Constantin
Attached below is a revised BRD file based on the one you sent me. There seems to be an ERC issue between the SCH file and the BRD file surrounding the SCL/SDA pins for the I2C bus. Not sure what the issue is, which one was right (schematic or BRD file) so I just revised the BRD file.
Here is what I came up with in an hour or two. Note the much lower number of cuts across the GND plane and the revised location of the battery holder. Kudos on the quick implementation of the Yaimichi connector, it's a great little micro-SD card holder, if only Digikey also chose to carry it.
Also, please note how I moved all through-hole components to the other side of the board, with the SMD components only mounted on the top side. Gives you more room to assemble / solder the thing and there is usually no good reason to not move the SMD components to the underside of the board.
View attachment MotoDisplay v0.1.zip
