Results 1 to 2 of 2
Thread: DmxReceiver and Enttec ODE
    Hi.
    I my code has been successfully running using the great DmxReceiver.h library.
    I supplied a DMX signal with the Enttec USB PRO interface. The dmx controlled LEDs faded nice and steady.
    Now i am trying the same code on the same teensy 3.1 with a DMX signal that is supplied from an Enttec ODE (Artnet) device.
    The LEDs flicker.
    I read somewhere that the ODE device sends a DMX signal at 44.2 hz,
    Is it possible that the DmxReceiver library can't handle such a signal.
    Or maybe the library does not conform to the DMX standards stated here:http://www.enttec.com/docs/rs232_spec.pdf
    thanks,
    stephan
    ok.
    just downloaded this newer version and it seems to have removed the flicker.
    https://github.com/jimparis/DmxReceiver
    s.
