/tmp/build7632845037380780056.tmp/Utils.cpp: In function 'JS_DIRECTION _readJoystick(int, int)':
/tmp/build7632845037380780056.tmp/Utils.cpp:168:1: warning: control reaches end of non-void function [-Wreturn-type]
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void waitForTicCount(int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:56:30: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (targetTicCount < ticCount) {
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleTimeDivision(int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:67:57: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Time Division (PPQN): %d\n", _ppqn);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:72:76: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "ticTime in microseconds: %d\n", ticTimeInMicroseconds);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleNoteOff(uint32_t, int, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:78:112: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Note Off at: %d for Channel: %d, Note: %d, Velocity: %d\n", tics, channel, note, velocity);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleNoteOn(uint32_t, int, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:86:111: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Note On at: %d for Channel: %d, Note: %d, Velocity: %d\n", tics, channel, note, velocity);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleNoteAfterTouch(uint32_t, int, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:94:114: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Note After Touch at: %d for Channel: %d, Note: %d, Value: %d\n", tics, channel, note, value);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleController(uint32_t, int, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:100:120: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Controller at: %d for Channel: %d, Controller: %d, Value: %d\n", tics, channel, controller, value);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleProgramChange(uint32_t, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:108:100: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Program Change at: %d for Channel: %d, Program: %d\n", tics, channel, program);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleChannelAfterTouch(uint32_t, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:116:101: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Channel After Touch at: %d for Channel: %d, Value: %d\n", tics, channel, value);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handlePitchBend(uint32_t, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:121:92: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Pitch Bend at: %d for Channel: %d, Value: %d\n", tics, channel, value);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleSequenceNumber(uint32_t, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:128:100: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Sequence at: %d - NumberMSB: %d, NumberLSB: %d\n", tics, numberMSB, numberLSB);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleTextEvent(uint32_t, char*)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:133:60: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Text Eventat: %d: - %s\n", tics, text);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleCopyrightNotice(uint32_t, char*)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:138:67: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Copyright Notice at: %d: - %s\n", tics, text);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleSequenceTrackName(uint32_t, char*)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:143:70: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Sequence Track Name at: %d: - %s\n", tics, text);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleInstrumentName(uint32_t, char*)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:148:66: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Instrument Name at: %d: - %s\n", tics, text);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleLyric(uint32_t, char*)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:153:56: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Lyric at: %d: - %s\n", tics, text);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleMarker(uint32_t, char*)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:158:57: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Marker at: %d: - %s\n", tics, text);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleCuePoint(uint32_t, char*)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:163:60: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Cue Point at: %d: - %s\n", tics, text);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleMidiChannelPrefix(uint32_t, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:168:73: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Midi Channel Prefix at: %d: - %d\n", tics, channel);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleSetTempo(uint32_t, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:173:91: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Set Tempo (micro seconds / quarter note) at: %d - %d\n", tics, tempo);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:179:76: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleSMPTEOffset(uint32_t, int, int, int, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:185:47: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
tics, hours, mins, secs, frames, subFrames);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleTimeSignature(uint32_t, int, int, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:191:48: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
tics, numerator, denominator, metro, _32nds);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleKeySignature(uint32_t, int, int)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:196:85: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Key Signature at: %d - Key: %d, Scale: %d\n", tics, key, scale);
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp: In function 'void handleSequencerSpecificMetaEvent(uint32_t, char*)':
/tmp/build7632845037380780056.tmp/MIDIPlayer.cpp:201:83: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
logger(LOG_INFO, "Sequencer Specific Meta Event at: %d - Data: \n", tics, data);
/tmp/build7632845037380780056.tmp/UISMFunctions.cpp:28:28: fatal error: AUISMFunctions.h: No such file or directory
#include "AUISMFunctions.h"
compilation terminated.
