, my walwart unit shorts. I am not an expert of pinouts of DC plugs though, again I may have the wrong ones - but I am suspicious because the pinout is identical ....
  17. #117
    273
    You are probably right. With the DC power jack from Mouser, the board shorts always. Terminal 1a and 3c from the power jack are connected together on the pcb. 1a is the tip of the plug and 3c is the sleeve.
  18. #118
    Jun 2014
    12
    Hi Paul,
    I am using a different display with my teensy3.1. My question is one of compatibility. I am using the 2.8" TFT from buydisplay.com http://www.buydisplay.com/default/sp...-arduino-stm32
    This display also runs off of the ILI9341 chip. as long as I wire it correctly I should be able to use the same code libraries right ?
    Thanks,
    Brian
  19. #119
    Jan 2015
    Germany
    20
    Exclamation Streaming Write
    I modified the T3 ILI9341 library a bit to support streaming writes. The purpose was to transfer as much data as possible over USB and stream it to the display.
      tft.begin();
      tft.setRotation(1);
      tft.setAddrWindow(0, 0, ILI9341_TFTHEIGHT - 1, ILI9341_TFTWIDTH - 1);
    I added a new method streamWrite(uint16_t* Buffer, uint32_t Size) that uses the ILI9341 "Write Continue" command. This saves the call to set the window rect each time a new data block gets written to TFT memory.
    void ILI9341_t3::streamWrite(uint16_t* Buffer, unsigned int Size) {
    	SPI.beginTransaction(SPISettings(SPICLOCK, MSBFIRST, SPI_MODE0));
    	writecommand_cont(0x3C); // Write Continue Command
    	for (unsigned int i = 0; i < Size / sizeof(uint16_t); i++) {
    		writedata16_cont(*Buffer++);
    	SPI.endTransaction();
    Once the end is reached, the window rect will reset:
    int i = 0;
    void loop(void) {
      char Buffer[320];
      unsigned short int Count = Serial.readBytes(Buffer, 320); // How much can/should we read at once here??
      if (Count > 0) { // Todo: Assumes Count % 2 == 0
        i += Count;
        tft.streamWrite((uint16_t*) Buffer, Count);
      if (i >= ILI9341_TFTWIDTH * ILI9341_TFTHEIGHT * 2) {
        i = 0;
        tft.setAddrWindow(0, 0, ILI9341_TFTHEIGHT-1, ILI9341_TFTWIDTH-1);
    You can see the streaming in action:
    However there is an anoying issue. Everytime the TFT memory gets written, there is a brightness flickering (see video). I don't know how to get rid of it. Any ideas? There are about 5 frames per second, this is pretty slow but I think this is a limitation of the USB bus. I measured about 920KB/s USB transfer at maximum, this sould be close to maximum transfer rate.
    Are there any suggestions for improvement? Should we add this "streamWrite" to the ILI9341 library?
    Update:
    Please also take a look at https://www.youtube.com/watch?v=gJxs3Rm0aTU It shows an ÁProcessor generated animated graph with refresh rate of 33 ms.
  20. #120
    10
    Quote Originally Posted by xzeion View Post
    Hi Paul,
    Thanks,
    Brian
    Brian,
    I am in the process of playing with one of the buydisplay.com displays. The ILI9341 library works great ! and after trying a dozen different SD cards, the SD library works also.. 1-2 mb SD cards appear to be the only cards I have found to work so far.
    I have not gotten the the touch pad working with the XPT2046 driver IC or the built in font IC and Flash ram but still working on it.
    Look forward to seeing if there are others out there trying their display and hopefully share there success stories.
    I had issues for a few hours. I ordered a few of the 4-wire SPI and got one of them configured for 3-Wire SPI and nothing was working. After reading the manual and seeing the jumper settings I found I pick the wrong display to start with. So if you have issues, make to verify what version you received.
    Best of luck.
  21. #121
    Aug 2014
    124
    Hi Guys,
    I modified the optimized library to work with vertical text scroll, I needed this to make the library work with bitlash and other projects when I need the screen to act like a terminal.
    You can select partial of the screen to be "scrollable" with the "setScrollTextArea" function.
    I think I already saw someone here asking about it, so I'm sharing the modified version. Let me know if you find issues.
    https://github.com/vitormhenrique/ILI9341_t3
    Check it working:
  22. #122
    Jun 2013
    Southern Colorado
    66
    @vitormhenrique
    Thanks for the modified lib. I thought it had a couple of bugs
    but I was coding badly......so far it works great. I'm using the
    whole 320 x 240 for a scroll area with a black background and
    yellow text to emulate a simple terminal and it looks great!
  23. #123
    Aug 2014
    124
    Thanks!
    I actually will change and document some stuff, currently the enableScroll is setting the background area to whatever it has or a default black, i did not like that, because if you enable and disable the text scroll on the middle of your code it is going to "erase" your screen, or part of if.
    You also need to set the scroll area before do anything with the screen, otherwise the text warp will be messed up.
    I did not had many time to test it, and this was my first attempt to modify a library, so I bet there are few issues.
    Let me know if you have any idea of improvements (horizontal scroll maybe?)
    Vitor Henrique
  24. #124
    Jun 2013
    Southern Colorado
    66
    using teensy 3.1, teensyduino 1.20, arduino 1.0.6
    When the horizontal scroll area is exceeded sometimes a character is lost.
    Check out my convoluted test code below. However I have tried many different scroll area
    sizes with different background and text colors with different text sizes and this is
    the only issue so far. Using the code below....when the number gets past 99
    it works ok. For my simple terminal emulation projects this is not an issue and
    I'm delighted with your modified lib.
    #include "SPI.h"
    #include <ILI9341_t3.h>
    #define TFT_DC 9
    #define TFT_CS 10
    #define baklite 23
    // If using the breakout, change pins as desired
    //Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
    //Serial.begin(9600);
    pinMode(2,INPUT_PULLUP);
    SPI.setSCK(14);
    analogWrite(baklite,175);
    tft.begin();
    tft.setRotation(3);
    tft.enableScroll();
    tft.setScrollTextArea(0,0,320,240,ILI9341_WHITE);
    tft.setTextSize(3);
    tft.setTextColor(ILI9341_BLACK);
    void loop(void)
    for(int i=0;i<1000;i++)
    tft.print("This is line---");
    tft.println(i);
    while(!digitalRead (2));
    delay(2000);
  25. #125
    Dear Forumers, would welcome suggestions on how to fix this.
    I am using the Color Display with Paul's audio shield. Also, I am accessing correctly the optional EEPROM that I installed in the shield.
    Everything seems to be working fine, but I hear an annoying buzz from the audio shield.
    The buzz starts when I perform the first
    Per Paul's instructions, I am using the following settings for the color shield:
    vvvvv
    #define TFT_DC 20
    #define TFT_CS 21
    SPI.setMOSI(7);
    SPI.setSCK(14);
    tft.begin();
    The code below reads from EEPROM the different waveforms stored, displays them and plays them back in the color shield.
    I get the expected behavior, except for the annoying buzzing.
    Feb 7th 2015: hardware completed, experimented with ILI9341 graphics
    Feb 14th 2015: display waveforms from ROM, play back through Audio Shield
    #include "Audio.h"
    #include "SPI.h"
    #include "MIDI.h"
    #include "Wire.h"
    #include "flash_spi.h"
    #include "SD.h"
    #define FLASHSIZE 16777216
    #define PAGE 256 //dimension of 1 EEPROM page (in bytes)
    unsigned char buf2[PAGE]; // we are using this buffer for reading from the EEPROM
    int16_t buf[PAGE];
    int page = 0;
    // Set DC and CS, no conflict with Paul's Audio Adapter
    #define TFT_DC 20
    #define TFT_CS 21
    // Use hardware SPI and the above for CS/DC. Reset is tied to 3.3V, no need for a 3rd pin
    uint16_t screenWidth, screenHeight;
    //Audio Shield
    float maxFREQ = 1200;
    AudioSynthWaveform waveform1;
    AudioOutputI2S i2s1;
    AudioConnection patchCord1(waveform1, 0, i2s1, 0);
    AudioConnection patchCord2(waveform1, 0, i2s1, 1);
    // Needed when using ILI9341 with the audio shield
    SPI.setMOSI(7);
    SPI.setSCK(14);
    // Set Up TFT Screen
    tft.begin();
    tft.fillScreen(ILI9341_BLACK); // reset screen
    tft.setRotation(3); // Set orientation
    tft.setTextSize(1);
    screenWidth = tft.width();
    screenHeight = tft.height();
    // tft.setTextColor(ILI9341_YELLOW);
    drawWaveBox(ILI9341_YELLOW);
    // Initialize EEPROM
    flash_init();
    // Initialize Audio Shield
    AudioMemory(18);
    audioShield.enable();
    audioShield.volume(.7);
    // Arbitrary Waveform, this is where we play the waveforms from the EEPROM
    waveform1.begin(0.45, 440, WAVEFORM_ARBITRARY);
    void loop(void) {
    int i;
    page=0;
    while(1) {
    flash_read_pages(buf2, page, 1);
    for (int i=0; i<PAGE; i++) {
    buf[i] = (int16_t) buf2[i];
    drawWave(buf, page, ILI9341_RED);
    waveform1.arbitraryWaveform(buf, 440);
    while(1);
    drawWave(buf, page, ILI9341_BLACK);
    page++;
    if ((int) page / 16 == 16) page = 0;
