Results 1 to 8 of 8
Thread: IRremote trouble: 'IRsend' does not name a type
    Junior Member Mneventh's Avatar
    6
    Hello!
    I want to use the IRremote library to control a TV using my teensy with an infrared LED. I have set up teensyduino and loaded the blink test successfully.
    I got an error when trying to use IRremote:
    sketch_oct12a:4: error: 'IRsend' does not name a type
    sketch_oct12a.ino: In function 'void loop()':
    sketch_oct12a:10: error: 'irsend' was not declared in this scope
    But class IRsend is defined in IRremote.h. Do you have any suggestions what I might try to get this working please? Thanks a lot.
    This is the code I was trying to use (which is taken from the page here: http://www.pjrc.com/teensy/td_libs_IRremote.html)
    #include <IRremote.h>
    IRsend irsend;
        irsend.sendSony(0x68B92, 20);
        delay(300000);
    6
    I'm more used to using the teensy_loader_cli with C code, is it possible to use this library that way? Maybe that would let me workaround this include error?
    21,476
    Oh no, looks like the RobotIRremote library is causing a conflict.
    Look in your arduino libraries folder. Delete RobotIRremote. That'll probably fix things.
    6
    That was exactly the problem, thanks so much Paul!
    Now to figure out the codes to send..
    Nov 2017
    2
    Question help
    Quote Originally Posted by Mneventh View Post
    Where do I delete the library from I can't find it?
    Nov 2017
    2
    where do I find the library to delete it I cant find it.
    6,350
    Quote Originally Posted by DC3192 View Post
    Assuming you have this issue, you should look to wherever your sketch folder is located. You have not specified anything like what type of machine. But for example on my Windows 10 machine it is located at:
    C:\Users\kurte\Documents\Arduino
    Obviously if your user name is not kurte, it is probably a different directory
    Then look the libraries subdirectory there and then delete the library Paul mentioned.
    And/Or you should look where you installed Arduino and look to delete it there. That is on my 1.8.5 system I see it at:
    D:\arduino-1.8.5\libraries\RobotIRremote
    21,476
    That message is more than 3 years ago.
    This is no longer an issue with recent versions of Arduino & Teensyduino.
    If you need help, please start a new thread. You MUST give us complete info, including the complete code you're compiling, which version of Arduino & Teensyduino you have, which board is selected, and so on. Before you post, read your message. Does it contain enough info, given clearly, so anyone reading could recreate the exact same problem on their computer? Please, put some work into writing a good question, so we can help you.
