What is the max output frequency of analog ouput Teensy3.1?
Hi all,
I searched for informations to known how I can generate 10Mhz to 15Mhz sinus signal on analog output (that it will be use to control a NE612 mixer).
It's possible with Teensy 3.1 ?
It's depend of the setup in makefile (from fresh generated project with avr-project cmd line ):
line 21 of Makefile: -> CLOCK = 8000000 must be set to 75000000 ????
Teensy 3.1 must be over-clocked ?
It seem that the nominal frequency of Teensy 3.1 is 72Mhz ( https://www.pjrc.com/teensy/teensy31.html#specs )
Thank you in advance. Bruno
I don't think you're going to get that high on the DAC. My recollection is that it's set up for audio signals in the kHz range, ie less than 44.1kHz.
I use one of the digital PWM pins as a clock input to a MCP3910 and the highest I've gotten that without over clocking was 12 MHz. With over clocking the pin may reach 15MHz.
So I would be surprised if you could get a teensy to put out a MHz-level sinusoid signal. Methinks you'd have to invest in a external DAC. Whether the teensy could control it adequately is a different question. But it seems likely that a faster processor is necessary. Anyhow, I'd still buy a teensy - they are awesome MCU's.
Thank for your reply.
In fact, I was looking for the easiest way to inject a signal to a NE612 without a colpitts. So as I understand it, the better it is Colpits and an analog output of Teensy3.1 to drive it in VCO.
So, a question again. How can I set CLOCK speed in make file. With this:
CLOCK = 75000000
Any help is welcome.
Thank, Bruno.
Start with Arduino, even if you never intend to really use it. Arduino has a "verbose info" option in File > Preferences. Then you can see the compile commands. The clock is set with F_CPU.
There's also a sample makefile in hardware/teensy/cores/teensy3.
I think Paul meant that response for a different thread.
I haven't done it myself, but I suspect your best bet will be a direct digital synthesis (DDS) IC. I understand some of those have built-in mixers and might reduce your component count and complexity overall.
Regards,
Dave
Yes Mr drg, I don't known that is best solution but the goal is "how to reduce":
- capacitors ajustement ( UHF spectrum )
- the number of component on the PCB
- circuitry
In a first time, 2 new teensy3.1 are expected and are not delivered yet :-(
Thank at all. Bruno
Hi all,
Here the benchmark with my Teensy 3.1. The goal was to known the max output frequency on DAC (A14 output). The conditions of tests are:
. Teensy must generate an sine wave and square wave in "good form" with minor distortion or best, no distorsion.
. Teensy program don't do nothing else.
sine program here:
Sine generator.
It works with A14/DAC on Teensy 3.1
Autor: Bruno Poultier.
Goal: Testing the max frequency available on A14/DAC with sine wave
Tests conditions:
. The same source has been compiled whith various CPU clocks: 96Mhz, 72Mhz, 48Mhz and 24Mhz
. 12 bits resolution (max)
. the output is free of charge (no capacitor, resistor, etc)
. the output signal must be clean (beautiful sine)
This example code is based on PJRC project.
float _2pi = 3.14159265 * 2;
// 2 * pi() ~ 6.28 / 0.01 => 628 dots
const int DOT = 628;
float amplitude[DOT];
Fill array with all values.
arg: none
return: none
void fillAmplitude(){
for ( int x = 0 ; x < DOT ; x++){
amplitude[x] = (sin( x * 0.01 ) * 2000.0 ) + 2050.0F;
} // eo for
Create the sine wave with the precalculated values
arg: none
retur: none
void preCalculatedAmplitude(){
// sine wave
while(1){
for ( int i = 0 ; i < DOT ; i++){
analogWrite(A14, amplitude[i]);
}//eo for
}//oe while 1
create sine wave dynamically and send value to the A14.
arg: none
return: none
void computeSine(){
float phase = 0.0F;
while(1){
float amp = sin(phase) * 2000.0 + 2050.0;
analogWrite(A14, (int) amp);
phase = phase + 0.01;
if (phase >= _2pi) phase -= _2pi;
}//eo while 1
initialize all mandatory elements
arg: none
return: none
analogWriteResolution(12); // DAC setup.
fillAmplitude();
preCalculatedAmplitude();
// computeSine();
Square program here:
Square generator.
It works with A14/DAC on Teensy 3.1 only.
Goal: Testing the max frequency available on A14/DAC with square output wave
Tests conditions:
This example code is pjrc project samples.
elapsedMicros usec = 0;
arg: none
return: none
void sleep(unsigned int t){
while ( usec < t )
usec = usec - t;
int _Zero = 1000;
int _One = 4000; // middle of max output capability
// Results from oscilloscope HITACHI V-212
// time slope to pass from 0 to 1.
// 1 | 0.7us
// 2 | 0.65us
// 3 | 0.65us
// 4 | 0,65us
// 5 | 0.7us
// 6 | 0,7us
// 7 | 0.64us
// 8 | 0.66us
// 9 | 0.64us
//10 | 0.66us
//15 | 0.68us
//20 | 0.6us
//50 | 0.65us
//100 | 0.62us
int t = 1 ; // tempo. We need to add a delay to have a nive square signal. No delay gives one "triangular" wave generated
while(1){
analogWrite(A14, _Zero);
//delayMicroseconds(t);
analogWrite(A14, _One);
Hi all,
. These tests has been processed 3 times to be more precise.
Sorry in advance because I have only one digital oscilloscope and I can not put photo of wave sine output.
The dynamic sine calculous has been tested but the output frequency is low. The benchmark results are not in the sheet.
sine program here:
Sine generator.
Tests conditions:
arg: none
return: none
} // eo for
arg: none
retur: none
// sine wave
while(1){
}//eo for
}//oe while 1
arg: none
return: none
void computeSine(){
float phase = 0.0F;
while(1){
}//eo while 1
arg: none
return: none
fillAmplitude();
// computeSine();
Square generator.
Tests conditions:
arg: none
return: none
while ( usec < t )
usec = usec - t;
int _Zero = 1000; // 0 could be bad without delay.
// 1 | 0.7us
// 2 | 0.65us
// 3 | 0.65us
// 4 | 0,65us
// 5 | 0.7us
// 6 | 0,7us
// 7 | 0.64us
// 8 | 0.66us
// 9 | 0.64us
//10 | 0.66us
//15 | 0.68us
//20 | 0.6us
//50 | 0.65us
//100 | 0.62us
int t = 1 ; // tempo. We need to add a delay to have a nice square signal. No delay gives one "triangular" wave generated when CPU clock < 72Mhz. After, it's sine.
while(1){
Sorry for my poor english :-(
Bruno.
- You may not post replies
- You may not edit your posts
Forum Rules
