Results 1 to 3 of 3
Thread: Encoder library - works fine on Uno R3, not on Due
    Aug 2014
    6
    I'm trying to use the Encoder library v1.2, running the "Basic" example sketch compiled with Arduino IDE v1.5.7 on a Due with encoder attached to pins (5,6) plus ground. Regardless of which direction I rotate the encoder it only counts up -- never down. Running the same sketch on my Uno R3 board but using pins (2,3) (I want to use interrupts,) and it works fine -- counts up and down as I expect.
    The encoder I am using: https://www.sparkfun.com/products/10596
    I also tried the "NoInterrupts" example sketch and it also only counts up on the Due and works fine on the Uno.
    Any ideas? Thanks for your help.
    1,228
    You'd be a lot better off asking about this on the Due forum which is here.
    Pete
    Aug 2014
    6
    Okay thanks -- will do.
