I'm trying to change the frequency on timer 2 (pin 25/32) for Teensy 3.1, It doesn't seem to work. Does Teensy 3.1 even support this command? Or will the timer1 library work even?
https://www.pjrc.com/teensy/td_pulse.html
https://www.pjrc.com/teensy/td_libs_TimerOne.html
analogWriteFrequency(25, 38000); // Teensy 3.0 pin 3 also changes to 375 kHz, trying to make it output 38khz, but it still shows 488hz on the scope, called in setup{}.
