OK, answering my own question, since it turned out to be "not so hard". Looking at PLLFRQ on Teensy 2, one can see the PLL is already configured in 48mhz mode for USB support. So the simple hack test I ran was to enable the 1.5 prescaler with PLL to 96mhz giving a 64mhz clock for timer4. The default PWM frequency for pins 4 and 10 is 3906 hz clocked from 16MHz F_CPU (16000000/8/2/256). In the sketch below with timer4 at 64mhz, pin 10 PWM is running 4 times faster at 15625 hz.
// run timer4 at 64mhz
analogWrite(4, 128); // compare pwm signals on scope/analyzer
analogWrite(10, 128); // teensy 2 pin is on timer4 OC4A
PLLFRQ = _BV(PLLTM1) | _BV(PLLUSB) | _BV(PDIV3) | _BV(PDIV1); // 96mhz/1.5
With TIMER4 running at 64MHz , you can run PWM at 250KHz with prescale of 1 and FAST PWM.
