Experimentalist
Hi
Paul suggests some crystals to use for the real time clock here https://www.pjrc.com/teensy/td_libs_Time.html
The Citizen one he mentions is 6.5pF but in the text he specifies that the crystal should be 12.5pF
I have this crystal http://www.hobbytronics.co.uk/watch-crystal?keyword=crystal
Spec:
C-Type Watch Crystal - 32.768KHz Frequency. Ideal for clock circuits
• 32.768KHz Frequency
• 20ppm Tolerance
• 1.1mm Lead Pitch
• 6pF Load Capacitance
• 3mm diameter
• 8mm case length
Once again this has 6pF load capacitance and Paul repeatedly specifies 12pF in the posts I have seen.
What will be the effect of the different load capacitance? Will it matter?
Anyone?
Ex
Spec:
• 20ppm Tolerance
• 1.1mm Lead Pitch
• 3mm diameter
• 8mm case length
Anyone?
Ex
