Results 1 to 7 of 7
Thread: Teensy 3.1 Audio Shield FFT Problems
    Wiesbaden Germany
    4
    Hi, i'm currently working on a micro audio solution. Most of the planned features are working but when i try to compile a version with FFT i always get this compiler error.
    D:\Arduino_Build\fft\core.a(analyze_fft256.cpp.o): In function `AudioAnalyzeFFT256::update()':
    D:\arduino-1.0.5\libraries\Audio/analyze_fft256.cpp:83: undefined reference to `arm_cfft_radix4_q15'
    D:\Arduino_Build\fft\core.a(analyze_fft256.cpp.o): In function `AudioAnalyzeFFT256::init()':
    D:\arduino-1.0.5\libraries\Audio/analyze_fft256.cpp:38: undefined reference to `arm_cfft_radix4_init_q15'
    I'm using the i2c_t3 library instead of Wire, because i use 2 busses with different speed.
    27,108
    Are you building in Arduino with Teensyduino, or with a non-Arduino makefile?
    I'm guessing this is a non-Arduino build that isn't linking in the ARM math library.
    Wiesbaden Germany
    4
    I'm using Arduino with Teensyduino but Subleme Text 2 as external editor.
    27,108
    First, make sure you're using at least Teensyduino version 1.19. Use Arduino's Help > About menu to check. If you have an older version, upgrade to at least 1.19. Th
    If so, use File > Prefernces to turn on verbose info while compiling. That extra info is needed to troubleshoot this issue. Arduino should give you a "copy error" button to easily copy the entire output to the clipboard. Best to paste it here inside "code" tags, since it'll be long.
    Wiesbaden Germany
    4
    Found the issue, its the SublemeText plugin. It works in Arduino/Teensyduino.
    Member kig's Avatar
    Nov 2014
    San Francisco
    44
    Was having the same issue using Eclipse Arduino plugin. Would compile in Arduino, but not in Eclipse.
    Solved by adding -larm_cortexM4l_math to extra parameters to "combiner" in project properties, C/C++ Build, Settings, Arduino Combiner, Command Line Pattern. That's where I added it.
    Mar 2015
    Sydney, Australia
    6
    @Kig, You sir are a champ!
    Thanks to you I can compile with eclipse now instead of the horrible Arduino IDE!
