Results 1 to 6 of 6
Thread: SPI compiler error with ILI9341_t3 (Teensy 3.1)
    Dec 2013
    5
    I have been using the Teensy 3.1 with the Adafruit ILI9341 display library for a while without any problems. I have been trying to run the graphicstest example for the new ILI9341_t3 library and am unable to because of some compiler errors related to SPI. I have verified that I am using the newest version of the Arduino environment and Teensyduino. I feel I might just be doing something stupid.
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::setAddrWindow(uint16_t, uint16_t, uint16_t, uint16_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:47:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:47:64: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:50:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::pushColor(uint16_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:55:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:55:64: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:57:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawPixel(int16_t, int16_t, uint16_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:64:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:64:64: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:68:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawFastVLine(int16_t, int16_t, int16_t, uint16_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:76:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:76:64: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:83:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawFastHLine(int16_t, int16_t, int16_t, uint16_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:91:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:91:64: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:98:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::fillRect(int16_t, int16_t, int16_t, int16_t, uint16_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:117:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:117:64: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:126:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'uint8_t ILI9341_t3::readcommand8(uint8_t, uint8_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:211:9: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:211:67: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:255:9: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'uint16_t ILI9341_t3::readPixel(int16_t, int16_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:263:9: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:263:67: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:282:9: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::begin()':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:314:10: error: 'class SPIClass' has no member named 'pinIsChipSelect'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:315:18: error: 'class SPIClass' has no member named 'setCS'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:316:32: error: 'class SPIClass' has no member named 'setCS'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:344:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:344:64: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:355:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:358:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:360:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawLine(int16_t, int16_t, int16_t, int16_t, uint16_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:555:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:555:64: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:596:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawRect(int16_t, int16_t, int16_t, int16_t, uint16_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:602:6: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:602:64: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:608:6: error: 'class SPIClass' has no member named 'endTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp: In member function 'void ILI9341_t3::drawChar(int16_t, int16_t, unsigned char, uint16_t, uint16_t, uint8_t)':
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:850:7: error: 'class SPIClass' has no member named 'beginTransaction'
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:850:65: error: 'SPISettings' was not declared in this scope
    /Users/santiagogonzalez/Dropbox/Arduino/libraries/ILI9341_t3/ILI9341_t3.cpp:880:7: error: 'class SPIClass' has no member named 'endTransaction'
    Jun 2013
    So. Calif
    2,825
    1.0x
    not
    1.5x
    SPI beginTransaction is new/experimental.
    Boston, MA, USA
    1,117
    You need 1.0.5 (not 1.0.4 or earlier, and not 1.5.x) and you also need Teensyduino 1.20rc2 which you can get at
    http://forum.pjrc.com/threads/26298-...te-2-Available
    Dec 2013
    5
    I am using using 1.0.5. I guess that I just needed the release candidate. Thanks!
    Boston, MA, USA
    1,117
    Yes, the SPI transaction stuff is brand new (hence the errors for beginTransaction etc that you got).
    27,400
    You need 1.20-rc2. Version 1.19 is too old for this new SPI stuff.
