Results 1 to 2 of 2
Thread: Arduino 1.0.6
    Boston, MA, USA
    1,108
    Arduino 1.0.6
    Changelog
    Core
    avr: Improved USB-CDC write speed (Justin Rajewski)
    avr: Improved USB-CDC read code (Paul Brook)
    avr: Fixed race condition in USB-CDC transmit (Paul Brook)
    avr: Added replacement stub for cstdlib atexit() funciton (Christopher Andrews)
    Fixed wrong NULL pointer handling in Stream class (Amulya Kumar Sahoo)
    Backported String class from IDE 1.5.x (Matt Jenkins)
    Backported Print class from IDE 1.5.x
    Backported digitalPinToInterrupt macro from IDE 1.5.x
    Added initVariant() hook to allow 3rd party variant-specific initialization
    Added replacement stub for cstdlib atexit() function (Christopher Andrews)
    IDE
    Added compatibility for IDE 1.5.x libraries layout
    Fix toolchain command line to compile assembler files (Jimmy Hedman)
    If two libraries have the same header file use the lib with the same folder name (Paul Stoffregen)
    Libraries
    Robot_Control: removed duplicated SPI and Wire (Xun Yang)
    Robot_Control: fixed issue on motors being opposite (Xun Yang)
    Robot_Control: updated turning algorithm (Xun Yang)
    Esplora: added reading form Tinkerkit inputs
    SoftwareSerial: Fix idle level when initializing with inverted logic (Jens-Christian Skibakk)
    fixed a bunch of examples
    Firmware
    Wifishield: fixed paths on firmware upgrade scripts
    https://github.com/arduino/Arduino/releases/tag/1.0.6
    21,302
    Saw the release just now. I've been holding off 1.20, since 1.0.6 was expected "soon" for the last couple months.
    I hope to have 1.20 on the website later today.
