How to create array for four 4051s on teensy2 analog pins
Hello..
I need desperate help with my controllers
i am using 4 4051s on teensy2 pins A0,A1,A2,A3
how do i code an array to loop through all analog inputs ?
currently i can only read 1 4051 at a time with this code :
//ANALOG IN MUX loop _______________________________________________
int toReadAnalogMux[] = {
           //IC pin number are written below
  1,1,1,1, //0-3
  1,1,1,1,
  1,1,1,1,
  1,1,1,1//4-7
  //DEBUG_______________________________________________
  //enable if you want to test your output in the serial monitor
boolean enableDebug = 0;  // 1 for enable, 0 for disable. **Remember to disable debug when running MIDI**.
int analogThreshold = 3;
//int INH_pin = 11; //analog read pin
int analogInsPrev[26]; //array to hold previously read analog values - set all to zero for now
int tempAnalogInMux = 0; //array to hold previously read analog values
int tempAnalogInMap = 0;
int ax = 0; //address pins
int bx = 1; //address pins
int cx = 2; //address pins
int analogPin = 19;
int controlPin[3] = {ax,bx,cx}; //set contol pins in array
int muxChannel[8][4]={{0,0,0,0},{1,0,0,0},{0,1,0,0},{1,1,0,0},{0,0,1,0},{1,0,1,0},{0,1,1,0},{1,1,1,0}};
//function to read mux
int readMux(int channel){
  //loop through the three control pins
  for(int i = 0; i < 3; i ++){
    //turn on/off the appropriate control pins according to what channel we are trying to read
    digitalWrite(controlPin[i], muxChannel[channel][i]);
  //read the value of the pin
  int val = analogRead(analogPin);
  //return the value
  return val;
void loop(){
  for(int i=0;i<8;i++){       //loop through 8 mux channels
    //for(int multi = 9; multi > -1; multi--)                      // MY ATTEMPT :/
    if(toReadAnalogMux[i]==1){                                   //we read this mux channel analog input
      tempAnalogInMux = readMux(i);                              //read values using readMux function
      if(abs(analogInsPrev[i]-tempAnalogInMux)>analogThreshold){ //ensure value changed more than our threshold
        tempAnalogInMap = map(tempAnalogInMux,0,1023,0,127);     //remap value between 0 and 127
        usbMIDI.sendControlChange(i+1,tempAnalogInMap,2);        //send message
        analogInsPrev[i]=tempAnalogInMux;                        //update current value
Thank you very much in advance !!
I don't quite understand this question. It looks like you're doing things correctly now.
hi thanks for the reply !
:D
basically the above code only aloows for one 4051 to be read at a time depending on which pin i select
eg:
if i have this : int analogPin = 18; (i can read the first 4051 (8 faders)
if i change the code to : int analogPin = 19; ( i can then read the second 4051 (8 faders)
I need to read all 4 analog pins at once the muxes are connectec to teensy pins 18,19,20 and 21
Then modify the code to read 2 analog inputs at once:
//make val1 and val2 global outside of all the functions
int val1;
int val2;
// inside the readMux function
val1 = analogRead(analogPin1);
val2 = analogRead(analogPin2);
Or rework the function to accept the array itself and have it fill the array on each call. In the loop inside the function have it read the 2 pins at once.
int val1;
int val2;
Thank you for that..
Ive done the code as you said and it still only reads one mux at a time :(
